Question about Indesit W 123 Front Load Washer
Indesit WIX L123, all lights flashing continuous like a disco ca it be repaired or is it dead!
My machine starts to fill and then stops. It flashes 7 times. What is this error?
What is the Brand and model of your washer ?
Is it Indent ?
Many basic UK Indesit washing machines fitted with a rotary dial indicate error codes by clicking the dial continuously round and flashing the door lock light a set number of times.
If the door light (LED) flashes 7 times it means, "Heater relay stuck - check connections on heater and module (PCB)".
In my experience, this fault code usually required a replacement PCB and EEProm. A connection fault on the heater usually results in the entire washing machine going dead. Nothing will work, but the LEDs light up. This symptom can also be caused by an open circuit motor or other faults.
It's always possible for a connection fault to cause error codes but the heater relay is embedded in the PCB and if it develops a fault the whole board needs replacing. I don't recommend replacing the PCB as a DIY repair. It is an expensive part and it will not be guaranteed unless fitted by an engineer. New PCBs do not come with the micro-chip EEPROM which would also need fitting. Replacing the PCB and EEPROM yourself is risky. If the fault is not cured you cannot send the parts back.
If you have an engineer to replace the PCB and EEPROM I would imagine the cost is likely to easily be over £100. If your washing machine has a 5 year parts guarantee Indesit would supply the PCB free of charge but only if their own engineer fits it at a cost of about £90.
If you are really keen to fix this yourself and want to try another PCB there is a company that might be able to help and are happy to deal with the public called Quality Electronic Repairs (see link below)
Mar 07, 2016 | Washing Machines
When I on the machine LG WF-F5700PCX ,all the lights are blinking. water is not flowing in.
Washing machine all the lights flashing, error codes on ...
www.how-to-repair.com/.../washing-machine-with-all-the-lights-flashing...
Oct 25, 2014 - In this video I'll be showing how to fix a washing machine with all the lights flashing and how to identify error codes or fault codes on Hotpoint, ...
Washing machine lights flashing - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - Flashing lights Many modern washing machines display error codes if they detect a fault, but they don't all display a readable error code.
Flashing Lights on Washing Machine How to Repair ...
? 8:05
https://www.youtube.com/watch?v=P6WZNLO6wE4
Oct 22, 2014 - Uploaded by how-2-repair.com
Flashing Lights on Washing Machine How to Repair Hotpoint, Ariston, ... flashing like this.error faults are available at our website for all makes.
Indesit Washing Machine Repair: Flickering Or Flashing Lights
? 4:36
https://www.youtube.com/watch?v=S1L2N7srXKs
Mar 27, 2014 - Uploaded by DextersLab2013
Indesit Washing Machine Repair: Flickering Or Flashing Lights... Since making this video i have had to replace all of the remaining capacitors ...
Jan 11, 2016 | Washing Machines
Anyone now the fault light codes for this model---thank you
Flashing Lights & Error/Fault code - Repair
Oct 25, 2014 - Now there may be some variances for older models, but there are 3 main types of board listed ... Tagged under: Ariston, Creda, error codes, flashinglights, Hotpoint, Indesit ... And can someone please enlighten me, thank you.
Identifying Hotpoint or Indesit Error Codes - YouTube
? 6:46
https://www.youtube.com/watch?v=aud14I0Zu9M
Aug 29, 2014 - Uploaded by eSpares
If your machine is stopping with flashing lights or a error code on the ... Lights on Washing Machine How to Repair Hotpoint,Ariston, Indesit ...
Dec 15, 2015 | Hotpoint Ariston Aquarius WD420 Front Load...
Blinking lights
? 8:05
http://www.how-to-repair.com We are working on a tvm570 but this is usually the fault with most boards ...
? 4:36
In this video i remove the Computime control board on an Indesit WIXL163S washing machine where the front ...
Dec 02, 2015 | Washing Machines
Indesit Washing Machine lWB5113 Flashing Lights(Faulty ...
? 3:34
www.youtube.com/watch?v=-lnfePzPwTQ
Jul 29, 2012 - Uploaded by porracaralho caralho
Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
How to repair Indesit washing machine that is Flashing ...
? 0:43
www.youtube.com/watch?v=Q9Yq2Cz8UFE
Jun 26, 2011 - Uploaded by XR600RQJ
Washing machine Indesit starts to flash for longer and longer ...How do you unlock the door when the power is off?? every time i turn it ... My washing maschine ( Indesit WITXL 129 ) had the same problem - 6 from 9 LED lights ..
Oct 14, 2015 | Kenmore 24032\24036 Top Load Washer
Power indicator and rpm indicator flashes
See:
? 3:34
Jul 29, 2012 - Uploaded by porracaralho caralho Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
? 0:43
Oct 14, 2015 | Washing Machines
Flashing lights
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
Aug 22, 2012 | Indesit Washing Machines
Indesit W1A 111 front load W/M
hiya
no need to worry they do this.
hope this helps
please dont forget to rate the helpfulness. thanks kj
Jul 20, 2008 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
340 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
