Question about Frigidaire FRS26H5AS Side by Side Refrigerator
Why is water dripping from bottom, near hinge on fridge side? The drip pan is bone dry.
  • Frigidaire Master
  • 1,606 Answers
Due to it being on the refrig side , it sounds like the water resevoir behind the lower crispers , has a hole it it . Remove the crispers and activate the water ,( with the refrig door open ) and look for leak . If so , the tank is easily replaceable .
Posted on Oct 05, 2010
    Sergeant:
    Champion:
  • 351 Answers
Drain stopped up
Posted on Oct 04, 2010
I have a maytag side by side refrigerater psd265LGES fruit flies coming out of ice machine/water dispenser.I scrubbed the whole fridge,yet still have them.Is there a drip pan on this fridge.
I would lift up the drip tray and clean that out making sure nothing is under it. If it is coming from the dispenser then there is no reason to check under the fridge unless you think something is under there like grapes or berries.
Jan 31, 2018 | Maytag Refrigerators
Drip pan
The drip pan is located behind the toe panel (grille) at the bottom. The pan should be located in the left side. If you have auto defrost, the pan may or may not have water in it. It is likely to have accumulated grunge which can be removed by a good wash and rinse, being careful to avoid breaking the pan during cleaning. Reinstallation is the reverse of removal.
Sep 12, 2012 | Maytag MZD2766GES Side by Side...
My whirlpool French door fridge is leaking all over the floor. The drip pan underneath is bone dry. I can't find the drain hole inside the fridge to see if it is clogged. Is letting it thaw for tw
there is a water tube connection at the bottom of door on hinge side that has a spring and allows it to swing with door. it also has a fitting there so the door can be removed.it is the tube running inside the door to the ice water dispenser. if it has one, it can leak at the fiting
Jul 07, 2012 | Whirlpool GX5FHDXVY Stainless Steel (248...
My Hotpoint refrigerator drips water some times alittle and some times a lot I'm not sure where it comes from I have cleaned the rubber seal and made sure there is nothing keeping the freezer side from...
In most refrigerators there is a drip pan underneath that captures condensation and allows it to evaporate. Possibly your drip pan is missing or improperly installed so that the condensation is dripping onto the floor. Check your manual, or find one online. Usually you just have to remove the grill from the bottom of the fridge to get access to the drip pan.
Nov 19, 2017 | Hotpoint HSH22IFT Side by Side...
Drip pan is full and overflowing onto floor
If the temperture behind the compressor is not so hot the water will not evaperate. the heat from the compressor dry out the water.
Jan 03, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Trickling water noise coming from the bottom of the fridge.
It may be nothing to be concerned about. The water produced during the defrost cycle drains into a pan at the bottom of the refrigerator. This water is then evaporated by heat from the refrigerant coils.
You may be hearing this water dripping into the pan from the tubing that carries it from the inside of the refrigerator.
Oct 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Dripping water inside fridge. Can't find drain hose
at the rear of the fridge unit there is a hole, normally at the bottom of a shallow "v" shape. there should be a plastic insert in it to clear any blockages, just wiggle it a bit. failing that a pipe cleaner will do the same.
May 02, 2009 | Refrigerators
Drip tray full of water, don't know how to get it out to dump
How to remove drain pan on a kitchenAid side by side with water filter .
Nov 11, 2008 | KitchenAid Superba Architect KSCS25INSS...
Water leaking onto floor from refrigerator/freezer
The defrost drain is stopped up. Without taking anything apart, the easiest way to clear the drain is to blow compressed air through the drain tube which is at the back of the Fridge. You'll see it..... it drains water into the drip pan. Hope this helps !
Oct 09, 2017 | Refrigerators
Fridge is leaking water all over the place.
The defrost drain opening or drain hose is plugged up with ice or crud. If the drip pan is bone dry, it's a sure sign that the drain opening or drain hose is clogged. Trace the drain hose back to see where it pick up the condensate in the refrigerator cabinet. Remove whatever pieces you need to to clean that sucker out. Door gaskets are torn or not making good contact with the cabinet. No? Well then where's all that water coming from, Einstein? It can only come from the humidity in the outside air--your fridge can't make water, dontcha know
May 10, 2006 | Maytag MBF2256H Bottom Freezer...
Frigidaire FRS26H5AS Side by Side Refrigerator Logo
165 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
