Question about Maytag PAV2300 Top Load Washer
Drum won't move or spin... but motor does...new belt?
    Problem Solver:
  • 15 Answers
Axes broken between tub and drum
Posted on Oct 07, 2010
Bowl will not turn or spin in any cycle the machine fills and emptys but the bowl just doesn't agitate
Sounds like either the belt has snapped from drum to motor or the motor has gone its easy to fix just remove the rear panel check to see if the belts snapped put new one on there should be a nut that tightens the belt up on the motor psrt put belt around drum part and motor and move the motor to tighten yhe belt up
Jul 27, 2017 | Washing Machines
Wf865 drum won't turn in programme
have you checked the motor brushes there are 2 of them they are located on each side of the motor you will have to take the motor off and you will see them at the back of the motor undo the 2 screws on each one and take out the carbons should be 25m long and shinny and spring in and out freely I can supply new ones if you need them
Sep 27, 2012 | Hotpoint Ultima WF865 Front Load Washer
The belt keeps slipping off so the drum won't turn
replace the bel, is worn, put a new one. Of course before try to adjust the tension of belt, for moving a little the motor.
God bless you
Sep 22, 2012 | Vacuums
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
Drum won't move
take the back panel off make sure power is off and check if the belt has come off or broken and also check the pulley that spins belt is tight and if all that is ok then it sounds like the motor might need to be looked at
Jul 05, 2011 | Bosch Axxis+ WFR 2460 Front Load Washer
The dryer is plugged in and the circuts seem to work however the dryer is making a humming noise but it will not turn on fully.
what do you mean it won't fully turn on?do you mean the motor won't run because usually when it humms you either have a bad motor or something is jammed and stopped the motor from spinning.try this,open the door,with one hand hold the door switch in and with the other hand spin the drum,have someone else push the start button while you do this,if it starts the motor is bad,if you can't spin the drum something could be stuck in the blower wheel or the belt broke and could of jammed up the motor but it sounds like you have a bad motor.let me know what you find and next time send the brand name and model number.
May 04, 2011 | Dryers
The Maytag washer doesn't spin and had a burning rubber smell. Motor operates, but the drum does not spin. Belts have slack, motor pulley show evidence of belt turning which caused the burning rubber...
You should have a tensioner pully (a small wheel on a piece of spring steel) that hold the belt tight.
If that spring steel is broken or weak, then you will have to take the broken one to your local appliance repair parts shop and obtain a new one.
That should keep the belt tight and keep the drum spinning.... -Jim
Oct 23, 2009 | Washing Machines
New belt runs too close to drum on pully
adj belt in motor pulley groves 1 grove at at time spin with hand to center on drum pulley
Dec 07, 2008 | Frigidaire ATF6000ES Front Load Washer
My indesit WG1230 washing machine does not spin or move drum but water go in and out.
With the door open, try spinning the drum, there should be some resistance along with a slight wherring sound. If it spins freely without much sound at all - you probably need a new belt.
If you can feel it driving the motor, you may need new contact brushes for the motor.
If the machine buzzes when it should rotate on program, you need a new motor Run capacitor also.
If no sound - nothing, the motor may need replacing or at least checking.
Nov 05, 2008 | Indesit Washing Machines
Maytag PAV2300 Top Load Washer Logo
47 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
