Question about Whirlpool Dishwashers
My Bauknecht dishwater (GSI 4895), after few minutes from starting, shows on the panel " F4" and then it stop. What does F4 means and how can i repair it?
2 Suggested Answers
  • 641 Answers
SOURCE: What does F7 Means?
The F7 means that the drain filter is blocked or your water pressure is low. Check and clean filters. Good luck !
Posted on Jul 26, 2007
My Bauknecht GSF 6550 dishwasher is stuck with error F4. Whar does it mean ? What can I do?
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect. The error indication can be a short in the circuit, check the heater circuit and the pump motor.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.espares.co.uk/advice/dishwashers/a/3
Thank You for using Fixya
Sep 03, 2011 | Bauknecht 24 in. GSF8984 Free-standing...
Display showing f4 what does that mean thank you julie
Hello
Fault with water fill (only on machines with level-controlled fill)
1. Disconnect the power to the unit
2. Remove the lower access panels and check the tray under the dishwasher (you will probably find it is full of water)
3. Use a towel or a sponge to remove the water
4. There is a float that should stop the operation of the dishwasher and run the pump if water is in this tray. Check this pump to see if it is functional
5. Test the dishwasher
6. If there are no leaks from the dishwasher into the pan, check the drain hose under the sink
7. THE DRAIN HOSE MUST RUN UP TO THE TOP OF THE UNDERSIDE OF THE COUNTERTOP THEN DOWN TO THE DRAIN. (If the hose is not set up like this, water from the sink drain will flow into the dishwasher and overfill the tray
*Faults may vary by model. Use this as a general guide.
Aug 21, 2011 | Bauknecht 24 in. GSF8971 Built-in...
Hello everybody, I hope that you gona a give me some tips for repairing my dishwasher mashine. A few days ago, the error F2 appears on my dishwasher machine (Baucknecht GSI 5894) I checked the pump for...
Possible the inlet valve has given up and is not allowing water in.
Also possible there is a slight leak enough to shut the water off (safety feature) - Check underneath for a float mechanism and any water there.
Aug 20, 2010 | Bauknecht Dishwashers
Dishwasher stops after a couple of minutes and F4 shows on the display
the F4 problem in the Dishwasher is common, and the solution is often to replace the Water Indicator unit. This is because the light-action microswitch attached to the unit often loses its spring.
Replacement is HERE if required.
Also, dismantle the sensor unit to get all the "gunk" out. There can be a carpet of white goo covering the rubber diaphragm, get the thing out of the machine though the front bottom inspection cover.
May 08, 2010 | Bauknecht 24 in. GSF8971 Built-in...
What does F4 on microwave display mean?
This Kenmore is made by LG for Whirlpool. Confused yet? :D
F4 means you have an open humidity sensor.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site here, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
To find helpful exploded view diagrams and get part numbers, you can just enter your full model number at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
But Sears parts can usually be obtained for far less here by entering either the part number.
Apr 22, 2010 | Kenmore Microwave Ovens
I have an error code f4 on my whirlpool adp 8966 dishwasher can you tell me what it means please
F4 indicates draining failure.Your washer drain pump starts and after 4 minutes the OWI(optical water indicator) detects that mashine is 'not empty'
Posible mailfunction reasons:
The drain pump must be defective/blocked
The siphon would have got closed
The control board would have got damaged
OWI defective
Apr 04, 2010 | Whirlpool 24 in. ADP6940 Dishwasher
Hi my Bauknecht GSI 5411 dishwasher seems to starting ok but then it stops after a couple of minutes. have checked the water supply tap as well as the filter and they seem to be ok. Please help
Set the machine to the end of the drying cycle, when it has finished, try pouring boiling water into the machine about a kettle full there is a sump level control beneath the removable filter (where all the **** gathers) if this has fat deposits on it this type of problem can occur.
Nov 05, 2009 | Bauknecht 24 in. GSX7551 Built-in...
Flashing
The lights flash when the door is not shut all the way, or the sensor that detects that the door is shut is not sensing the door is shut. Try pushing in on the door while hitting the start button.
Sep 10, 2007 | Bauknecht 24 in. GSF8984 Free-standing...
What does F7 Means?
Apr 25, 2007 | Bauknecht 24 in. GSF8984 Free-standing...
Bauknecht GSX4756 dishwasher
I have this problem frequetly - it's an easy one to fix! Just press the programme button which changes the programme setting you want (on my built-in GSX4756 it's the last button on the right) and keep it pressed in until the beeping stops. Then start it again (will probably be on the rinse programme if it's like mine).
Feb 08, 2007 | Bauknecht 24 in. GSFP3988 Built-in...
Dishwashers Logo
88 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
