Question about Sony Reader Touch PRS-600
My sony reader touch edition will not turn on. the screen is a bunch of black lines and it looks as if it is broken, when i try and turn the power button on i get a blinking yellow-orangish light. also, the reset button doesnt seem to be fixing the problem.. please help!
Mine did the same thing.
I pressed the reset twice for 15 secs on the second time the light stopped flickering then I put it on charge for 2 hrs it works fine now.
Posted on Oct 07, 2010
  • playtimeplus Oct 27, 2010
    my sony reader touch edition will not turn on. the screen is a bunch of black lines and it looks as if it is broken, when i try and turn the power button on i get a blinking yellow-orangish light. also, the reset button doesnt seem to be fixing the problem.. please help!
    My reader is doing the same thing and reset is not working and I have charged it for 24 hours and still nada! Has anyone figured out how to fix this yet or is it done? I have had my touch for a little over a month and treat it like gold. It was an upgrade for me and I'm starting to think that the touch screen is a problem in this model. Help anyone
Prs 600 ereader screen contrast problem
The PRS-300 "Pocket Edition" ereader is a device that did provide a far better than ... I bought the Sony Reader Pocket Edition to use for my public library's downloads. ... Conservatively, I probably read upwards of 20 hours each week, both ..... Well lets just say it only seems like there are a few words on the screen at a time. ...
Jan 03, 2012 | Sony Reader Touch PRS-600
When i turn the page on the sony ready touch I can still see the last page under the next page. Has this happened to anyone else?
Hi patsyhodgins!
At certain point this "goshting" you see its normal operation because of the type of screen (E-Ink) but if you get words mixed or its too difficul to read, you can try a reset:
Note: This will not affect your ebooks:
1. Disconnect the reader from the computer
2. Power off you reader
3. Hit the reset at the bottom for 3 seconds
4. Power on you reader
5. The screen will blink and will display "Opening Book", let the reader load your books
See if the problem persist, if so, you can try a hard reset, make sure the reader is fully charged.
Note: This will delete all content from you reader, I recommend you to back uo your data before proceed:
1. Power off the Reader.
2. Press the RESET button.
3. Power ON the Reader.
4. When the screen shows "Opening book..." , press and hold at the same time the "Page Back" button and the Volume + at the bottom until the "Reset All" appears on the screen
If none of the steps above work, then contact Sony to get the screen repaired.
GoodLuck!
eBookBoy
http://digialreader.freeforums.org
Jul 17, 2011 | Sony Reader Touch PRS-600
Reader suddenly went beserk, lots of activity as though I were pushing buttons to change pages, etc. and then it stopped working properly; some part of the screen shows correctly while most of screen is...
separtdifge3,
Probably a charge issue, try this:
1. Connect the reader to the computer for 15 minutes (make sure there is a red steady light)
2. Disconnect the reader and press the reset at the bottom
3. slide the power switch to turn it on
4. If the problem persist you will need to do a hard reset
5. If after a hard reset the issue is not resolve problably you will need to contact sony to get it repaires =(
eBookBoy
Jul 01, 2011 | Sony Reader Touch PRS-600
How do i get rid of the horizontal and vertical lines on a sony prs 600? the unit was never dropped or mishandled. they actaull appeared as i was reading my book on it
Hi mdill9759,
Looks like a problem with the screen itself. Try this to see fi you can get issue resolved, good luck:
1. Hit the "Reset" button at the bottom of the reader
2. Slide the power switch, at this point the screen should blink and show "Opening book"
3. Allow the reader to load and see if the lines still appear on the screen
If the lines are still on the screen, contact Sony to get it repaired.
eBookBoy
Jun 12, 2011 | Sony Reader Touch PRS-600
Hi, my sony e-reader while turned off or on appears to have what looks like white horizontal lines across the top of the screen which prevents me from viewing any text at the top of the screen.
Without seeing it exactly, it sounds like it could be one of two issues:
  1. You should try charging and resetting your ereader. Please be sure to save everything, as your system will go back to its original default settings.
  2. If option 1 does not work, it sounds like you may have damaged the internal "ink" - this typically happens by dropping the ereader. If this is the case, unfortunately the damage is permanent by can be fixed by a professional or via Sony.
Feb 09, 2011 | Sony Reader Touch PRS-600
My daughter purchased a Sony Reader Touch Edition (PRS-600) some time ago and used it for a while then gave it to me. I tried to use it myself but when I attempted to download a book that I had purchased...
Remove the reader software from your computer first. Then reinstall the eReader software, the sync the eReader to the program while in the Sony store window; set up an account for just you via the Sony store and start spending money... enjoy!!
Jan 07, 2011 | Sony Reader Touch PRS-600
How do I download music to my sony reader prs 650
Personally, I find the Digital Library interface for Sony is slow, cumbersome and irritating.
I found the quickest and easiest way to get files on to the e-reader is to load any files you want to use on to a SD flash memory card on your PC. Then, make sure your e-reader is totally switched off, not just in "Sleep" mode. To do this slide the "Off" switch over and hold it for 2-3 seconds and confirm "Yes" when asked. Then insert the SD card in the e-reader. When you power up the reader again you will find the files show up in menu system of the reader.
Oct 26, 2010 | Sony Digital Reader Touch Edition
My Sony reader prs-600 is frozen. The reset button doesn't do anything. How do I unfreeze it? A part of my screen still works, but a big part doesn't. What can i do?
Try holding the reset for 5-10 seconds, then flip the power switch quickly, three times. If this doesn't work, check the light next to the power switch. If it is flashing yellow, follow the same process. It might take up to three tries.
Jul 21, 2010 | Sony Reader Touch PRS-600
Can i fix broken screen on sony prs700 ebook reader
That depends on your definition of repair. If your screen is not operating properly, for instance the touch screen is not working correctly. It may be possible to repair it.
If your screen is damaged from some type of impact and is cracked the screen then no. The only option is to replace the screen. In the past Sony has used a swap to deal with repair issues in regards to small electronics so your best bet is to get in touch with Sony support about this.
Since I do not know the exact nature of your problem I can only assume what kind of damage you have. However if the screen is not damaged directly but it's just not operating correctly I will add this.
There have been issues relating to the readability of the screen that seem to relate to the touch activation feature. It's been reported that because of the type of touch mechanism and the lighting feature used, it causes the words to look fuzzy.
Although I'm not sure how well this works some people have used another product with the e-book called the "Light Wedge".
I have included some links. The first is call "MobileRead.com".
It a forum dedicated to readers such as yours. They have a lot of information that you might find helpful. The other link is for Sony Ebook support.
I hope something here helps and good luck.
http://www.mobileread.com
http://esupport.sony.com/US/perl/select-system.pl?PRODTYPE=74&NAVDISP=portaud
Nov 23, 2009 | Sony E-reader Portable E-book MP3 Player
Sony Reader Touch PRS-600 Logo
1,030 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
