Question about Saniflo Saniplus - Two Piece Elongated Elongated Bowl with Macerating Pump
We have a Saniflo 2 and the motor randomly starts without flushing, it is prone to getting blocked. How can we stop these problems with our Saniflo.
danhawke
  • 4 Answers
SOURCE: Saniflo works in short burst when not flushed eg in night
Sound to me that the toilet is over filling and in doing so water will over flow down the pan. This is definately what I would check first!
Posted on Jan 27, 2009
SOURCE: My saniflo toilet wont flush
You need a new capacator. The motor is trying to run but does not have enough electricty to get the motor up to full speed.
Posted on Apr 26, 2009
  • 82 Answers
SOURCE: NOISY SANIFLO
Always an issue, guessing it is on a tiled floor? or up against a tiled wall?
I put some thin foam / Bubble wrap underneath and behind mine to dampen the vibrations. It also helps if you box the unit in and use foam to quieten the noise (on top and around the unit). Depending upon how long you have had it, it may also need a clean out or possibly even the motor bearings are getting a bit worn, creating some noise with the excess movement.
Good Luck
Posted on Jan 17, 2010
  • 115 Answers
SOURCE: The saniflo keeps cutting in even when not flushed
Water pressure makes the unit kick on and off. It will turn on by itself if water is somehow draining back into the pump. It could be water leaking from the toilet tank into the bowl and from the bowl to the pump or the flapper on the check valve inside the discharge elbow may be stuck open or could be defective and allowing waste water to drain back into the pump, once it builds up enough water pressure inside the pump, the unit will kick on and off by itself.
Posted on Jul 27, 2010
vetteman3002
  • 2299 Answers
SOURCE: I have a problem with a newly fitted saniflo that
You are right. With all of the energy saving plans going they think that the pump should not run every flush. That is why it is taking 3 flushes to turn on the pump.
Posted on Oct 26, 2010
I have had a saniflo operating fine behind my ensuite toilet for 2 years. The saniflo drains into the waste pipe after the AAV and before the bathroom sink. Recently when we flush the toilet and the...
may need a backflow preventer in the waste line under the sink..it is basically a ball on a spring..designed to make the water go only one way..I am guessing the wasteline was opened up with a plumbing snake..that pump may have too much backpressure from the head line..
Jan 25, 2014 | Plumbing
Saniflo compact part flushes when being used
Of course you should , the MAKER should make it right
May 22, 2017 | Home
Sanicompact motor operates continuously but bowl doesn't clear. Have emptied bowl manually and poured Saniflo cleaner in.
This problem occurs when the flush button is damp after cleaning the whole toilet with a shower. Solution: Wait till it dries up 2) if you have installed a main switch put it on and at the same time press the flush button.
Dec 26, 2010 | Elite Saniflo SaniCompact- SaniCompact One...
My Saniflo sanicompact does not flush away, when i press the flush botton it does not work, the toilet buzzes all the time. when the water gets to a level it use to pump away but has stoped doing this.
saniflo buzzing all the time means that the motor is trying to run but cannot. indicates that something is blocking the pump impeller from rotating. unit needs to be removed, cleared and tested. if fault contiues you may blow the fuse (if you are lucky) otherwise the motor will eventually burn out. get this checked soon.
Apr 12, 2010 | Saniflo Sanicompact Elite - One Piece...
Running continually won't stop.
indicates a partially blocked system. Try cleaning and descaling first before getting into any mechanical solutions - note 80% of all saniflo problems are to do with dirty / blocked sytems and nothing to do with the mechanics / electronics. Saniflo actually sell saniflo cleaner - but like most plumbing systems - on going maintenance tends to get overlooked until a problem arises.
Nov 17, 2009 | Saniflo & Saniplus& Macerator Pump
Helicopter starting :)
could be the thermal trip on the motor. Suggest you remove the lid and clean out any buildups inside. check for for a jam,around the blades like a tampon. Careful - they are very sharp!
Oct 01, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
My saniflow toilet is blocked and a plumber has told me i need a new motor. where can i get this and how much are they?
If you hear it making noise the motor isnt blown, but it could be clogged.
A quick an easy fix is by filling a 5 gallon bucket with hot water (or warm water) and slowly pouring it into the bowl. The warm water breaks the particles up further, and will help flush the unit out. Make sure you run the water alot after its cleared out (to flush the debris). You can do that by turning on the shower or sink (if connected). If you dont have a shower or sink just keep flushing the toilet.
Sep 03, 2009 | Saniflo Sanicompact 48 Toilet With Pump,...
System not flushing and motor cut out.
Motor may have been jammed and notw burned out.
May 29, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
My saniflow saniplus has stopped pumping water i think- the toilet and bath has filled up with waste water. i have taken the top off the saniflo and blades are working fine but they keep going because the...
We had that problem but the unit was built in and I could not get at it, the outlet pipe sounds like it is blocked, I cleared mine by connecting a pipe from the cold tap to the outlet pipe and flushing.
May 11, 2009 | Saniflo & Saniplus& Macerator Pump
I think a small plastic item has dropped into my saniflo toilet it keeps maing a loud noise evey few minutes. hat should I do
Nov 15, 2008 | Saniflo SaniPlus-Round SaniPlus Macerator...
Saniflo Saniplus - Two Piece Elongated Elongated Bowl with Macerating Pump Logo
128 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
