Question about Soyo Dymond DYLM017A 17" LCD Monitor
MISSING POWER SUPPLY
I am looking to find the polarity of the DC adapter on my 17inch Soyo monitor. Any help on the plarity or replacement power supply source out there?
Thanks
Alan
  • Soyo Master
  • 5,568 Answers
Normally, the polarity is molded next to the connecter hole; it may not be real easy to see.
If you have a digital multimeter with a 'diode' position, most devices have a diode internally installed to prevent damage in case of a bad substitution and the meter will show a value of somewhere between 500-800, typical would be in the mid-600s.
If you find that, then the meter is currently causing the internal protective diode to conduct as it would if the WRONG polarity would be applied and most meters will supply a positive voltage to the red lead for diode function.
Commonly, the center is the positive contact but this sure isn't certain.
Posted on May 27, 2008
Computer 19" LCD Monitor with TFT 1280 x 1024 8ms DVI Connector Integrated Speakers - DYLM1967 ...: After a thunderstorm, my Soyo monitor would not tu...
If it uses AC adapter, then check the DC voltage at the DC plug to see if you get any voltage, if it use Direct power cord then it may have blown fuse inside the monitor, then you will need to open up the monitor.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 17, 2010 | Soyo TFT 19" LCD Monitor
What voltage power supply do need for the momo force feedback wheel i go one second hand and it was missing the power supply please could help?
Hi, Here all the specs of the Power adapter you looking for. Thanks and have a nice day ! J -
- Adapter model: ADP-18LB C
- Adapter Input: 200-240 V / 50-60 Hz ~ 400 mA
-Adapter output: 24.0 V - 0.75 A Output Plug - Outside Diameter (mm): 5.50
- Output Plug - Inside Diameter (mm) : 2.10
-Output Plug - Barrel Lenght (mm) : 12.00
- Output Plug - Polarity : Center positive.
thanks and have a nice day J -
Mar 30, 2010 | Logitech Momo Force Racing Wheel PC
My B70A Hyundai will not power on. The green or amber light will not power on. I wanted to make sure I have the correct Plug. Are there any drivers or is it plug & Play? Thanks Lesa LesaBrown1@aol.com
This monitor is plug and play but the driver (or lack of) is not the problem.
Its either your the power supply or the monitor itself has an issue with its
internal power distribution circuitry. First make sure your power supply is
operational. The original 120V AC to 12V DC 3.3 A power supply for the
B70A had a green LED on the brick itself. You will find it on the top right
corner of the brick, on the end where the DC cord comes out (opposite
end from the AC input) If you have the AC cord plugged in the wall, the
LED should be lit. If it isn't, the brick is no good, and should be replaced.
Any 12 VDC adapter with an amperage rating of at least 1A but no greater
than 3.3 A having the same size tip (with correct polarity) should work.
If you have confirmed that the adapter IS functional and the monitor LED's
still remain off, the internal power distribution circuitry of the monitor is
damaged, probably caused by burst or leaking capacitors.
Feb 19, 2009 | Hyundai ImageQuest B70A 17" LCD Monitor
BEFSR41 power supply?
Both the voltage and the polarity should be printed on the case of the router. The polarity should be right next to where the power plugs in.
The polarity information will look something like this:
If you take the router into a local Radio Shack, the clerk will probably be able to tell you which power supply you need.
Jan 09, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
MAG LT776s Monitor power cord
Your description is the external power supply/adapter for a Mag Innovision LT776s 17 in. Flat Panel LCD Monitor. One may be purchased here. Aftermarket/replacements may be found here, here or here. Pls verify that the plug matches the jack and the polarity is correct. Additionally, if it would be a replacement, pls check the voltage and current rating.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 10, 2008 | Mag Innovision LT776s 17" LCD Monitor
Sceptre LCD Monitor
I did not have a power adapter for my lcd monitor but after 2 weeks of searching stores, internet and universal adapters I found the power adapter for my specific monitor on ebay. If that doesn't work I would suggest a universal power adapter.
May 28, 2008 | Computers & Internet
Maxtor personal Storage 3200 Power Supply [K01PWR3200]
i own the exact same drive. i'm looking for a spare power supply, came across this website, and saw your problem. the power supply is 12 volts dc at 2 amps. the connector that gets plugged into the hard drive: center pin is power (positive) and outer "shield" is ground (negative). hope this helps.
Dec 29, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
Lost power adapter-help!
its 12V 1000Ma (1.0A) I work in radioshack... IN fact Im dealing with this problem as I speak... I need the Polarity for this however, otherwise theres a 50 50 chance this might get blown.
Dec 12, 2007 | Harman Kardon HK206 Computer Speakers
Replacement External Power Supply
So the old power supply doesn't have the output voltage, current and polarity noted on the label? What a ripoff! *grin* Did you look on the case near where it plugs into the monitor? Sometimes that will tell you the voltasge and polarity. Poliarity? Get that one wrong and the monitor could be cooked instantly! But it's usually positive. I found a completed eBay listing that had this info: "the power supply which the seller used to power up this Planar Flat Panel is inventoried as follows: ViewSonic 12V Power Adaptor Model # SYS1126-5012" I looked that one up, and it's listed as 12V at 4.17A. PC Hub has them for $28.62: http://www.pchub.com/uph/laptop/345-19804-2285/AC_Power_Adapter_5V-12V_Others_SYS1126-5012.html Good luck!
Jan 06, 2007 | Planar PL2010M 20" Flat Panel LCD Monitor
Soyo Dymond DYLM017A 17" LCD Monitor Logo
158 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Matson Kurian
Matson Kurian
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
