Question about Garmin Forerunner 305 GPS Receiver
Wont turn on
How did you find the button if it was hidden?
  • 3 more comments
  • thongdee Jun 03, 2008
    wont turn on ... please help
  • mjsruns42K Sep 11, 2008
    Garmin forerunner 305 wont turn on and does not respond in charging unit
  • smee again Sep 27, 2008
    will not turn on, as soon a connected to charger message states charging is complete, when disconnect for docking base forerunner will not switch on, place back on docking base and all works ok only while it is on the base.
  • melwarn Dec 05, 2008
    Garmin 305 doesn't turn on, and doesn't even indicate that it's charging when in the dock. I've wiped off the contacts on both the charger and the unit, and sometimes it beeps at me, attempts to turn on, but then goes blank again. What to do??
  • sub4 Dec 21, 2008
    My 305 was working fine.  Last night I charged it over night.  When I turned it on for the start of my run this morning, pressing the on switch had no effect.  It's dead.   Tried recharging, linking to computer - nothing.  completely dead.
  • 7 Answers
I faced the same problem.
Here is the detailed answer I received from Garmin support. It worked for me!
Please put the 305 on to charge. If the screen is blank, press and hold the Mode button and then press the Lap/reset button as well and hold them both for 2 or 3 seconds. After a few seconds you should see the "battery charging in progress" message. Then leave it to charge for 30 mins. While it is charging, download your training history to your PC.
Once it has charged for a while. Remove it from the charger and switch the unit off.
Press and hold the Mode button and then press the Lap/reset button as well and hold them both for 2 or 3 seconds.
Then press and hold the Mode button again and this time also press and hold the Power button. The unit should switch on and have a message on the screen saying ?Do you really wish to erase all user data?. Select YES and press enter. The unit will reboot and ask you some questions including if you have a heart rate and cadence sensor.
I then asked them again:
Before I do the 2nd step which resets the data, will it erase only the training data (tracks etc.), or also all the other user data like profile and such?
If yes, are these can be backed up too?
Why is the complete reset required if the Edge is back to life? Do you suspect some data corruption or inconsistency?
And they replied:
The complete reset is required because this could occur again in a few days time. The complete reset will wipe everything including history, workouts, courses, user profile, data field settings and almanac data.
The first time you connect the GPS to your PC after doing the reset you will get a message saying that the profile on the device is different from the profile in the program. You will need to choose to keep the profile in the program which will then transfer your user profile back into the GPS from Training Center.
Posted on Dec 28, 2008
Will not turn on
Posted on May 31, 2008
Do 2003 impala have a hidden restart button ?
Hidden restart button for ? Like fords inertia fuel cut off switch ? Is your impala's engine cranking when to turn the key to start ? But not starting an running .
Jan 23, 2016 | Cars & Trucks
Will not turn on.
Unplug the printer and turn the power switch off. Wait 60 seconds and plug it back in and try it. Sometimes there is a main power switch hidden on the back. How do you know you have power to the printer if it wont come on? If the power button is of the membraine type, ive had luck working the end of my fingernail back and forth on the button until it comes on.
Nov 08, 2015 | Canon PIXMA Office Equipment & Supplies
My craig tablet wont start up
Try factory reset. Press the hidden reset button while powering the unit. This should clear out everything that caused the hangup.
Apr 13, 2014 | Tablets & eReaders
Security alarm wont turn on
Check your batteries in the handset, make sure that all the doors, boot and bonnet are shut. Now try. .. still no go then maybe try this
There is a button hidden under the dash somewhere usually on the drivers side, put your key in and turn on the ignition then hold down the button under the dash till the alarm sounds. Turn off the alarm via the handset, or push and hold the button again. You may need to open and close the door. Lock and unlock then try again.
Feb 05, 2014 | Honda Vehicle Parts & Accessories
Rotozip scs01
I've broken a couple of Rotozips. They say there is a replacement part available from the company, but I found it much easier to just replace it, as they have hidden springs and little parts that are real easy to lose ( I tried to fix 2 of them and now have lots of spare parts for the next one I break!). I paid $25.00 and about $10.00 for shipping for the button and lost the spring, and the button is very model specific - meaning it will only work on that model!
Hope this helps!!
Nov 02, 2013 | Saws
My nook tablet by barnes and noble wont come out of demo mode
You'll have to factory reset it by turning it off and holding the home button and power button at the same time I know because I got into my hidden setting and accidently turned it on myself
Jan 08, 2013 | Barnes & Noble Nook Tablet
I have a computer running os window 7 ultimate when it on sleep mode it wont turn on any button can somebody please help me thank's
hi there,
please try to go to safe mode and then click start and open computer, hold the Alt key on your keyboard and press T, the tools box should appear then choose folder options.
Go to View, Click show hidden files and untick the three boxes that has the word hidden on it.
Click apply and Ok
Open the C: drive and look for the file called hiberfil.sys delete it and it should work.
To prevent this problem from happening again I would suggest you turn off the hibernate option for your computer.
Hope this helps!
Jul 02, 2011 | Computers & Internet
I have a Garmin C330 and it wont turn on, what can I do?
One thing you should try if you havn't already is to push the reset button. This button is hidden under the thin frame around the screen. Look carefully and you will see a little half moon cut in the frame. Slide your finger nail under and carefully pry the frame up a bit then work your way around the frame lifting as u go. Now look again and you will see the reset button.
Mar 22, 2009 | Garmin nuvi 350 GPS Receiver
RCA TH1602 MP3 Player
As you plug the device into the computer, hold down the Play button. Leave it held until you see that it is installing new hardware (something like ROM initializing). If this doesn't work, you may need to add devmgr_show_nonpresent_devices=1 to your environment variables (search that variable to find how if you don't know) and then in the device manager go to view and show hidden. Make sure the device is not plugged in and then remove all references to it in the device manager (any grey USB MSD or HID is what I removed). Now plug in the device while holding in the play button. I had to reboot to complete this part. Now you should be able to load the firmware (this was required here, it will format the device so there will be no files on it, including the ones that it shipped with).
Oct 15, 2008 | RCA TH1602 MP3 Player
Garmin Forerunner 305 GPS Receiver Logo
771 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
