Question about DSC GESTETNER - DSc38u Color Printer
Error message SC471
What is an SC471 error
    Problem Solver:
  • 10 Answers
This is transfer belt home position sensor error.Clean the belt and the sensor.
Posted on Oct 03, 2009
HOW TO FIX CAMERA FAILED ERROR MESSAGE.HANDLER.HANDLE MESSAGE(-1)
ERROR HANDLER.HANDLE MESSAGE(-1)...CAMERA GALAXY YOUNG......!
Sep 12, 2012 | Samsung Galaxy Y
In aficio 2228c the error code sc471...??
The unit of the transfer belt is not installed properly
Sensor defective transfer belt
Problem of unity of the transfer belt
May 25, 2011 | Ricoh Aficio 2228C Copier
We have an Aficio 2238C that is giving an error message upon startup. It says functional problem, turn off unit and turn back on, etc.... error number SC471.\r\nI have tried the "yellow...
Probably this happened after a paper jam??? Yes???
This error is related to the Tranasfer Unit.
This SC 471 can be cleared by removing and re-installing teh Transfer Unit.
If this doent work you probably have to replace a mylar. For that i advise you to call a technician
Apr 07, 2011 | Ricoh Aficio 2228C Copier
Minolta 2200 service code 16
(TABP0902037EN00) - magicolor 2200 DeskLaser - What are the steps to fix a service call 16H transfer belt rotate error on a magicolor 2200 series? (TAUS0805552EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'ACC_Getstatusr EC;Code=__D, Resetting ACC to Initial State' (q0601101) (TAUS0805008EN00) - magicolor 2 + - Installing CrownNet code on the Crown monochrome printer (q0499042) (TAUS0803976EN00) - magicolor 2200 + - Flashing System Code to DeskLaser to Correct 'Starting System Firmware Image' Message (q0202107) (TAUS0806277EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Missing' (q0800700) (TAUS0806280EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Missing' (q0800703) (TAUS0806281EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Fuser Missing (q0800704) (TAUS0806282EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Missing' (q0800705) (TAUS0806283EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Low' (q0800706) (TAUS0806284EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Empty' (q0800707) (TAUS0806286EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Fuser Unit' (q0800709) (TAUS0806287EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Life Low' (q0800710) (TAUS0806288EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Transfer Belt' (q0800711) (TAUS0806289EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'OPC Drum Life Low' (q0800712) (TAUS0806290EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace OPC Drum' (q0800713) (TAUS0806292EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Waste Toner' (q0800715) (TAUS0806293EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Life Low' (q0800716) (TAUS0806294EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Oil Roller' (q0800717) (TAUS0806295EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Input Tray' (q0800719) (TAUS0806296EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Upper Bin' (q0800720)
Dec 11, 2010 | Minolta magicolor 2200 DeskLaser Printer
Error code SC471
SC471 is a Transfer Belt HP error. The transfer belt does not lift in the rear. The rear cam (G060 3894) slips past its locking tab on the square stepped shaft and slips off the side.
The fix: reposition the rear transfer belt lift cam to lock the tab into the square shaft. Secure the locking tab with a tie wrap.
Now this is the solution if you know what you are doing on this printer. I can not even begin to tell you in this forum how to dis-assemble the printer to get the transfer belt unit out and effect this repair. IKON is pretty pricy on labor. I would see if there is an independant guy locally that can do it. Inexpensive repair that I would charge $90 or less for. If you HAVE to call IKON then just make sure they do not try to tell you that you have to replace the transfer belt unit. This repair is all that is needed 90% of the time.
Good Luck and Thank You for using Fixya.
May 05, 2010 | Ricoh Aficio CL3500N Laser Printer
How to solve error SC471 on my Ricoh alficio cl7000
This is a transferbelt home position error.
Book says:
1. Turn the main switch off and on.
2. Reset the transfer belt unit.
3. Clean or replace the transfer belt
sensor.
4. Replace the transfer belt contact
motor.
5. Check the contact and release
mechanism of the transfer belt unit.
My guess is cleaning will solve it.
open the front door and sing don the green lever
locate the 2 screws at the top and bottom of the unit and remove them.
remove the cleaning unit 1 screw and a thmb lever slide the unit out (its on rails) wipevacum and/or blow clean the unit and re assemble
also clean the connector that it plugs to in the back of the machine
(q-tip)
if it still appears belt or unit will need to be replaced
Apr 04, 2010 | Ricoh Aficio CL7000 Laser Printer
Could not create this file.Shall I try again?
Click Start
Click Run
Type CMD and press ENTER.
Enter CD \ and press ENTER.
Enter CD "program files" and press ENTER.
Do you get an error-message?
If not, that's good. If so, what's the error-message?
Enter CD "PrintMaster 2.0 Gold" and press ENTER.
Enter CD "Components" and press ENTER.
Enter CD "Clip Art" and press ENTER.
Enter CD "Travel" and press ENTER.
Enter CD "Europe" and press ENTER.
Enter ECHO Y > "Rusty Fence.jpg" and press ENTER.
Jan 04, 2010 | Encore Computers & Internet
How to solve error SC471 on my Ricoh 3800C
That is a transfer belt lift up error. The transfer belt lifts up for color and goes down for black only prints. Open right side door and check for paper stuck in the area near black rubber roller. Sometimes the belt dosen;t lift correctly. Open front door and turn knob on upper left counterclock wise to lower black transfer roller. On brown cover remove the top left screw and bottom right one (need to look on bottom side of cover) Slilde transfer unit out then back in. It is also possible the sensor inside machine is dirty.
Aug 18, 2009 | Ricoh Office Equipment & Supplies
Printer was off for two weeks and now error sc471
SC471 means: Belt tension unit cam error. Even though the belt tension unit tires to return to its home position several times, the home position sensor is not activated.
Possible Causes:
Defective transfer belt unit.
Defective transfer belt tension unit.
CN25 Pin 3 on the engine board is unable to send a signal.
Suggested fixes:
Replace the transfer belt unit.
Replace the engine control board.
Replace the transfer belt tension unit.
I would start by opening it up and inspecting the transfer belt and associated parts. Pull them out and re-seat them. Look for broken wires, stripped gears, gunk in the works. Clean it, then put it back together and test.
If you aren't up to it, it is probably time to call the repair man.
Dec 16, 2008 | Ricoh Aficio CL2000N Laser Printer
Error Message SC471 for my Richo printer
Hi there the following is taken from the service manual hope this can help you.
471 Belt tension unit cam error
tension unit tries to return to
• Defective transfer belt unit
• Pin 3 (CN25 on engine control board) unable to
send signal
• Defective transfer belt tension unit
1. Replace the transfer belt unit.
2. Replace the engine control board.
3. Replace the transfer belt tension unit.
Thanks J
Nov 18, 2007 | Ricoh Aficio CL2000N Laser Printer
289 people viewed this question
Top DSC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a DSC Office Equipment and Supply Expert? Answer questions, earn points and help others
