Question about Vacuums
Fd 400 terminal - Vacuums
Castex Scx 400
It sounds like the valve that actuates the flow of water is stuck open. Whether or not you could fix it depends on how the handle is configured. If the handle triggers something internally then it needs to be disassembled and the valve given some oil.
Mar 06, 2016 | Vacuums
Has the battery got a fuse link in it?
If you don't get any voltage reading across the + and - terminals, the battery is faulty. The aux terminals are used to sense battery temperature and charge state. You most likely have a bad battery.
Mar 05, 2016 | Filter Vacuums
Amber flashing light while on home base. New, pulled tab, placed on dock. First time said charge err1, took out battery and replaced. Now just flashes amber. Is this correct?
Your manuals are here. Flashing lights must be covered. A quick look at the site says flashing red is bin full. In fact, I found it. Flashing Amber is CHARGING.
Roomba 600/500 Battery and Charging Overview On some robots, the CLEAN light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged . homesupport.irobot.com homesupport.irobot.com/.../roomba-600%2F500-battery-and-charging- overview LabeledSupport ... clipped from Google - 12/2015 iRobot: Customer Care - Roomba 700 Anatomy homesupport.irobot.com homesupport.irobot.com/app/answers/.../a.../roomba-700-anatomy images?q=tbn:and9gcss8oogw3vmcv_uom0z_pxoi9q5tq9n4aqrcwbsxn0zd1blfvnacictdbyn iRobot: Customer Care - Roomba 700 Anatomy Solid Red = Battery Discharged; Amber Pulse = Charging; Solid Green = Fully Charged; Quick ... The battery indicator blinks when there is a charging issue. homesupport.irobot.com homesupport.irobot.com/app/answers/.../a.../roomba-700-anatomy LabeledSupport ... clipped from Google - 12/2015 iRobot Roomba 500 Series Battery Maintenance homesupport.irobot.com homesupport.irobot.com/ci/documents/.../042809_500MaintBatt_vib iRobot Roomba 500 Series Battery Maintenance Roombas "CLEAN" light should pulse red/amber while charging. ... Green - fully charged; Amber - partially discharged; Red - nearly discharged; Flashing Red - ... homesupport.irobot.com homesupport.irobot.com/ci/documents/.../042809_500MaintBatt_vib LabeledSupport ... clipped from Google - 12/2015 Roomba 400 Series/Discovery Battery and Charging Overview homesupport.irobot.com homesupport.irobot.com/.../roomba-400-series%2Fdiscovery-battery-and- charging-overview Roomba 400 Series/Discovery Battery and Charging Overview Your Roomba's POWER light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged. homesupport.irobot.com homesupport.irobot.com/.../roomba-400-series%2Fdiscovery-battery-and- charging-overview LabeledSupport ...
iRobot Owner Manuals and Quick Start Guides
Dec 31, 2015 | Roomba Vacuums
Need a wiring diagram for an Oreck XL 9100 with a amatek motor.Seen one but to small to read.
Jerry, typically the way it should be wired, is the black wire from the handle cord will go to the closest terminal on the motor from where the cord comes into the back of the power head. There should be a black dot beside the terminal. The two white wires should go to a terminal diagonal from the black wire connection and should also have a black dot beside that terminal. The other black wire should go to the terminal beside the terminal that the white wires are connected to. If there are not two terminals side by side then the black wire will go to another terminal that will be on the same side of the motor as the white wire. Hope this helps!
Jan 28, 2015 | Oreck Vacuums
How do I wire an oreck xl9100 motor
The black wire coming from the power cord will go onto the terminal closest to where the cord goes into the vacuum. Sometimes there is a black dot next to the terminal. The white wire from the cord will attach to a piggy-back terminal on the white wire coming from the lights and will attach to the motor on the other side of the motor from where the black wire attached. There may also be a black dot beside that terminal as well. The black wire from the lights will attach to a terminal on the side where you attach the white wires, either right next to them or above them on the same side of the motor. Hope this helps you.
Sep 06, 2014 | Oreck Lamp Housing with Reflector XL9100...
Power head not working
Steve:
The terminals for the power head plug into a terminal inside the machine. You'll need to unplug the machine from the wall and open the canister to find where the terminal wires plug into. You probably need to open the lower half of the canister to find those terminal plugs. It would help if you have a multimeter. The wires actually run through the hose, so I would check the hose carefully to see if the wires have been damaged there.
Jan 06, 2013 | Hoover S3670 Bagged Canister Vacuum
Connector broke off motherboard roomba 400 series. how do i fix it
replace the motherboard if you are a handyman.
replace the connector if you know how to solder
Nov 05, 2012 | Roomba Generic Discovery 400 Series...
Installed timer and I'm getting breaker pop. I've tried several different ways to wire and it keeps poping the breaker. GE Replacement Timer 15600
1) If you are replacing T103, the T103 can be wired many different ways. Not all wiring diagrams are supported by GE 15600 replacement timer that fits into Intermatic box.
2) Double check your T103 terminals
T103 terminals should be A 1 2 3 4
If terminals 3 and 4 have wires, then GE is not correct replacement.
You can buy repair parts for Intermatic timer
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T103
3) GE has terminals 1 and L which are connected by brass bridge. If brass bridge is removed, add a jumper wire and connect terminals 1 and L
GE has terminals 1-L X 2
4) Typical GE 15600 wiring shows on following link, in addition to links for parts and manual:
http://waterheatertimer.org/GE-timers-and-manuals.html#15306
White wires on terminal A connect to terminal X
Black wire on terminal 1 connects to terminal 1
Black wire on terminal 2 connects to terminal 2
Sep 11, 2011 | GE Vacuums
I have a 230 volt pump that needs 2 wires plus a ground wire.What kind of toggle switch will I need for this and how do I wire this?
If there are only two terminals on the motor the only connection would be one leg of the 230 volt supply on one terminal and the other leg on the other terminal.
The switch must be double pole, double throw. That is two terminals on top to connect the two supply wires and two terminals on bottom (that are both open when the switch is OFF and closed when the switch is ON) connect to the only two motor terminals. The ground wire grounds the motor green wire, the switch green screw (terminal) and any green wire on the supply wire.
Mar 10, 2011 | Vacuums
Model Oreck 2600HH- need schematic
white to motor terminal,black to other motor terminal,green is always ground to housing there is a small terminal tucked away its s small spot for the lights
Feb 01, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Vacuums Logo
119 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
