Question about Microwave Ovens
I appear to need a Microtemp SMCASU G4A00 240c. I had no idea what it was for sure until I Googled it. I suspected it was a fuse. I have no continuity either way. It is from a George Foreman grill that is like new. Where can I get such a critter?
    Scholar:
  • 73 Answers
Use a direct sustitute NTE8242 to replace it, check your local appliance repair or e-bay
Posted on Oct 26, 2010
Samsung Microwave Mod # SMH9187ST. Starts on its own, "bake potato" on display screen. After shutting down, code SE appears on screen. No response from keypad until unplugged. Reset and problem ret
Contact Samsung, I was having a similar problem with the SE error appearing on my microwave. Apparently its a problem with the control panel and they are going to replace it free of charge under there epidemic warranty
Mar 18, 2013 | Samsung SMH8165W Microwave Oven
How to replace a fuse
You need to remove the mains plug, remove the top cover of the oven. Make sure that you do not touch any capacitors within that can hold charge. Check the fuse on the mains power section. If blown replace with same type , move off and test on a load trip circuit as precaution. If the fuse blows then the there is short within, the magnetron, surge filters,mains capacitors and main capacitor can be a suspect.
Jan 09, 2012 | Microwave Ovens
The control panel does not appear to have any power. It does not illuminate or turn on. The matching oven works fine so I know it is getting electricity. I even checked the circuit breakers just to be...
There is a fuse inside that has blown....replacing the fuse may fix it... but there may be other problems and that is why the fuse blew in the first place...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Nov 27, 2010 | Jenn-Air JMC9158AA Convection Microwave...
Unit is totally dead. was wondering if there would
check the unit ceramic fuse located under the outer cover,its a 15 or 20 amp ceramic cartridge fuse in a clip, if the new one blows suspect one of many things,h.v. diode,capacitor,magnetron,shorted wire to case,thermal cutoff staying open.etc.,yes you can get a manual from Appliance Parts Pros web-site
Oct 12, 2009 | Microwave Ovens
GE SpacemakerXL Microwave blowing fuse
If its blowing fuses more than likely there is a short somewhere. Make sure you are putting the required size fuse in. Also never put in a higher than recommended amp fuse you could catch the house on fire.Unhook the fan motor and see if the microwave will run. Anything can be fixed but the cost of doing so may be more trying to fix, but really it could be cheaper to buy a new one instead of trying to fix that one. IMO
Aug 24, 2009 | Microwave Ovens
No sf15h250v fuse anywhere!
you just solder the inputs, extend them to your fitting needs.
Jun 26, 2009 | Welbilt MR755T Microwave Oven
Whirlpool GMC305PD -- Thee beeps and won't start
the 3 beeps are telling you that your fuses are blown
Mar 26, 2008 | Whirlpool RMC275PD Microwave Oven
GE Spacesaver microwave model: JVM1653sf001
It could be the Magnetron. First, If the unit is out of warranty, you can try to remove the rear cover (make sure unit is unplugged) and see if there is a blown fuse in the section that powers the Magetron. If all the fuses are good, I would suspect a faulty Magnetron. The Magnetron is the microwave tube which makes the food cook. They are not too difficult to replace. MCM Electronics sells them and you can call them with your model and they can find a replacement for you will be able to see how much it will cost.
http://www.mcminone.com/search.asp?keyword=magnetrons
1-800-543-4330
Good Luck,
- Jim
Jan 24, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
561 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
