Question about Roper REX5635E Dryer
My dryer wont start, like there is no power.....checked breakers... checked plug ...no obvious problems...is there a reset on the dryer itself
    Sergeant:
    Champion:
  • 351 Answers
Safety limit it not a reset you will have to replace
Posted on Oct 04, 2010
THE DRYER WONT START,FILTER AND VENTS ARE CLEAR. HOW DO YOU FIX THIS PROBLEM?
Several reasons can cause a no start dryer condition. I'll start with the easy ones first. If a gas dryer, it runs off 120 volts. Check the house fuse or breaker or plug a light into the dryer outlet to make sure you have power. If outlet is OK then we have several dryer problems possible. If the dryer is electric, it run off 220 volts. You need a voltage tester to check the 220 house plug. Could still be a problem with the house 220 breaker. On the dryer itself, the first thing to check is the door switch. If the door switch is bad the dryer will think the door is open even when it is actually closed. Next, some dryers have a switch on the internal belt system. If the belt breaks, the dryer will not run.(only on some newer models). Couls also be a bad timer assembly. Some of these may need a tech to actually test since it requires taking the dryer apart to get to these item.
Feb 28, 2015 | Dryers
Dryer will not start
It is possible the cord/pigtail connections were not tightened enough and have burnt off.
May 01, 2014 | Dryers
Dryer has power wont start
Hello Dom - Being that you have narrow down some possibilities, here are a few simple troubleshooting tips that may help you get to the root cause:
1. Make sure the dryer is plugged into outlet, and plugged in correctly.
2. Is house fuse blown or circuit breaker tripped? Replace fuse or re-set circuit breaker.
3. Make sure that electrical circuit is not overloaded and correct. The dryer must be on a circuit by itself. Overloaded circuits can damage the dryer and possibly cause damage to home. I would recommend reaching out to a Licensed Electrician check to make sure it is on a circuit by itself.
4. Thermal limiter tripped or an internal problem with the dryer. A thermal limiter automatically turns off the motor (electric dryers only) in the unlikely event of an overheated situation.A service technician must replace the thermal limiter after correcting the fault.
If these assessment measures prove to be ineffective, I would strongly suggest contacting an authorized service technician who would be better able to assist you in the diagnosis and repair of your unit. You can often locate an experienced technician in your area by going to the manufacturer website.
Jun 19, 2013 | Frigidaire Dryers
Frigidaire electric dryer model gleq2152es1 lights wont turn on and wont do anything
Hi ana piedranayari05, this is AP! Thank you for your post
I understand you are having trouble with your Frigidaire electric dryer not turning on. Make sure the dryer is still plugged into the outlet, and plugged in correctly. Also check to see if the house fuse is blown or circuit breaker tripped? If so, Replace fuse or re-set circuit breaker. Check to make sure that electrical circuit is not overloaded and correct. The dryer must be on a circuit by itself. Overloaded circuits can damage the dryer and possibly cause damage to home. Have a licensed electrician check to make sure it is on a circuit by itself. Additionally, the thermal limiter could have tripped or possibly an internal problem with the dryer. A thermal limiter automatically turns off the motor in the unlikely event of an overheated situation. A service technician must replace the thermal limiter after correcting the fault. If you have check the plug, fuses, and circuit breaker and still no power I would recommend contacting a local technician to diagnose and service your electric dryer.
Jan 18, 2012 | Frigidaire GLEQ2152ES Electric Dryer
I have had my whirlpool dryer about 4yrs + (geq9800pw2) has always worked fine. Last week it started tripping ckt breaker toward the end of drying cycle. As of this morning, it blows ckt breaker...
leave off the oven and a/c breakers and plug dryer and reset the breaker. if not tripping occurs then one at a time trip back the oven first. if no trip then trip off again and trip the a/c. if no trip then trip the oven back. if trip you may have a wire problem. if dryer trip any way then possibly you have a short in dryer. check the heating element wires,power cord at the dryer side(terminal block).
Feb 14, 2011 | Dryers
Kenmore 90 series dryer, motor wont start, loud
  • Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
  • If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
  • Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Hope this will fix your problem for sure.
May 10, 2010 | Kenmore Dryers
Hello, our dryer won't start today. Any ideas
Firsyl, check that it's plugged in. Stupid some say but it happens.
Jan 17, 2010 | GE DBXR463EDWW Electric Dryer
Dryer was working fine...then
You have a short circuit in the dryer. Check the incoming wires at the cord terminal on the rear of the dryer. If these wires are OK it could be a shorted heating element.
Sep 08, 2009 | Whirlpool LER5636P Electric Dryer
Kenmore 80 serirs dryer wont start..
hi..check your circuit breaker,may be the power cord
is tripping it.If this is not the problem,check and see if
there is a reset button on the outlet where you plug in
the dryer.
try this out..
thank u..
kindly rate my response..
May 15, 2009 | Kenmore 44832 Front Load Washer
Dryers Logo
76 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
