Question about Cycling
I dont know how to adjust the gap beetween the frame and thebottom and top of the shaft of the fork that goes thru the frame is it just the hexagon screw by the handle bars? cause that doesnt seem to be working for me
    Genius:
  • 1,788 Answers
The hexagon screw is the lug bolt for the fork, it also has an expander on the bottom of it. If, I were you I would take to a professional, and see if you need some bearings or something before you strip something and get hurt on it.
Posted on Oct 04, 2010
How many washers go on top and bottom of a steering shaft
one on the bottom under the frame where the shaft sticks out then your nut goes on but make sure when you put the shaft in that HEX WASHER stays in place because it will move on you if u rush thru it
Aug 04, 2015 | Garden
Adjust tension on wishbone rear
For a 2004 Softail - you never gave a model year.
1. Place rear fork (3) in the frame so that
the bores in the frame align with the bores in the fork.
Insert the bushings (10) into the spherical bearings (7)
from the inside.
2. Install pivot shaft.
a. Apply LOCTITE ANTI-SEIZE to pivot shaft (4).
b. From the right side, install pivot shaft and spacers
with spacer collars facing transmission case.
c. Apply LOCTITE THREADLOCKER 262 (red) to
threads of pivot shaft nut. Install and tighten pivot
shaft nut to 90-110 ft-lbs (122-149.1 Nm).
NOTE
Proper pivot shaft tightening is important to maintain rear fork
alignment.
3. Check for freedom of rotation of the rear fork around the
bearings and that the fork and frame side members have
not been distorted when the pivot shaft nut was tightened.
4. Install the canister (California models),
fender extension (2), brake caliper and rear wheel.
5. Install both rear shock absorbers (9) using bolts and
washers (8).
Aug 31, 2013 | Harley Davidson FLSTC Heritage Softail...
I dont know exactly what happened my buddy had my bike out and wrecked it .. Looks like the front wheel came back into the radiator. Its not in the radiator now. But I know something is bent because the...
The forks usually bend well before the frame.
Take the forks off the bike and turn the chrome part in the fork leg and you will soon see if they are bent.
If they are only slightly bent a dial gauge will help.
Dont even think about having them straightened, get new ones
Jul 17, 2011 | kawasaki ZZR 600 Motorcycles
I have a 1978 KZ750 twin that will shift into neutral or 2nd gear but no other gear. I have removed the engine from the frame and removed the side covers and oil pan. I can't see any damage or debris,...
The lower fork is bent. It is impossible to just look at a fork and see the bend. Wierd that you can't see the bend, but it IS there.
Check the shat that the fork slides on to be sure it is not bent also. Bent shafts do not happen often but they do happen. The bad fork should slide freely on the shaft. Also, put the shaft on a flat surface. Roll it and look for any gaps between the table and the shaft. If a gap shows the shaft is bent.
I checked Babbitt's and it looks like they have forks and such for your bike. You might want to get fresh points, condensor, engine seals and gaskets, etc.. Please rate my answer. Thanks.
www.babbittsonline.com/pages/parts/viewbybrand/default.aspx
Aug 19, 2010 | kawasaki Z 750 Motorcycles
How to replace sway bar end links on 2005 dakota 2WD quad cab
I just replaced 2 front stabilizer links and it was easy. You have to jack up both wheels make sure you take off both front tires makes it easier too work on take the top nut off on link by stabilizer bar first if you break it off dont worry its ok then take off bottom nut from the frame where the link goes thru put in new link tighten bottom nut first then tighten top nut dont over tighten top nut to much just enough that the threaded shaft is about a 1 1/4 inches above the nut do the same on the other side.
Apr 04, 2010 | 2005 Dodge Dakota
Dont know what side the throw out bearing goes on the pressure plate or the shaft
After clutch is mounted & aligned to flywheel, bearing goes over input shaft of transmission before slid through the clutch assy, to flywheel. Don't forget bearing attaches to release fork.
Oct 24, 2009 | 2001 Hyundai Santa Fe
Just bought a 1995 GSXR 750. The front bounces quite a bit. How do I adjust the front suspension from a road setting to a drag setting. Previous owner claimed it was set up for drag racing. Dont know...
if there is an adjustment then it would be right there at the top of the larger side of the forks. you would hold it in place and turn the nut below it to the numbered setting for it. now i dont think there is one on there so you would have to get the drag forks or the fork rebuild kit to change it to drag spec.
Aug 03, 2009 | 1995 Suzuki GSX-R 750 WS
Front suspension to soft on mongoose xr-75 mountain bike
The front forks aren't adjustable, as you probably figured out. You can, however, get harder springs if the springs can be accessed at the top of the fork tube. If not, do what I did on my mountain bike. I bought a better pair of adjustable forks that I found on eBay. It will take a bit of investigation on your part regarding the dimensions of the forks, so you get the correct length and width where the forks fit onto the frame (and the overall desired fork length), but you'll be a lot happier with adjustables.
Jun 14, 2009 | Cycling
Forks are set too hard and dont give a very smooth ride and I dont know how to soften them up
dial on top of fork adjustment if not you could replace the spring inside. http://www.parktool.com/
Apr 10, 2009 | Cycling
How to adjust the fork suspension on Mongoose Iboc Style# R4654TG
there is an alan key nut usually underneath the "lowers". this takes the lowers off and thats all i know. aslo there is twist things at the top. this adjusts the rebound
Mar 25, 2009 | Cycling
Cycling Logo
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
