Question about Precor EFX 546i Elliptical Version 4
Precor ramp stuck in the up position - Precor EFX 546i Elliptical Version 4
2 Suggested Answers
bwinton
  • 83 Answers
SOURCE: The ramp will not go up or down. It's states low
The ramp system has a battery monitoring system. If the battery voltage falls below 11 Vdc when the ramp movement is initiated or the battery voltage falls below 10 Vdc after ramp movement has been initiated, ramp movement will be stopped and gives that error message. The ramp will not be enabled until such time as the battery voltage exceeds the above limits. The battery voltage must be raised to be to correct this problem either by charging or replacing the battery.
Posted on Mar 19, 2010
How do I solve Error 42?
Precor Error Code 42 Error Code: 42 Manufacturer: Precor
Model: All Models
Error Description: Error 42, Lift Position Value Out of Range. Error 42 is displayed when the lift position reported by the lift position potentiometer is found to be outside its set limits.
If an Error 42 has occurred, it is important to know the physical position of the lift when the error occurred. It is possible the lift is physically out of range or jammed. In this case, the Error 42 is a secondary symptom and the issue should be approached as an Error 40. Possible Reason:
  1. Bad or intermittent connection in the lift motor controller.
  2. The lift motor requires calibration.
  3. The lift motor potentiometer is bad.
  4. The lower PCA to upper PCA cable is bad.
  5. The lower PCA is bad.
  6. The upper PCA is bad.
Recommended Action:
  1. Intermittent connections can be difficult to locate. If the Error 42 condition is intermittent, a connection issue is probably the cause. This is definitely true if the Error 42 occurred while the lift was within its normal physical range. Inspect the lift potentiometer connector and repair connection if necessary. If the intermittent connection cannot be found or corrected, replace the lift motor. A lift calibration number of 0 or 255 indicates an open or shorted potentiometer connection. This means the problem could be anywhere between the lift motor and the upper PCA. Typically it can be identified and tracked using an ohmmeter.
  2. Using the appropriate service manual for the unit being tested, refer to the lift calibration procedure. If the information in the service manual doesn't match the lift position/physical lift position of the unit, recalibrate the lift motor. [Something caused the lift motor to be out of calibration. Investigate for cause and correct. Simply recalibrating the lift motor will not solve the problem.]
  3. If the lift calibration number is not 0 or 255 and does not change when the lift motor turns, replace the lift motor.
  4. Check continuity of the interconnect cable or swap with a known good interconnect cable to verify if cable is bad.
  5. Swap the lower PCA with a known good lower PCA to verify if the lower PCA is bad.
  6. Swap the upper PCA with a know good upper PCA to verify if the upper PCA is bad.
Lift Position Value Out of Range Precor Error 42
May 29, 2014 | Precor EFX 5.17i Elliptical Cross-Trainer...
Precor 5.17i lift wobbly
INcline it all the way up and look underneath the ramp. Check where the ramp attaches to the main frame. If there are cracks in the bottom of the ramp, you need a new ramp, especially if you have a steel ramp as opposed to alumunum.
Mar 14, 2014 | Precor Exercise & Fitness
Ramp on my precor 456i won't move
Chances are there is a stuck key on the keypad. Normally the only way to correct this issue is by replacing the overlay and keypad. http://www.sportsmith.net/ Use your serial number to find the correct item for your version.
Dec 27, 2013 | Precor EFX 546i Elliptical Version 4
Ramp is stuck
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
This is commonly caused by a bad overlay/keypad. The only solution to resolve this issue is to replace the overlay/keypad.
Please use your model and serial number to find the correct replacement at the following link: Precor Equipment Repair Parts Treadmill Belts Ramp Sleeves SPORTSMITH net
The ramp will not go up or down. It's states low battery (546i precor)
Dec 29, 2009 | Precor EFX 546i Elliptical Version 4
Precor EFX 546i Elliptical Version 4 Logo
123 people viewed this question
Top Precor Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
