Question about Toys
What age is recommeded for using the jumperoo? and how do I set the height to a lower level?
    Sergeant:
  • 168 Answers
It should say on your box. but 6 months is usually the age. but really when they can support their neck and hold their own head up.
My son started using it around 3 months. I put him in it when he had good neck strength and no longer had any head wobbles.
From about 3-5.5 months he enjoyed the toys on it. But he didn't start jumping until about 5.5-6 months, but once he figured it out (literally after I demonstrated it by jumping in front of him) he LOVED jumping and playing with the toys.
Check that using Bumbo about 3-4 months. Doorway jumper 5-5 1/2 months. Exersaucer 6or 7 months maybe.
I hope helps.
Posted on Oct 04, 2010
New Holland tractor
Sensor, wiring or computer failure.
Jun 26, 2016 | Cars & Trucks
How to lower lawn mower
Cindy, if it's already at the lowest setting, you kinda / sorta answered your own question, i.e. it can't be adjusted any lower; but, as you may be aware, there is an adjuster at every wheel, and by putting all wheels at the same - lower - level, you will get a lower, mowing height; and if you've already done that, or there are no 'individual adjusters', they wheels are typically bolted to the frame and there are usually several holes to bolt the wheel to - simply un-bolt and re-bolt to achieve the lowest, preferred height.
Apr 01, 2016 | Garden
Can't find the relay for the electronic level control(elc) for a 1999 cadillac eldorado
1. Locate the automatic level control height sensor under the rear of the vehicle on the rear suspension support. If the back of the car is too low and will not pump up, ground pin B Yellow wire and see if the compressor will come on and the car will raise.
2. If the car does raise when pin B is grounded, check the powers and grounds to the height sensor.
3. If the powers and grounds are OK and the pump does come on and the car raises when pin B is grounded, the height sensor will need to be replaced.
4. If the car is too high and will not come down, ground pin E White wire at the height sensor to see if the car will lower.
5. If the car lowers when the White wire in pin E is grounded, check the powers and grounds to the height sensor.
6. If powers and grounds are OK and the car does lower when pin E is grounded, the height sensor will need to be replaced. Tech Tips: There are two different automatic level control systems for this car; one is without RPO F45 and one is with RPO F45. The system without F45 has an automatic level control height sensor and with F45 the automatic level control compressor is controlled by the continuously variable road sensing suspension module. Tests/Procedures: 1. Using a head lamp as a load, test the ELC height sensor power/grounds.
2. The power feeds are: Orange wire, pin C and a Brown wire, pin D.
3. The ground is pin A, Black wire.
4. Ground the White wire at the height sensor, check that the vent solenoid in the ELC compressor clicks and vents the air from the system. Author: Bill Siegmann
Dec 24, 2012 | 1999 Cadillac Eldorado
I recently bought a kia sportage but when i hooked up my caravan , i found that the caravan was sitting high at the front , a problem i never hadwith my previous 2 cars , how can i tell if the towbar is...
Hi, You haven't mentioned what age your Sportage is, it may have been fitted with self adjusting rear suspension which will lower the ball height after a few miles of driving with the caravan on. Please check the specification of your Sportage.
Is the kneck of the towbar (the part with the ball on it) like a swan kneck or a traditional bolted on ball? Swan kneck towbars are not usually height adjustable but bolt on balls can be adjusted by fitting a spacer plate which has three different heights. Ideally the caravan should sit level when hitched.
Apr 28, 2011 | Kia Sportage Cars & Trucks
I just purchased the Fisher Price Jumperoo Deluxe from a second hand store. The front part of the chair tilts forward and I thought it should be level. How do I fix this?
There should be a fabric strip that goes through 4 places on the jumperoo, under the seat part, and that fastens underneath by fitting over a small metal lever. Put the seat upside down, pull the front straps through the bottom a little to get some slack, pull the metal levers on each side forward (there is a small catch they are placed in when the jumperoo is in use; you'll have to move them up and forward to get them out of place and maneuver them so you can reposition the straps) and pull the straps off the metal levers. You can then choose the next tightest setting for the straps and push the metal levers back into place.
Mar 13, 2011 | Fisher Price Deluxe Jumperoo
Whats the proper height when using the exersaucer evenflo
  • Place the product on level ground and make sure the legs are the same height. (The tray should be level.) That's the best way to avoid tip-overs.
  • Follow the manufacturer's age, weight, and height recommendations and keep the owner's manual for future reference. Don't use the activity center before your baby can sit up unassisted, and stop using it when your baby reaches the height or weight maximum and can walk or even stand up by himself, which means that he could easily tip it. And, as a general rule, if your child can tip over the activity center by just leaning over the edge or can climb out of it, it's time to retire it.
  • hope this helps.
  • Aug 04, 2010 | Evenflo ExerSaucer SmartSteps Active...
    SCALE SETTINGS
    To change the height/weight/age, hold the user # you want to change it for and the set/save button at the same time for a few seconds.
    I am #2, so I hold the 2 button and set/save. Then you can use scroll to change the numbers/options, and set when you have properly set the digit.
    First it does height, then age, then gender, then if you want a goal, and then what that goal is.
    Apr 09, 2009 | Health-O-Meter Health o Meter BFM588DQ-81...
    Changing user settings on Conair WW67T scale
    1. Tap the scale
    2. Wait for "0.0" display
    3. Set
    4. Use the up arrow then stop on the user you desire
    5. Set
    6 Using the up/down keys enter Height
    7 Set
    8 Using the up/down keys enter Age
    9 Set
    10 pick the little man or woman
    11. Press SET - the scales will redisplay your profile settings for verification.
    12. Wait Until the Display Goes Blank.
    13. Tap the Scale.
    14. Press USER, select desired profile, P-01 is the default.
    15. Wait for "0.0" display
    16. Step onto the scales and wait for all measurements to display
    Oct 02, 2008 | Health & Beauty
    Toys Logo
    125 people viewed this question
    Top Toys Experts
    Andrew Taylor
    Andrew Taylor
    Are you a Toy Expert? Answer questions, earn points and help others
