No internet connection, a network cable is unpluged
  • 249 Answers
Check the cable. Try to reseat the cable. Try to reverse the cable. If it still does not work. Go to control panel and check for any symbols like a question mark or exclamation point in the device manager. reinstall needed drivers.
Posted on Oct 04, 2010
    Scholar:
  • 88 Answers
Check the cables - may be cable is not plugged in properly or cable is bad or else the DHCP device (modem or router )is turned off .
Also check in device manager (RIGHT CLICK ON MY COMPUTER - PROPERTIES - HARDWARE TAB - DEVICE MANAGER , CHECK IN NETWORK ADAPTER 10-100 ETHERNET STATUS ) should be enabled
if everything is fine then reduce the link speed - same process but double click on 10/100 Ethernet - click on advance tab - change the value to speed and duplex and set it to 10 mbps half duplex and click ok - close everything 30 secs it should change the status .
try with the very first one with cables first please .
Hiro h50015 nic on windows 7 says network cable unplugged when cable is clearly plugged in
To connect to the internet, you must have a device like a modem or a router. Is your PC connected to this device? Do you have other PCs or networked devices on your LAN? Can you reach them with ping?
To make it easier to help, you should give information how your network looks! e.g.
internet ---- cisco800 router --- d-Link switch ---- myPC
or something like that. Otherwise it is fooling around in the dark.
Apr 13, 2014 | Hiro H50015 Network Adapter
There is no internet connection to the laptop. The arris modem gives internet acess to the PC computer, though. The manual for the Airlink 101 router says to connect the router and MODEM to each other by a...
What you're missing is that ALL the PCs will be connecting THROUGH the router to the Modem. Unplug the PC network Cable from the modem, then plug a network cable from the router's INTERNET port into the modem (where you removed the PC's network cable). Now, plug the PC's network cable into one of the ports on the router (usually 4 or more, marked 1,2,3,4. Think of a Router as a "splitter". It connects to the Modem, then several devices connect to the Router, some of them by wire and some by Wi-Fi. So your desktop PC is connected by wire to the router and your laptop PC is probably connected by Wi-Fi (wire is an option, as well). The Router sorts out all those signals and communicates with the Modem. Sound reasonable?
May 02, 2017 | Arris Comcast Touchstone Telephony VOIP...
I installed the Asus mini Bluetooth USB - BT211 and I see the icon Local Area Connection - A network cable is unplugged . When I go to the Bluetooth Suit and click on the configuration task that IE fails...
bluetooth does not connect to the internet, it connects to other bluetooth devices such as bluetooth mobile phones.
the network cable shows unplugged if there is no cable plugged into it and going into your internet router
Apr 09, 2011 | ASUS USB-BT211 Mini Bluetooth Dongle -...
2004 Emachine- when desktop comes up on lower right there's a flashing icon when clicked on says "Network Connections", Local Area Connection, Network Cable Unplugged, Intel{R} PRO/100 VE...
If the local area connection icon specifies as network cable unplugged, then the computer has not sensed the connection between the computer to the cable modem / DSL modem, please reseat the cable behind the cable / dsl modem to the computer. If the icon still shows unplugged, then change the network cable between the two.
If the issue still persists, please revert with more details lik the kind of internet connection used and the reason for reinstalling.
Jan 04, 2011 | E-Machines eMachines Desktop PC
Internet explorer cannot display the webpage
That error means the network cable that runs from the modem or network hub is unplugged from your network or lan card on the back of your machine. If you need further help please repost with the type of internet connection you have (dial up, network, or cable, satelite etc..)
Feb 14, 2010 | eMachines ET1161-05 PC Desktop
Its always show at the the monitor the " A network cable is unplugged".
If you are connecting to the Internet using a wireless connection and your LAN card in the computer does not have a LAN cable connecting it to a hub or router then you will get a message "A network cable is unplugged".
If you don't use a wireless connection and you only connect to the your network/Internet then the problem is either the LAN cable has come loose in the computer's LAN card or at the router or the LAN cable is faulty.
Nov 17, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
This message " A network connection is unplugged" comes when the connection unavailable may be due to faulty connection. Chek that your router is rightly plugged and the sockets are dust-free. If problem persists, contact support.
Aug 14, 2009 | D-Link Computers & Internet
HP laptop shows full internet signal, wont let me connect
First, the "Network Cable Is Unplugged" - don't worry about that. That is just informing you that your WIRED connection is unplugged, which is fine because you are using wireless.
Now the actual issue of no internet...first try by unplugging your internet modem for 20 seconds, and plugging it back in. Next do the same with your wireless router. At this point your computer will disconnect form the wireless network and you may need to reconnect it. After the reconnect see if you still have the same issue, but chances are it should be fixed :-)
If that does not work let me know and we can further troubleshoot the issue!
Apr 23, 2009 | Teac USB2 TV TUNER (USB2TVTUNER) Video...
My computer (Dell) unknow Network Card
i) Click on Start button ---->Select option Control Panel------>Select Network Connections----->
  a new window appears showing the "internet connections icon " Such as:
  Local Area Connection 1 or 2 or 3 and since you are not connected it will show this icon as:
eg1: Local Area Connection 1 or 2 or 3
  Network Cable Unplugged, Firewalled
  VIA compatible Fast Ethernet
  in this case u can download VIA network drivers....from internet..
  or
  eg2: Local Area Connection 1 or 2 or 3
  Realtek RTL8139 Family Fast Ethernet NIC
  in this u can download "Realtek RTL8139" network drivers.... from internet(which is showing model     no: RTL8139 through google search engine )
        (OR)
ii) Click Start button ---->Select RUN option ----> type in the text box devmgmt.msc --->Select               Network Adapters....
    but this will show wheter ur network adapter or NIC is VIA or Realtek or......but doesnt show the           correct Model NO: of VIA or Realtek....
    so i would suggest to follow the step (i)
Thanking you
M.Sridhar
Dec 25, 2008 | Dell Ethernet Card Network Adapter
Computers & Internet Logo
David Payne
David Payne
