Question about Husqvarna 450 e-series 18" Chain Saw
What is the round ring in the clutch cover called in a husqvarna 450 chainsaw
  • Husqvarna Master
  • 2,239 Answers
The brake band.
Posted on Jan 14, 2011
Sprocket won't turn. Engine runs OK. This is not a clutch brake problem
could it be the second handle (BRAKE) is still on .push forward on the front handle , that unlocks it
Nov 22, 2015 | Husqvarna Model 450 Chainsaw 50Cc With 18"...
Husqvarna 450 e chainsaw chain tension wheel doesn't lock and the cover comes off during use
The adjustment handle snaps down to lock. If the handle is coming loose, I recommend replacing the handle. You can also go to standard bar bolt set up if you prefer. Check with your Husqvarna dealer for part numbers.
Apr 22, 2014 | Husqvarna 450 e-series 18" Chain Saw
How do I "reset" the brake?
If the chain brake is on and the sprocket cover is off the saw, they are a pain. You need to grip the clutch housing while turning backwards the tri-star \'cog\' in the inside of the sprocket cover. Ive done it in the past by holding it in place over the chain brake handle so the cog\'s line up and pulling the handle back in the off position. Failing that you might be successful using a pair of 90 degree circlip pliers.
Jul 01, 2013 | Husqvarna 450 e-series 18" Chain Saw
I cannot get the clutch cover off my husqvarna 455
Before the cover will come off you need to slacken the chain and make sure the chainbrake is off, to do this pull the hand guard fully back to the top handle, it should click and settle back into the central position, the brake/cover should then come off
Nov 24, 2012 | Husqvarna Garden
Husqvarna chainsaw 450 oil leak
The 450 has a very simple non adjustable pump, it sits through a black rubber pick up/delivery pipe, they are quite prone to leaking where the pipe sits up against the crankcase, the part no. of the pipe is 544084201, changing this will help, you can also try using instant gasket to seal it, you will need to remove the clutch , sprocket, and pump plate to get acsess to it.
Oct 19, 2012 | Husqvarna 450 e-series 18" Chain Saw
Husqvarna 450 chainsaw used about 1 hour out of the box cutting fine then the blade stops. hard to get clutch cover off and now cant get it back on
Sounds like the brake has come on, grab the hand guard and pull it firmly right back to the top handle, this should load the brake.
Sep 18, 2011 | Husqvarna Garden
Chain will not rotate; which part needs to be replaced?
Try to turn the chain by hand--if moves freely, the clutch assembly under the cover may be overly oiled. Remove the bar and chain, then wash the clutch drum and shoes with carburetor spray cleaner. Make sure the chain brake is not set. Hope this helps!
Sep 13, 2010 | Husqvarna 450 e-series 18" Chain Saw
Take the chain off a 450 husqvarna
Pages 17 & 18 should help answer your question.
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2008/HOUS2008_1151081-96.pdf (This may not be your saw)
Loosen the tension adjuster, remove the clutch cover, (engine to left) pull the bar off the adjustment pin then push it left against the clutch cover bolt. Remove the chain from the chain groove, remove the bar, the chain can now be removed.
You can download the correct Operator's Manual and IPL here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
HTH
Lou
Dec 16, 2009 | Husqvarna 450 e-series 18" Chain Saw
Clutch cover wont go back on
the easiest way i have found to put the cover back on is to take the clutch drum off.now youn can put the cover on.reset the brake and reinstall the clutch drum.the brake loop gets in the way any other way.hope this helped,if not let me know and we can try something different.......
May 10, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna 450 e-series 18" Chain Saw Logo
102 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
