Question about Humminbird 595c GPS Receiver
My gps not working - Humminbird 595c GPS Receiver
I am a pilot, and got this tablet to aid in navigation. Any and all apps that I have downloaded, tell me the gps isnt working. Its set to 'high accuarcy' and is still not working.
Why would you buy a tablet when for around for the same price you could obtain a good quality GPS , you don't have to have GPS to use Google maps.
Jul 10, 2015 | Tablets & eReaders
Trying to get my gps working on my boss double din when i press the gps icon it says gps not supported
You have to be sure that the radio really support gps it doesn't work on every boss radio it could have the icon of GPS but still doesnt need to be gps supported if it have gps then you have to be sure that you connect everything correctly
Apr 24, 2014 | GPS
Waiting for GPS comes up when I try to get directions, it never loads
what are you using for gps? ovi maps? garmin? google maps?
i suggest installing google maps to see if your gps is working alright.
then check in phone settings to ensure that gps positioning method is enabled for 'built-in gps' and 'assisted gps', thereafter check positioning server is set to 'supl.nokia.com'.
normal lock time is around 5-30seconds with E71 GPS with A-GPS on; anything more than that i'd attribute it to a faulty built-in gps unit.
let me know if it works.
Jan 26, 2011 | Nokia E71 Smartphone
My gps stop working on my rx5915
If your gps does not come on anymore, there seem to be a problem somewhere, which most likely is from either the battery, the charger or both. Try another battery in the gps to see if it will work, if it works, then it means you will need to get another battery for your gps.
Test the charger also on another gps to see if it will charge, if it charges it, then it is okay, but if it does not, then it is bad and need to be replaced. Either way, you have detected the cause and solved the problem.
But if your gps normally comes on and does not read map or signal, then you need to reset your gps. Or update to the latest version of software for your GPS.
Hope this information helped.
Dec 23, 2010 | HP iPAQ RX5915 Travel Companion GPS...
Gps is not working. no error message.
If your GPS is not working, charge the battery of your gps, if it is not still working, i will advice you get a new battery on the gps because it is possible that the battery on the gps might have gone bad, change the battery and see if it will work.
Need more information, leave comment.
Take care.
Jul 27, 2010 | Computers & Internet
Gps error message "gps module not responding"
Check the connectors and wiring between the GPS module and sonar unit. If it's an internal GPS module yo may have knocked loose a connector internally.
Jun 01, 2009 | Lowrance LCX-17m Sonar with GPS GPS...
Navman pin 570 navigation not working screen says gps port closed
tap on "GPS Status" (second page of GPS software) and be sure that the box is checked in the upper left hand corner. In the same screen, be sure com 8 and 9600 (baud rate) is shown.
May 28, 2009 | Navman PiN 570 GPS Receiver
I cant find my gps on my samsung omnia
I have a Samsung Omnia. If you go into settings you can turn on AGPS (assisted GPS) and download some addition software that helps gps. GPS is automatic but you can turn it off or allow windows mobile to manage it which is advisable. You cannot automatically see the GPS but you can buy or get third party software to see when GPS is working.
GPS gate works to turn gps on/off manual but this is just one software.
I have included a link to show where these settings are and if you want to use GPS gate. Note: I am not affiliate with GPS gate at all.
Nov 13, 2008 | Cell Phones
Navigon 5100 gps
Try turning it off and turning it back on while it is still plugged in and see if that works.
Oct 23, 2008 | Panasonic Navigon 5100
My HTC TyTN II GPS does not appear to work. I have bought the device, and when I first installed TomTom the device was able to get a GPS fix, Howeve after I ran external GPS, the device no longer seems...
I Got it!
I finally got my HTC TyTN II yesterday from Dubai.
First thing I wanted to test was the GPS. It did not work with: TomTom6, Google Maps, Yahoo Go.)
I was surfing around to find something that would help me out and have noticed that many people have the same problem.
Many people (Like me) did not know howe to setup the GPS.
Many people are saying: "You have to put it your GPS settings in Com 4 and the Baud rate on 4800 and it should work.
Well mine didn't work with those settings. (Along with other people.)
I had played with the External GPS option (Don't do this cause setting something wrongm ay cost you a HARD-Reset.)
I Was lucky that mine worked again after a SOFT-Reset. So watch out!
The standard GPS settings! (If you have changed it, Soft-reset your phone and set it up as these pictures show.)
Why am I doing this?
People buy this phone to make use of it. When something does not work why buy the phone then :S
Hope that this may help a lot of people on here and other forums, communitys & websites.
Here is my story of how I did get my GPS to work:
1. Download the GPS addresses by using QuickGPS (Start -> Programs -> QuickGPS).
(This will download info of what your GPS Reciver needs to connect to the satalites.)
2. Download a free (Well half free, You can also buy this application it will give you some extra options, but we don't need those extra options.) tool named: GPS Test. (http://www.smartphone.net/software_detail.asp?id=3170 or at http://www.pocketpc-software-downloads.com/software/t-free-pocketpc-gps-test-download-uykfcoyy.html)
(This program will scan all your mobiles com ports and Baud rates, To see what your real GPS settings are.
In my case they were: COM PORT: 4 - Baud Rate: 9600 (Notice it ain't 4800. Usaly it shows your settings with a pop-up.
When It doesn't Go to "Menu -> GPS Settings", There it will show you you're GPS settings.)
3. Install TomTom 64. Download your free map.
5. Go to the GPS settings.
(Set-up: Other NMEA GPS-Reciver -> GPS-Baud Rate -> Com. (Select the Baud rate + Com port from what the GPS Test did show you.)
6. Now wait.
Jun 29, 2008 | GPS
Humminbird 595c GPS Receiver Logo
81 people viewed this question
Top Humminbird GPS Experts
Jerry Greenberg
Jerry Greenberg
Steve
Steve
Are you a Humminbird GPS Expert? Answer questions, earn points and help others
