Question about Proview PL482S 14 in. Flat Panel LCD Monitor
I connect the screen to a new PC and nothing appears in the screen. Is it necessary a software to install the Proview screen? Is there any solution?
  • 44 Answers
No, you do not need software to see your computer operating system. Unfortunately you did not say what model of computer you have. Are youy sure you are using the wright port? some computers have two (2) graphic ports, one that works and one that does not.
Posted on Oct 04, 2010
After 10 years with a Proview not Proscan RX326 TV, went from coax to HDMI from new Comcast digital adapter. Comcast & Proview remotes turn on TV but the screen often stays dark with no sound.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 06, 2016 | Proview Televison & Video
I have a 42 inch proview tv that only shows a blue screen, what is the problem?
either it is on an input with nothing connected or it is a problem.
Mar 22, 2012 | RCA Televison & Video
I'm trying to authorize my Brand New Sony 650 reader at the Reader Store. When I connect my USB cord to the computer the only thing appearing on the screen of my Reader is "Charging Battery"...
you have to download the software so it reads everything of the phone if the phone came with a cd thats the software try installing it and it will work
Mar 16, 2011 | Sony PRS650
Color is messed up...very green looking screen, appears red colors appear green
Do you have extra hardware connected to the TV? If so, it could be a problem with the cable/connections.
Mar 07, 2011 | Proview Hx263 26 in. HD-Ready LCD...
The pages print off and are fine on one side but on the other side it's a double copy - as if it's printing over itself.
Try this:
Please close all applications before running the Repair MFL-Pro Suite.
1. Turn off and unplug the machine from the AC outlet and disconnect it from your computer, if you already connected an interface cable.
2. Turn on your computer. (For Windows 2000 Professional/XP, you must be logged on with Administrator rights.)
*Note: On Windows 2000 and XP systems, you can check to see whether youhave administrator rights by right-clicking on the "Start" button. If you see the text "Explore All Users", you have administrator rights. If you do not see this text, you do not have administrator rights. Try to log on to the computer using a different user name, or computer manufacture for support; if your computer belong to a network You will need to contact your network administrator to give you permission to install the software
3. Insert the supplied CD-ROM for Windows into your CD-ROM drive. If thelanguage screen appears, select your language. If you are not promptedwith the language screen, go to My computer, then double click on the MFL_Pro icon.
4. The CD-ROM main menu will appear. Click on REPAIR MFL-PRO SUITE.
5. Click YES, when prompt the software to turn off machine and disconnect parallel/usb connection.
6. When the Brother MFL-Pro Suite Software License Agreement window appears, read the agreement, then click YES if you agree to its terms.
7. Select LOCAL CONNECTION, and then click NEXT. The installation will continue.
7a. For some models, you will be prompt to select USB or Parallel connection following step 7. Please select the cable connection you areusing, then click next.
8. When prompted to #Connect the Machine#, connect the USB or Parallel cable to your PC, and then connect it to the machine. (DO NOT connect the machine to a USB port on a keyboard or a non-powered USB hub. For Parallel connection, please use cable 6 feet or shorter. Brother recommends that you connect the machine directly to your computer.)
9. Plug in the power cord and turn on the machine. It will take a few seconds for the installation screen to appear. The installation of the Brother drivers will automatically start. The Found new hardware wizard windows will appear one after another. Please DO NOT try to cancel or click on any options for the Found New Hardware Wizard. Just wait and the installation program will make the necessary selection for you.
10. When the On-Line Registration screen is displayed, click Brother Registration to register your device with Brother. You can also click onScanSoft Registration to register the ScanSoft Paperport software. If you have previously registered with Brother or Scansoft, click Next.
11. Click FINISH to restart your computer.
The MFL-Pro Suite, Brother Printer driver and Scanner driver have been reinstalled and the installation is now complete.
Oct 31, 2010 | Brother MFC 210C All-In-One InkJet Printer
My proview 558 monitor has a 1/2 inch black line at the bottom
ms_biguns, You need to test one or the other, The tower should output and drive a substitute known good monitor, or a known good pc should be able to display the WIN-desktop screen on your Proview 558. Could it also be that the software in pc not set up for driving a Proview558? 12fixlouie
Feb 28, 2010 | Proview Computers & Internet
Can you use the aiptek mega cam like a web cam?
Yes you can. Here's what worked for me.
First disconnect your camera.
Software
Uninstall your existing software.
Download new software from http://www.goaiptek.com/drivers/driverfiles/minixp_1.5.zip Unzip.
Install the new software but DO NOT CONNECT THE CAMERA UNTIL INSTALLATION IS COMPLETE.
Camera
Remove any batteries.
Set switch to 'On'
Set Mode to Video
When software installation is complete, plug in camera to PC with USB cable supplied.
Run installed program on PC. The Mega camera screen will appear. Click on 'Live'. Your camera picture should appear on the screen.
Oct 06, 2009 | Aiptek Mini PenCam Digital Camera
My computer wont load windows a problem has been detected and windows has been shut down to prevent damage to your computer. unmountable boot volume if this is the first time you seen this stop error...
Your Operating System probably corrupted due to unexpected power failure or any other reason. You may have to setup widows again.
Before reinstallation take backup of all necessary file in a separate Hard Disk from your (C: ) Drive , existing desktop , my documents , share folder, etc. to do this you have to connect you Hard Disk with another workable PC.
After taking all necessary backup, setup Windows freshly and it is recommended to format C drive during fresh setup.
Jul 12, 2009 | Averatec Laptop Keyboard for 3200 Series
When I hook up my Little Shots Camera it says can not connect to device
Uninstall all old pc cam,mars software and do a fresh installation. Restart computer.Before plugging in usb cable,push the shutter button down and hold it.Shutter is the button that takes the pictures. Now plug in usb cable. Camera should say pc cam and installation of software should start and complete. If asked about newer reference files answer yes. Software should now be installed. To use as pc cam,Dbl Click pc cam,mars icon on the desktop.New screen will appear.click on right facing triangle and another screen will open. Camera will now show on monitor what it is aimed at.To shut off,close all screens,and click on icon tray and shut usb device if necessary. To use as camera and view pictures,connect usb cable without pushing any buttons,and camera will say usb,Dbl click my computer,dbl click removable disk D,E F whichever it has been assigned,dbl click DCIM folder,and there are your pics to do waht you want with,save,print etc.Do not delete pics using the computer,delete only by camera so you do not damage files necessary to store and take pictures.If you do camera may have to be reformatted.Disconnect from pc same way by clicking usb icon in tray and stopping device,then its safe to unplug cable.
Dec 26, 2008 | Blue Microphones Blue Hat Little Shots...
30Gb White Video PA44F B/A
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore…
www.apple.com/support/ipod/five_rs/
Apr 09, 2008 | Apple iPod MA446LL/A MP3 Player
Proview PL482S 14 in. Flat Panel LCD Monitor Logo
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Frank Russell
Frank Russell
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
