Question about Agri-Fab Garden
I have a An Agri-Fab Model 45-03152 The Impeller is broken and spins on shaft . Can I get areplacement impeller etc.
Master_Tech
  • 770 Answers
SOURCE: I had an "f2" error code on Fisher Paykel DD603
i will but need your email address
Posted on May 20, 2008
valiantma595
  • 176 Answers
SOURCE: how to remove impeller from motor to replace
If it's a separate shaft, it requires a puller tool, but first you have to remove a nut that holds the impeller to the shaft. If the shaft is part of the impeller, meaning that it is a one piece fabrication, then there is nothing you can do about it. You haven't even stated where does this impeller come from, a washing machine, a water pump, etc.
Posted on Sep 18, 2009
  • 409 Answers
SOURCE: REMOVE IMPELLER FROM SHAFT A O SMITH PUMP MOTOR HIFLO
The impeller is threaded onto the motor shaft, take the back cover off and use a wrench to hold the motor shaft, then turn the impeller counter clockwise to remove.
Posted on Mar 17, 2010
  • 198 Answers
SOURCE: 1 HP electric motor hums but not turning.
check for a re-set button somewhere on the motor housing.
Posted on May 04, 2010
  • 677 Answers
SOURCE: how tough is it to change water pump impeller on 15hp johnson
There is no special tricks.Unbolt the gearshift linkage that has access through the side of the leg.Usually a small plate.Unbolt the lower g/box.4 bolts I think.The box should then drop.If not,use a rubber hammer and be patient.Put the lower skeg of the g/box in a vice to make things easier.NOW.When you lift the housing of the w/pump take a note of which way the impellar pump lobes are curled.DON'T put the new impellar in the wrong way.It's probably worth putting in a new seal whilst it's apart.You spin the housing or imp. as you put it together.Use a small bit of grease for the initiall dry start-up.Put some very good grease on the top splines on the driveshaft.It goes straight into the crankshaft.If it corrodes,nothing comes apart.As you put the g/box back on,spin the prop so the splines go back in.There is no special alignment.Gearchange linkage and you go fishing.(take the prop off and regrease the splines on the shaft of it)Hope this helps
Posted on Jul 22, 2010
Can my shaft spin and not my impellor. how can i check
the impeller is usually screw onto the shaft or the shaft has a D (flatspot on one side to lock impeller) so no, the shaft cannot spin without the impeller moving unless the shaft is snapped or impeller is totally stripped (ive never seen either)
if the pump is running but not pushing water, take the wet end off and make sure there is no debris (leaves, worms etc) caught in the impeller fins. you will be amazed at how much that will reduce the performance of a pump
Jun 20, 2014 | Hayward 1.5hp Pool Pump Motor Motor A O...
Removing impeller mow n vac
Sounds like you need to contact your nearest authorized service center, or you can download operators and service manuals directly from the Agrifab website by clicking on the provided link:
Downloadable Manuals
I trust this information proves useful.
Jan 23, 2014 | Agri-Fab Garden
Having difficulty pulling impeller wheel for replacement on an AGRIFAB 5HP Vacuum. I assume the shaft is tapered and I tried using a jackbolt to try to loosen. If there is a shaft key, could it be bent or...
did you find a grub screw in the impeller hub
using the correct puller tension the puller then hit the center bolt hard and if it is a taper , it will jump off
Aug 19, 2017 | Agri-Fab Agrifab Towbehind Mownvac...
I have a Kenmore Ultra Wash model 665 1373 and it isn't getting totally clean on the top rack - glasses and cups are almost clean but bowls etc are not, any ideas?
Check the shaft of the impeller, the plastic shaft might be broken, it was the problem with mine. To get to the impeller you have to remove the filter at the base of the diswasher and after you will see the screw that hold the impeller assembly in place, unscrew it and you will see right away if it is broken, Good luck
Jul 16, 2011 | Kenmore PRO 24 in BuiltIn Dishwasher with...
I have a ao smith sp 1520 2 hp pool pump. the impeller broke off the shaft. how do i change the broken impeller please
Remove the back of the motor ... you will find there are flats on the shaft. Put your 7/16 or 1/2 open end wrench there and with your other hand, spin off the broken impeller.
Aug 22, 2010 | AO Smith 2 hp Swimming Pool - Jet / Well...
I have a ariens snow blower model 1128 when i engage the impeller turns and the shaft to the auger gear box turns but the augers don't turn. the shear bolts are not broke either
Have you confirmed the bolt integrity completely through the shaft? Also check the gearbox for proper lubrication or gear failure.
I recommend contacting your nearest authorized service center, or you can download operators and service manuals typically online by performing a simple Google search using your make, model number and part needed.
I trust this information proves beneficial.
Jan 02, 2010 | Agri-Fab Agri - Fab Snow Blower - 42"
I have a Toro Snowblower Model#38620 (826LE). Last winter the Traction belt(94-8812) kept slipping off of the pulley-impeller when under load so I replaced both belts which were worn, that I purchased from...
You may need to replace the pulley also.
I recommend that you contact your nearest authorized service center, or you can download operators and service manuals directly from the Agrifab website by clicking on the provided link:
Sep 26, 2017 | Agri-Fab Agri - Fab Snow Blower - 42"
Traction Belt (new) continues to slip off of drive plate.
Sounds like you may need to replace the pulley as well. It has likely worn out of specification.
I recommend that you contact your nearest authorized service center, or contact Toro directly for assistance.
Oct 02, 2009 | Agri-Fab Agri - Fab Snow Blower - 42"
Garden Logo
89 people viewed this question
Top Agri-Fab Garden Experts
Joseph Mueller
Joseph Mueller
David Ellis Rhea
Ray Smythe
Are you an Agri-Fab Garden Expert? Answer questions, earn points and help others
