Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
I contacted help via the chat option...they had me reinstall the software/drivers, and my scanner still doesn't work. I can print but can't scan. I'm using WIndows 7 Home Premium edition on a brand new Dell laptop.
  • 265 Answers
If you installed a windows 7 compatible driver it should work. If the driver you installed is not compatible try running the "troubleshoot compatibility" by by right clicking on the scannner program icon then click on troubleshoot compatibility.
Posted on Oct 04, 2010
I have a Lexmark x7170 3 in 1. I got a new-ish laptop with Vista and now my scanner doesn't work. I've tried download drivers, but nothing seems to work. Are the compatible at all?
In this case Try to Do a Wia scan i will tell u how..........
Windows Vista: Go to Start/All Programmes/Windows Photo Gallery...........
There you will see an option saying File click on that and now on the drop down click on Import from Scanner or Camera.........Select ur scanner from that list and click on Import.............
If it doesnt scan and does the same thing it insists that there should be a Problem with the scanner.........
If that works..........
Software Problem.............
Uninstall and Reinstall the software................
Good Luck..................
Sep 24, 2011 | Lexmark X7170 All-In-One InkJet Printer
Can print but not scan
Issue The error message 'An error occurred while communicating with scanning device' appears on the computer running Windows XP.This error occurs while using the HP scanning software. If the error message appears on the computer while scanning from a networked product, click here to troubleshoot scanner communication errors for the networked product (c00897542) (in English). This document does not cover the communication error message on networked products. Solution Beforeproceeding with the solutions in this document, use the product to makea copy in order to make sure that the hardware is functioning correctly. Ifthe copy function does not work, this document will not help resolvethe issue. Search the HP Web site for a document covering the errormessage that appears on the computer while copying. Ifthe copy function works, try each of the following solutions in theorder presented. After completing the steps for each solution, test theproduct. If the product still does not work, then proceed to the nextsolution.
NOTE: Someof the following solutions require that the computer be restarted.Consider printing this page or creating a bookmark to it, so that itcan be referenced after restarting the computer. Solution one: Restart the All-in-One and the computer Follow these steps to restart the product and the computer.
NOTE: Make sure that the product is connected directly to an electrical outlet and not through a surge protector or power strip.
  1. Turn the power to the computer off.
  2. Press the power button (c01453128.gif) to turn off the product.
  3. Wait 10 seconds.
  4. Restart the computer.
  5. Press the power button (c01453128.gif) to turn the product back on.
  6. When the computer restarts, try the scan again.
  • If these steps resolved the issue, you do not need to continue troubleshooting.
  • If the issue persists, continue to the next solution.
Oct 31, 2008 | HP PhotoSmart C4385 All-in-One Printer
Scanning
Make sure the the scanner software is properly installed , you can check it under device manager, because if the scanner driver is not installed it wont really work..
Hope that helps........
Sep 05, 2008 | Dell 962 Photo All-In-One InkJet Printer
Hi. I bought an Epson Stylus TX210 printer not to long ago, and it was working fine. Everything except the scanner. so, my parents and I were trying to fix it and I'm not sure what we did wrong because...
im not sure what i'm and doesn't means
the drivers for the scanner might have been corrupted
you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options you can troubleshoot
hope this helps
Apr 17, 2011 | Computers & Internet
Scanner function will not work.error message--"no scan options". have reinstalled software plus downloaded software from hp website.
Cobbled together a MS scan option that works with the L7580. Not very seamless but I'm scanning, viewing, saving and emailing OK.
Still wish I could get the darn L7580 to work via the "scan" button!
John Boggess
Jan 05, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
My printer doesn`t react
Hi there, " Unplug the printer cable from the computer. " Unistall the printer drivers from Device manager and also unistall the all the printer appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the printer. " then you can connect the printer and and try to Print the test page.
Scanner: Hi there, " Unplug the Scanner cable from the computer. " Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the Scanner. " then you can connect the Scanner and and try to Scan.
Aug 19, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Computers not sensing scanner via LAN
Scanning over network usually requires software to connect. First go to the drivers page as below. Windows Vista | Windows XP, download the latest drivers (the Full Feature one) as well as the firmware update for the OfficeJet. Plus the "Update" files that's dated newer than the Drivers.
Upgrade the firmware (this will reset all custom settings in the OfficeJet like IP address) with a USB connection.
Run the full feature installer and if there is an option for Networked OfficeJet, then tick it. Also you may need to change/disable firewall for the installer to pick up the networked OfficeJet.
Scanning over the network usually connects with a customized TCP port. And most likely the Windows "Scanners and Cameras" will not pick up network scanners unless it's been defined manually (installer can do this part).
Jun 15, 2009 | HP Officejet Pro L7650 Printer
Lexmark x3550 will not scan 'Downloading Application List" and "
Had the same problem. Installed the most recent drivers. OK now. Good luck. - Kakou
Feb 05, 2009 | Lexmark X3550 All-In-One Printer
HP Officejet J5750 can't scan,fax from PC and no HP devices detected error
This issue is common with every HP scanning software used with Windows OS which have a firewall running.
If you would try the following:
- check the task bar if HP digital imaging monitor is up and running
- if not, go to C:\program files\hp\digital imaging\bin and double click the file HPQTRA08.EXE
- now the monitor should run
- if not, pls reinstall the software (*)
- if yes, pls try to open HP solution center
- if solution center starts, pls try to scan or to fax
- if successful, no other steps are required
- if faxing is not successful, check in the printer folder, if you find a HP <device name> series fax entry
- if you cannot find it, unplug the printer and delete the entries in both the printer folder and scanner folder
- also run the software CD and start the uninstall_l1.bat and uninstall_l2.bat in the util\CCC on the CD (if 64 bit OS, the run the 64 bit versions)
- restart the PC with the loaded CD
- replug the printer and let it be reinstalled
(*) For a clean reinstall it is recommended to contact HP support. They know the best way to leave a clean system on the PC.
Hope it helps.
Henning
Oct 20, 2008 | Office Equipment & Supplies
Leopard and psc 1610 scanning
First, Install the HP Software from here: http://preview.tinyurl.com/4wfxnq
Then, Search for 'scan' in spotlight or quicksilver.
Open up 'HP Scan Pro'
Choose your settings, and scan away.
Do NOT use the 'scan' button on the printer, it does not work. Ignore it and use the software.
Nov 09, 2007 | HP PSC 1610 All-In-One InkJet Printer
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
64 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
