-   DRYER WILL NOT START....I HAVE CHECK THE STARTER SWITCH AND THE DOOR SWITCH WITH A VOM BOTH TEST ZERO OHM....
GETTING VOLTAGE TO POWER BOARD AND TIMER SWITCH.
My Maytag MAH8700 washer is not draining. It appears that the drain pump is not working and may be...
(More)
My Maytag MAH8700 washer is not draining. It appears that the drain pump is not working and may be locked up. I checked it with a meter and am getting power to it. I pulled the pump off and put power to it. It buzzes but does nothing else. Sound like I need to replace the pump?
I ran a diagnostic and it went through all phases...it even did the high speed spin test. Error code...
(More)
I ran a diagnostic and it went through all phases...it even did the high speed spin test. Error code given--E47. My understanding is, this is a door lock issue. Will replacing this part solve the drains, but won't spin issue I have? Thanks in advance.
