Question about LG LFX25960ST Stainless Steel French Door Refrigerator
I'm getting the Er IF code, unplugged it for the recommended time and plugged it back in and still getting error code, where is the fan located so I can access it and replace it, Is it in the freezer compartment where I take off the panel in the back. Thank you for your help. Peter
  • 4 Answers
Peter,
I'm having the same eexact problem now and it's down two the Ice Fan Motor or the pcb main. Here is the website where you can find the part.
http://www.searspartsdirect.com/partsdirect/part-model/LG-Parts/Refrigerator-Parts/Model-LFX25960ST/3204/0161000/K0810256/00001?blt=06&prst=&shdMod=
Karl
Posted on Oct 11, 2010
What is wrong when I receive error code Er rF
Hello Anonymous!
Error code Er rF is an :Abnormality of BLDC FAN Motor for Freezer.
  • The freezer fan motor may be Defective.
  • Unplug the fridge for about 30 minutes and plug it back in, if the code appear again within 24 Hr , the Main Board might be defective too.
  • Check if the freezer fan is blowing normally, then the Main board has a problem.
  • If not, the Fan Motor is defective or both.
  • I would change the Fan first then the Main PCB
Good Luck,
JP
Jul 09, 2015 | LG Stainless Steel French Door...
Showing code of ice Er on door disp.
the error code er if means that the main control board lost a feedback signal from the icing fan motor for over 115 seconds. this fan is located in the rear of the freezer section, on the left side of the fan cover. the fan supplies cold air for the compartment where the icemaker is located. the error code may be cleared by disconnecting power to the refrigerator for about 3 minutes, then plugging the unit back in. the code will be cleared, but may come back if the icing fan does not start running. if the error continues to come back after the power has been reset. there may be ice formed around the fan housing preventing the fan from running. the fan cover can be removed, but is time consuming and difficult. you could just unplug the unit for 24 hours and leave the doors open. this will allow any ice build-up to melt and return the unit to proper operation.
May 17, 2015 | Frigidaire Refrigerators
What is 1F code on kenmore elite refrigerator
The Er IF error code indicates that the main control board detects that the ice compartment cooling fan is not working. This will cause a lack of cooling in the ice compartment and will normally result in no ice production. This is something that a service technician will usually need to correct.
Apr 17, 2015 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
What does message Er IF mean?
LG refrigerator "Er IF" error code is the "Icemaker Fan Error" message.T his error code indicates a problem with the fan that controls the unit's ice production. If this problem occurs because of ice buildup, unplugging the unit for 3 to 4 hours and allowing it to thaw may fix the issue. Call customer service if that doesn't work.
Oct 12, 2012 | LG Refrigerators
Error on display er ff
Hi, here are the error codes and meanings for your Refrigerator
Error Code, All Error Codes will have an ER on the left side, followed by the error on the right:
Er IF - Icemaker Fan Error - This can be caused by frostaccumulation on or around the icemaker fan. Unplug the unit for 3-4hours to allow this to melt off. If error code persists, call CustomerService.
Er FF - Freezer Fan Error - This can be caused by frost accumulationon or around the freezer fan. Unplug the unit for 3-4 hours to allowthis to melt off. If error code persists, call Customer Service.
For remaining error codes, try unplugging the unit for a couple ofminutes to reset the unit. If the error code persists, call CustomerService
Er FS - Freezer Sensor Error
Er rS - Refrigerator Sensor Error
Er ds - Defrost Sensor Error
Er dH - Defrost Heater Error
Er CF - Cooling Motor Error
Er CO - Communications Error
Thank you.
Jun 06, 2012 | Refrigerators
What does the message "Er
Hi
Error Code "Er FF" indicates a problem with the unit's freezer fan.
The freezer fan controls the temperature in the freezer. The source of this error is most likely ice buildup. As with the Er IF error, allowing the unit to thaw should resolve the issue. This can be caused by frost accumulation on or around the freezer fan. Unplug the unit for 3-4 hours to allow this to melt off. If error code persists, call Customer Service.
Please get back to us if you have further query or else please accept the solution.
Sep 02, 2011 | U-Line BI-95
Error code ER FF
code for defective freezer fan motor. ER FF
Sep 21, 2009 | LG LFX25960ST Stainless Steel French Door...
Kenmore elite refrigerator error code er if
Bad icemaker fan. When looking in the freezer, its the one on the left.
Sep 01, 2008 | Kenmore 73503 Stainless Steel Bottom...
Error code Er IF is on the display and noone from sears can tell me what it is, does anyone know?
ER IF means error icing fan, the problem is with a little board that is behind the water dispenser. Change this board and you will be in business.
sgt 48
Jun 27, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
LG refrigerator not working
Check and clean the condenser. Unplugging the system allows it to cool off. when you plug it back in it will cool until the heat rebuilds if not rejected through the condenser. Make sure the condenser fan comes on when the compressor runs. A faulty fan motor will cause the same type of problem.
May 19, 2008 | LG LRTBC1825T Top Freezer Refrigerator
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
297 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
