Question about Refrigerators
Do I have to worry about frost build up on any new home compact refrigerator thats operating correctly?
    President:
  • 670 Answers
Normally compact refrigerators are not frost free and will need to defrosted periodically. This can be done by unpluging it for 24 hours to allow the ice to melt.
Posted on Oct 04, 2010
I have Whirlpool fridge FF450 Elite. Though the fridge cooling is normal, after the night working find in the early morning all magic light flickering though the fridge compressor is working. The freezing...
seems to me by the frost that the inside fan is not blowing air across the cooling radiator (evaporator), due to ice build up impeding air flow or the fan motor stalls or not working a t all. Defrost timer should also be checked if the air flows thru inside the fridge.
Jan 06, 2015 | Whirlpool Refrigerators
U-Line undercounted refrigerator has condensation on the back metal panel.
If its not affecting the cooling ignore it, if it worries you, turn it off, dry it out , clean area & repaint it.
Nov 14, 2013 | U-Line 15R Compact Refrigerator
Hi, I have an LG artcool A09AHD aircon unit and after a while on the heat cycle, the unit stops and shows a circle with a snowflake and a waterdrop within the circle. Does anybody know what alarm tjis is?...
This may just be the defrost cycle for the outdoor unit. In the heat mode, the outdoor unit builds frost on the coil. The outdoor unit senses how much frost has built up on the coil and reverses the refrigerant cycle to allow the outdoor coil to warm up and defrost it. After a short period, the unit then restores itself to the heat cycle. This is normal operation and nothing to worry about. During the defrost cycle, you may feel some cool air inside your home.
Oct 26, 2013 | LG Heating & Cooling
There is ice buildup on the unit behind the fan and its causing the fan to rub on the ice. Why is this happening and what do i do to fix it?
Your unit is NOT frost free according to the specs so it will required periodic defrosting to keep the ice build up from affecting the fan.
Aug 14, 2011 | LG GC-051SS Compact Refrigerator
Frost build up in freezer
The frost is preventing the evaporator fan from circulating the air.
Check that it is operating properly - and thaw out condenser if needed.
A hair dryer will work good.
Verify the fan is operational after thawing.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 30, 2009 | Maytag MSD2756G Side by Side Refrigerator
My fridge wont stay cold.
it is not frost free , there is no fan , this fridge for light office use , also make sure gasket is ok , good luck:)
Sep 12, 2009 | Haier (B000194UBA) Compact Refrigerator
My compact fridge does not defrost and ice builds up in freezer section. How can I disconnect the freezer and not use it?
Lynne, the freezer section is what provides the cooling for the fridge, so there is no way to disconnect the freezer and still be able to have the fridge operate.
With the small compact fridges, the only thing you can do is to manually defrost the unit, when the ice buildup gets too much, which can vary, based on how you use your fridge, how often it gets opened and closed, etc.
Some compact fridge models have a small push button in the center of the temperature setting control knob - if your's has one, you can push that to initiate a self defrost cycle. However, you'll need to have some towels handy to collect the water that will result from melting off the freezer section.
There are not many small, compact fridge units that have the no-frost feature of full sized fridges, as it is more costly to build in all the needed components required to have frost-free operation. Not to mention the size of the fridge gets much larger, because of all the space needed to house those features (defrost heaters, electronic controls, ciruculating fans, control vents, sensors, drip/drain pan, etc., etc.)
Hope you find this Very Helpful and best regards!
Aug 25, 2009 | GE Refrigerators
The divder between my frig and freezer is also hot
This is normal. Modern frost free fridges have heaters built into the front edge of the cabinet to help keep the accumulation of surface condensation and excessive ice build up on the door edges inside the freezer and fridge.
It is nothing to worry about, but you might have an energy saver switch inside the fridge section that you can turn "on" to turn OFF the heaters (energy saver means the power using heaters would be OFF when the energy saver is "on", turning it "off" means the heaters are ON.
But not all fridges have a switch to turn off the heaters, so don't worry, just accept it and don't buy a new fridge until you need to.
Hope that helps, best regards!
Jul 30, 2009 | Roper RS25AEXLQ Side by Side Refrigerator
Everything in my refrigerator is frozen even on the lowest setting... what gives?
nothing to worry! just switch off your refrigerator for about 8hrs and after that switch it again. if it won't work than its time to replace your thermostart. because due to its falure only, the compressor is continously running and the temp. decreases. and all the metarials frosted..........................have a nice day :-)
May 14, 2009 | Sanyo SR-3620 Compact Refrigerator
Freezer building up lots of frost, but on lowest setting.
FREEZERS SHOULD BE TEMP AT O /REFRIGERATOR SHOULD BE 40/FOR PERFECT OPERATION.1ST IS THE FAN RUNNING IN THE FREEZER/IF YES UNPLUG FOR 6-8 HOURS AND RETRY/IF NO UNPLUG THE FRIDGE AND REMOVE THE BACK PANEL OF THE FREEZER MAKE SURE THE FAN IS PLUGGED IN.IF SO PLUG IN THE FRIDGE AND SEE IF THE FAN IS TURNING.IF NOT YOU NEED A NEW FAN IF THE FRIDGE IS NEW MAKE THEM BRING YOU A REPLACEMENT FOR FREE.
Jan 16, 2009 | Jenn-Air JCB2059G Bottom Freezer...
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
