I need a manual for PC LINE 5.1PCL 51001surround sound speakers
THERE IS NO SOUND FROM THE SPEAKERS, TRIED BOTH FRONT AND BACK PORTS TO INSERT THE INPUT LINE FROM THE SPEAKERS
i would try some headphones in the outport port on the pc to check that your sound is working , if it is then the speakers are faulty, if it doesnt output sound through the headphones then your prolem lies with the sound card on the pc or the drivers need installing
Apr 03, 2011 | Insignia 2.1 Speaker System (3-Piece)
Can't get the volume to work.
right click on sound icon ...mute off????....all volume controlls 80%....master volume max
Go to speakers see that wires are connected correctly ... line in...line out... Microphone.in..
see if manual control is max on speakers
Nov 25, 2010 | Computers & Internet
Does the Dell Vostro 220 have built in speakers and if so how do I activate them?
No the desktop doesn't have internal speakers. Connect external speakers to the Line Out (green audio jack) for basic computer headphones and speakers with an integrated amplifier. See the manual for directions on setting up surround sound systems. http://support.dell.com/support/edocs/systems/vos220/en/index.htm Make sure the speakers are on and have power, if needed.
I hope this helps.
Sep 23, 2010 | Dell Vostro 220 Desktop Computer
I want to make mp3's from my record albums and my friend told me it would be better if I had a "line in" instead of using the microphone input. I didn't get a manual and can't easily see the rear of my...
You can use either the line in or microphone input, as long as the levels are adjusted for volume input to minimize distortion in the sound.
The speaker symbol should be clicked on on the lower bar of Windows 7 to see the graphic equalizer in windows for each input of the sound card. Other versions of windows also have a speaker symbol down below on the right, I think.
Aug 02, 2010 | Acer ASPIRE T180-UA381B DESKTOP PC
I need to knowwhat phono leads I need to connect pc to tv -sound to come out of tv-Ive a medion pc? WHERE do I connect the leads on the pc?
Normally 3 standard sockets for audio, line in, line out and mic in, that are coloured blue green and pink respectively, for audio out connect to green socket (3.5mm jack plug)
May 11, 2010 | Medion MD-1704 PC Desktop
I have my Vizio hooked up to my computer. I have a sub-woofer and speakers. How do I get the speakers to work w/tv mode. They work when I am using computer mode. I have comcast cable and box.
Good day sir, Hi, you see, the TV produces its own sound, you need to feed this sound to your PC. here are options were you need to choose.
  1. You need a separate sub/speaker system for your TV. feed the sub/speaker with the sound line out from the TV. you also need an RCA to stereo baby plug adaptor for your sub/speaker.
  2. If you want to use your PC speakers, feed the line out of the TV sound to the line in of the PC, usually the line in is the blue port, you need an RCA to stereo baby plug. then activate the line in function from the mixer volume properties. This requires that you turn on your PC when in TV mode.
  3. Simply disconnect the sub/speaker baby plud input from the PC and connect it to the line out of your TV using an RCA to baby jack adaptor. (re connect again if you want it on your PC. this is very complicated)
  4. Does your sub has extra input? like aux, or cd, or tuner? feed the TV line out to one of these extra port. use the input selector switch from TV and PC. you need an RCA to stereo baby plug connector.
I forgot to ask, Does your TV has line out? if no, you are stuck with the built-in speakers.
Dec 16, 2009 | Vizio L37 Television
I have an Olevia Syntax LT27HV LCD TV that lost sound. Do you know what board fixes this problem? The manual says maybe interface board or system board.
It depends on where you lose the sound, no sound from speakers? no audio line out?
The amplifier circuits are on the main board. You should try hooking up a powered PC speakers to the audio line out to see if you get the sound, if you do, then the power amplifiers are bad (it is a single IC Class D dual amplifiers, IC U54 on the main board)
Sep 22, 2009 | Syntax LT30HV 30 in. HD-Ready LCD...
I am purchasing a casette to cd program and need to know where the line in on the sound card plug in is
IF YOU MEAN SOUND CARD DRIVERS THEN CLICK THE LINK BELOW FOR DRIVERS DOWNLOAD
DRIVER'S LINK WINDOWS XP
DRIVER'S LINK WINDOWS VISTA 32-BIT
IF U MEAN WHERE TO HOOK UP THE CABLES FOR SPEAKERS THEN LOOK AT THE BACK OF THE COMPUTER AND YOU WILL SEE PINK, GREEN AND ONE MORE PORT WHICH IS CIRCULAR IN SHAPE, THESE ARE THE SOUND PORTS...
SYSTEM SERVICE MANUAL
DOWNLOAD THE MANUAL FOR ALL DETAILS..
IN CASE YOU NEED TO UPGRADE YOUR SYSTEM AND WANTS TO INSTALL A SOUND CARD THEN CLICK BELOW AND ENTER YOUR DELL SYSTEM SERVICE TAG...
SOUND CARD INSTALL
May 29, 2009 | Dell Dimension 1100 PC Desktop
SRS-D21 speakers need reinstall but have NO installation disc
Hi, It is simple power speaker unit and does not need any software to work.
Please check connections of speakers, hook its line wire in line-out of of PC and make sure PC have correct sound drivers installed.
Jan 09, 2009 | Sony SRS-D21 Computer Speakers
Sound not coming out of speakers
just remove the cord from CPu...the sound cord and re-plug it and try the option line out or line in...
otherwise simple way is that...check wheter there is sound installed in Control panel under the add or remove program tab....
if not,then install the driver from *********** Board CD..
simple restart the PC it is required..
and for more queries post it on..
www.vk7.weebly.com
under the guest book..
i will sort it out as soon as possible..
Dec 04, 2007 | Manhattan 1100 Computer Speakers
Computers & Internet Logo
129 people viewed this question
David Payne
David Payne
