Question about Maytag MSD2756GES Side by Side Refrigerator
The temp has gone done in both the freezer and fridge compartment, which part do I need to replace?
    Sergeant:
    Champion:
  • 351 Answers
Thermostat would where i would go first
Posted on Oct 04, 2010
Wat temp is for fridge and freezer to be on plz
What are your recommended temperatures for the fridge-freezers? The default and recommended temperatures for our fridge-freezers are as follows:-
4?c for the fridge compartment, 5?c specifically for the fruit and veg compartment, and -20?c for the freezer.
The ideal temperature setting for a refrigerator is 3?C and for a freezer it's -18?C. The only exceptions are fridge-freezers in the RB*** range, for which we recommend -19°C (as -18?C isn't an available option for these models).
Keep your fridge at the perfect temp with these handy tips
Dec 04, 2016 | Refrigerators
Kelvinator fridge not cooling
Try defrosting the fridge. Check the cold plate at the back of the food compartment once the fridge has been defrosted and turned back on again. The cold plate in the freezer (around the walls) will be cold to touch as will the cold plate at the back of the fridge,
Oct 20, 2013 | Refrigerators
Fridge of my Hotpoint FFA90 fridge-freezer freezes
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Mar 11, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
Fridge (KBRA22KLSS00) has lower freezer compartment. Fridge is running, & freezer is cold,however upper portion of fridge is not cold. Is there a fan or a control to bring the cold into the fridge...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 31, 2009 | Refrigerators
Zanussi fridge compartment has stopped cooling but freezer is ok
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
OR.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 24, 2009 | Zanussi ZI918 / 12K Bottom Freezer...
Refrig does not turn itself off except at very low
How to check stuff>
Jul 13, 2009 | Refrigerators
Fridge compartment is not cooling down to set temperature
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 08, 2009 | Refrigerators
Refrigerator Compartment not cooling properly: freezer compartment working properly
Check the freezer section for frost build up, there is probably a problem with the defrost cycle. 1 of 3 things defrost bi metal would be the likely problem.The back panel in the freezer should be removed to see if there is too much frost.
May 01, 2009 | Frigidaire FRT18S6AW Top Freezer...
Fridge compartment is freezing in my Hoover upright fridge-freezer. Any advice greatfully recieved. Thanks, Owen
have you tried turning down the temperature for the freezer or fridge? The fridge gets its cold power from the freezer, it is siphoned into it. So turning down the freezer temp may help but a sensor may have gone bad in the motherboard of your freezer and not closing off the vent into your fridge
Dec 06, 2008 | Hoover HCA390FFK Bottom Freezer...
GE Fridge: PSS26SGPA SS Model
CallMe-
Your "freezer" and "refridgerator" temps are not jumping back to 14 and 44 respectively. When you change temps, they both wait 3-5 seconds before they revert back to a temp reading, not a temp setting.
Does your "freezer" make any loud or thumping noises? If not, do you hear a quiet whisper when both compartment doors are closed?
Solutions could be :
1. Servicing the coolant (might have a small leak)
2. Checking the seal on your freezer compartment (black rubber that meets the metal frame)
3. Your internal cooling fan is not operating and needs replacing (but I think your temps would be significantly higher).
Best of luck.
Jul 28, 2008 | Refrigerators
Maytag MSD2756GES Side by Side Refrigerator Logo
41 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
