Question about Video Game Consoles & Games
Hi I just got a new hdmi cable for my consoles and it supports 1080i I cant get the cable to pick up the console am using :O
  • 1,525 Answers
Hello when you connect hdmi on to games console it should adjust to 1080p you may have to go into menu setting and click on to hdmi setting you should see the game screen good luck
regards
shaun
Posted on Oct 04, 2010
How do I hook up Xbox 360 to the HDTV
Step 1:
Connect the audio/video input of the component cable into the "A/V" port located on the back of the xbox 360
Step 2:
Match the red, blue and green cables on the other end of the component cable to the corresponding component ports on your HDTV. If your HDTV has more than one set of component inputs, make note of which one you use.
Step 3:
Slide the switch on the component cable to "HDTV."
Step 4:
Turn on your HDTV. Set the video mode to the component port that will be used. HDTVs with multiple component ports will usually be labeled "Component 1," "Component 2" and so on
Step 5:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Choose the display setting (720p, 1080i and 1080p) that is best compatible with your HDTV. If you're not sure, try them all until you find the one that looks best.
Step 6:
Disconnect any previously connected A/V or component cables.
Step 7:
Connect the HDMI AV cable connector to the "HDMI AV" port on the Xbox 360.
Step 8:
Connect the other end to an available HDMI port on your HDTV. If your HDTV has more than one HDMI input, make note of which one you use.
Step 9:
Turn on your HDTV. Set the video mode to the HDMI port that will be used. HDTVs with multiple component ports will usually label them "HDMI 1," "HDMI 2" and so on.
Step 10:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Pick the display setting (720p, 1080i and 1080p) that looks best on your HDTV.
Dec 26, 2012 | Video Game Consoles & Games
Ps3 only displays in 1080i
I have similar problem , ps3 320gb + 5 years old sony bravia 1080p = everything OK
but when i connect ps3 to new samsung ue46d7000 1080p = doesn't work (only 1080i)
I am using same HDMI cable
Jun 19, 2012 | Sony Playstation 3 (PS3) Console
I have audio but no video with my HDMI connection
You may have the resolution on the PS3 set higher (say 1080p) then what your TV supports (1080i or 720p). Use the Yellow/Red/White cable that came with the PS3 to connect to the TV. Go to that input and check the resolution. Start at a lower resolution and check the HDMI input. If the TV does support 1080p, try a different/better HDMI cable.
Apr 05, 2011 | Sony Playstation 3 (PS3) Console
So i was messing with the display resolution, it was working fine before i started messing with it... i changed the resolution from 1080i with component cables... to 1080p. I lost the picture unti i...
1080i only works with component cables and wont go to 1080p but your hdmi will set it back to 1080i and then switch back to the component cables.
Jan 03, 2011 | Microsoft Xbox 360 Console
How to set up to using hdmi
#1 your tv would need to be hdmi compatable (have the appropriate plug on the back where all the inputs are located). For example I have a 60" Lcd HDTV and an xbox360 I attached the standard a/v (audio/video) red,white,yellow wires to tv and turned on the game console went into system settings and turned on the hd setting to 1080i for hi def resolution. Another alternative would be to connect console to your dvd player (most new dvd players will up convert signal from 480i or 720i to 1080i hd) and attach your hdmi cable between the dvd player and the tv to support the hd interface. Something I highly recommend is the jvc th c50 home theater surround sound when I play call of duty it has enough to knock stuff of our bookshelves and ******** the neighbors. Happy gaming
Dec 09, 2010 | Video Game Consoles & Games
Cant get a 1080i picture . tv supports this and i'm using a component cable . ( no socket for HDMI cable on tv )
try video reset
when ps3 is in standby mode(red light)
press and hold the power button till you hear a second beep.
standby mode press hold power........"beep"......"beep"..release power button
after plugging in the hd cables
Oct 21, 2009 | Sony Playstation 3 (PS3) Console
Cant get no picture on tv via hdmi or scart was working suddenly stopped
Youve gotta reset your console,,and make sure you switch the video back when you get back on,,if its the ps3 ,,check your manual,, it tells u how to reset,, if the 360,, i would say check the same ,,hdmi is high def,, and scart is analog 480i thats why , must be reset. ,, unless you get a scart cable with component jacks ,, thats 1080i,, hdmi is either or 720p,,1080p,,1080i,,good luck
Oct 05, 2008 | Video Game Consoles & Games
My tv wont pick up my ps3
the tv probbaly cant support and if not just dont use the hdmi cable
Jul 06, 2008 | Sony Playstation 3 (PS3) Console
Ps3 problem
Change the resolution on the ps3 to accept 480p, 720p, 1080i, 1080p.
Jun 14, 2008 | Sony Playstation 3 (PS3) Console
PS3 video issues using 1080i
the best cable to use is an hdmi cable, so long as the tv has hdmi sockets. you shouldn't pay more than 20 pound or 40 dollars for a good one. hope this helps
Jan 18, 2008 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
12 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
