Question about GE Spacemaker JVM1640SJ Microwave Oven
Hello, I have a "above the oven" GE microwave Model J VM1 50 001 made in 1986. A couple years ago it just "died" no power. A few months later it started working fine. Now it just died again! Is there some type of "fuse" somewhere within the unit that may need replacing. Looking for SUGGESTIONS !!! Thank you Gary Stockford stockfordg@cox.net
    Genius:
  • 1,035 Answers
Hi. There might be somthing wrong wit the fuse or power control module. You may refer to this link for all available parts for your Microwave oven.
All the best!
Posted on Oct 04, 2010
Sear Advantium 120
Disconnect it and connect bac to power. check the fuse. If nothing works is either the fuse, the cable or the power supply unit.
Apr 03, 2008 | GE Advantium 120 Convection/Microwave Oven
If I had a GE model# JVM1650WH02 and want to switch to Model# JVM1750DPWW. Do the hole match on top when I am mounting to the cabinet above the oven?
I had a GE JVM1651WB 005 from 2001 that died a few days ago. I replaced it with GE JVM1750DPWW today. The 3 old holes from the cabinet to the microwave fit perfectly, so did the old mounting bracket. I only had to make a hole for the plug and chord in the cabinet because the location changed by a few inches diagonally compared to the old one.
Dec 20, 2010 | Microwave Ovens
Panasonic Counter top Microwave model # NNT695SF Often when I push the start button, the microwave will go for a few seconds and then cut out. I then open the door and then shut the door and push the...
Issue with your Main Panel Power Fail to innitiate ..Du to Component mal-functioning inside the unit ...Possibility Magnetron defect, Or main Transformer Over heat, Also check for safety swich on the door for bad connection...
Sep 30, 2010 | Panasonic NN-T695SF Microwave Oven
We received a Ge spacemaker microwave oven as a
When a microwave makes a notable HUM there are 3 things thant can cause that dreaded hum.
1. Most common failure is the diode
2. Shorted capacitor
3. The Magnetron
If you list a model number I can probably find your parts for you and pass along a couple of trouble shooting tips if your good with a meter.
Kelly
Mar 04, 2010 | Microwave Ovens
Hotpoint GE Household Microwave
Well, I think you should get a brand new one.
They do not cost as much to replace these days and it might be safer.
May 11, 2017 | GE Microwave Ovens
I have a GE Spacemaker model #JVM1650CH01 that keeps on shutting off everything after a few seconds. I have to rest the clock and month -year - date to try again.
my spacemaker xl jvm 1650 microwave shuts down after just a few minutes of operation and after a few minutes needs to have a clock/time/day etc reset. is this reparable by a homeowner?
Oct 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1650 Microwave Making Loud Noise
hello Frank. Sorry to tell you that the magnetron is going bad and making that terrible noise. Since the inside of a microwave, even unplugged has up to 2000 residual and deadly volts of electricity I recommend either calling a pro or replacing the unit.
Jul 12, 2009 | Microwave Ovens
One surface light bulb on GE Profile microwave keeps burning out
I have the same problem. The left one burns out within a couple of hours use, the other one lasts a couple of months and is then gone. This pattern has repeated over 8 years. I replace them every now and then and then just go without until I get the urge again to fix it. Maybe smaller lower wattage lamps are worth trying...
Jun 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Crackling sound in microwave vent when power is off
By "powered off" can I assume you mean that it is plugged in and at idle, not cooking, just showing the clock?
If so, I'd say your control board is failing.
If my assumption is wrong, please write back with more details.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Nov 02, 2008 | GE JEM25 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
89 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
