Question about Canon i350 InkJet Printer
ANYTHING I PRINT OFF HAS DIAGNAL LINES ACROOS THE PICTURE I HAVE PUT NEW INK IN BUT IT DOENT HELP. THANKS
  • 249 Answers
Try to go to the setup for your printer then troubleshoot tab. There you could setup for cleaning the print heads and also the alignments.
Posted on Oct 04, 2010
Changed cartridge, received a code "P", says to install a new cartridge, but I just did install. Will not allow to do a clean print head.
hi, first turn the printer off and unplug it and let set for 30 mins. Ig that doesn't work try taking the cartridge out and reaching inside where you put the cartridges go and clean the print head with alcohol with a q-tip.
Nov 22, 2015 | Epson Picturemate Picture Mate Deluxe 500...
My printer is full of ink but when I print anything with colour it had horizontal lines going through it
This problem is pretty much the same as the question I answered a few seconds ago. I am going to give the same answer. Try running one or two ink cartridge cleaning cycles to help clear the air out of the ink nozzles. New cartridges aren't always perfect to begin with. After doing the cleaning try running a test print from your printer setup or installation properties window. If this print is good try printing another picture on a plain piece of paper rather than photo paper. If it prints OK then use your photo paper. I say this so you don't waste your photo paper. If you get lines in the test print, return the cartridge and see if the place you bought it from will exchange it for another one. If they will not exchange it try to get them to make the cartridge print correctly. You may have to bring your printer to them. This is the best advice I can give you, I hope it helps.
May 27, 2015 | Office Equipment & Supplies
Tle lines through printed picture
Run the "Clean Printhead" command. If this doesn't fix the problem, contact Canon. The printhead is wearing out.
Sep 16, 2009 | Canon PIXMA MP460 All-In-One InkJet...
I am trying to print a picture and my pic is coming out with lines through it. Any suggestions?
Try this one, Turn on the printer, Take out the inks, remove the printhead, put back the printhead make sure it will snap and you hear a click, put the inks back, wait for the printer to initialize, Press the Menu button, look for Calibrate printer, then print calibration page, then scan it after. Load a regular paper. Then try to print a demo page by pressing Photo and Copy at the same for 5 seconds then let it go. If same problem persist call this no for further assistance 1800 421 6699
Thanks
Aug 31, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
The printout has lines going through the pictures or wordings
here is the troubleshooting steps
try to remove the ink cartridges and put it baack again but make sure to hear a click sound when you put the ink cartridges,after that try to print again picture and if still has lines through it press the menu in the printer scroll down until you can see the calibrate printer,press ok and select the print calibration page and hit the ok button..after it print place the calibration page in the scanner glass and press start, try to print again a picture and if still has a line call the kodak hot line 1 800 421 6699 and you might have a printhead replacement.
Nov 15, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Horizontal colored lines through grayscale printed photos
Hi George,
It sound's like an ink-feed issue:
1) Dirty heads, even after cleaning
2) No-ink or poor quality ink
3) Damaged head: some are part of the cartridge, some are not
4) Air bubbles in ink
The test page is typically not as hi-res nor as saturated as a
photo print. The hi-res photo puts the greatest demand on the print head.
The color lines you see are actually lines of missing color,
where the head has failed to deposit ink, so one or two primary
colors are missing from the complete picture.
For example missing yellow will make a blue line.
Missing magenta will make a green line
Missing cyan will make a red line.... etc..
Clean the heads again and again, print again and again,
hoping to flush the system.
BUT, keep in mind that cleaning wastes huge amounts of
ink and tiny little cartridges of ink cost more than many new printers.
Martin
Apr 24, 2008 | Canon PIXMA iP90 Mobile Printer
No yellow ink
It sounds like you have a clogged nozzle. First I must assume you are using refilled compatible cartridges. You should change the cartridges for genuine Epson ones before proceeding.
Run 4 or 5 head cleaning procedures through the printer driver. DO NOT DO THIS WITH COMPATIBLE INK IN as this can make the problem worse.
If the clog does not clear or show significant improvement after 3 or 4 cleans, contact this person for information on intensive head cleaning for your machine.
Mar 27, 2008 | Epson Stylus C43SX InkJet Printer
Diagnal Interference Lines
the diagonal lines represent some low frequency interference (close to the supply frequency - 60 hz). Try to keep the unit away from other appliances, especially the left back zone - where the tuner is. Also, you have to do some experiments on the cable connections: disconnect other cable devices (internet modem, home phone, other tv/tuners), one of them might inject these signals into the cable. Keep me posted
Aug 25, 2006 | Toshiba DR4 DVD Recorder
Canon i350 InkJet Printer Logo
old marine
old marine
