Question about Epson Stylus C48 InkJet Printer
Me parpadean las dos luces y ala hora de imprimir me aparece este mensaje. Parts inside your printer are at the end of their service life. See your printer documentation.l
SOURCE: service life has ended on my epson stylus r320 photo printer
Thanks for your selflessness Steve H. describing the RESET procedure for the Epson R300 by simutaneouly depressing the POWER, STOP and MAINTENANCE switches.
I checked with Epson, via telephone, and they recommended going to an authorized dealer for ink pad replacement (approximately $100) or buy a new printer ( $150 - $250).
After completing your suggested RESET procedure successfully - I went a step further and mopped up the excess ink that was evident on the 'black ink pad' which was saturated with black ink. I used Kleenex which seemed to mop up the excess BLACK ink nicely, and continued this mopping procedure until there was no evidence of black ink on the Kleenex. There was very little evidence of spilled ink on the color pads.
Time alone will tell. So thanks again Steve - you saved me $100 to $200.
Oh yeah! I LOVE this printer.
Posted on Aug 21, 2008
SOURCE: Parts inside your printer are at the end of their service life. See your printer documentation
I FOUND IT! I KNOW HOW TO FIX:
This saved my printer:
  1. Unplug the power and USB cables from the printer.
  2. Prepare your work area by putting scrap paper down. Have somespare, just incase. You may also require tissue paper. It is alsorecommended you use protective gloves as the ink will stain your skinfor quite some time. Its really messy, trust me.
  3. Look at the back of your epson c46 there will be a "door" a small square that removes. Take it off.
  4. There will be 1 or 2 "spongey things" inside your printer, remove them. Sounds easier than it it. Can take up to half an hour.
  5. Take the scrap paper with the pads on to your sink, turn on the hottap and hold each one under the tap using the pliers until the waterruns clear. If you have protective gloves on it may be worth squeezingthe water out also. Don't use soap ect.
  6. It is recommended that once you have done this, you let them dry.
  7. Now return the pads back into the printer.
  8. Plug in the USB and power cable and turned it ON. (Yes the lights will still flash)
Part 2:
  1. Download and install the SSC Service Utility for Epson Stylus Printers.
  2. Select your printer and model number (There is no Stylus C42 UX, so select Stylus C4x), then close the window.
  3. You will see a SSC Service Utilitiy icon (it looks like a printer) in the system tray (next to your click), and LEFT click.
  4. A menu will appear, from here you can click on “Protection counter” (its a red cross), then “reset protection counter”. You might have to do this a few times..
  5. Turn the printer power OFF, wait 10 seconds and then turn it back ON.
Good luck guys!!
Posted on Apr 18, 2009
jasim01
  • 24 Answers
SOURCE: why my TX100 epson printer say's, Parts inside
Fiend your solution direct from EPSON. Here is your solution...
http://www.epson.com/printer/prob676ijt65/solution
Posted on Sep 03, 2009
Reset the waste ink counter!
Assuming you have completed your modification you can reset your printers waste counter using this method (I did this and it worked on the CX6400) can't guarantee it works on all)
1. You will see big button on your printer like power on (this is on the left
2. side), black & white photocopy, color photocopy, and then the stop button (these are on the right side).
3. first turn off your printer
4. push the b/w + color + stop buttons together and hold
5. push the power on button and hold (so you'll now be holding down 4 buttons together)
6. Don't release all the buttons until you see the light indicator is blinking and then a message display on the lcd
7. release all the buttons
8. push the color button (once)
9. turn off the printer
10. turn it on again
After this one may need to reload the printer driver and locate the printer!
Posted on Oct 26, 2009
DRIVER POLAROID PDR 300
Hola a todos, el grabador tiene los controles en dos circulos debajo de la pantalla, en el de la izquierda, con el grabador ENCENDIDO, debes oprimir unos segundos el boton rojo del centro que dice ERASE, y aparecera la leyenda DELETE ALL titilando 3 veces, y luego dice FORMAT, tambien titilando. En este momento oprimimos nuevamente el boton ERASE y el grabador comienza a formatearse, en la pantalla aparece el mensaje WAIT, por lo que esperamos a que termine el proceso, y LISTO!!!, cuando lo vuelvas a conectar a la PC te reconocera las 4 carpetas. Tambien yo lo formatee con la PC y estuve varios dias con este problema. Pasa que luego de un tiempo de uso, y aunque vayas borrando las grabaciones que hagas, la memoria se ocupa totalmente y te pide el formateo. Espero que te haya servido. Saludos desde Buenos Aires
Sep 20, 2012 | Polaroid PDR302 Digital Voice Recorder
Envie un mensaje ZONG AL 7557 SOLICITANDO SagaTokens, 2 transacciones estuvieron bien efectuadas, luego una quedo fuera de Linea, y luego otra fue efectuada.. La "fuera de linea" fue cobrada, mas...
Hola e realizados varias compras de cash y no me recargan los mensajes me los cobran, tengo 2 reacargas en proceso y no me ponen nada. Me llego un mensaje a mi telefono celular que decia: Disculpe, las compras con Zong se deben iniciar a traves de internet por un proveedor Zong.Si se le cobro por este mensaje, contactenos a support.vzzong.com por favor necesito respuesta rapido. gracias
Aug 19, 2011 | zong.com
Como resetear dcp165
Instrucciones para reparar el error 46 DCP-165C
Desconectar el enchufe de CA
Conectar de nuevo el cable de CA mientras mantiene pulsado el bot?n "Men?"
y manten?rlo presionado (por 15 seg)
ahora est?n entrando en el modo de mantenimiento aparece en la pantalla LCD "error 46"
Seleccione 8 utilizando el boton de flecha hacia arriba, pulse OK
seleccione 0 y pulsar OK
00:00 00:01 OK (en la pantalla se muestra este mensaje)
Presionar la tecla azul (star black) 25 veces hasta que salga PURGA: xxxxx
Seleccione 2, ok.
Seleccione 7, ok.
Seleccione 8, ok.
Seleccione 3, ok.
El contador de la purga indica ahora: purga: 00000
apaga la impresora, (desconctar el cable CA)
listo para imprimir!!!
May 26, 2011 | Brother DCP 165C Compact Color Inkjet...
No puedo sacar de la pantalla MSDC, saco la bateria pero igual no enciende.
tratar de cargar la bater?a ratos no se iniciar?. despu?s de una hora intente encender de nuevo.
C?maras MSDC puedan a su vez borrado cuando las bater?as est?n bajas. sin embargo, las luces de energ?a tal vez en pie.
May 11, 2011 | Cameras
Esta prendida la tele y no se mira nada que hago para que funcione
Hola mi nombre es Mayra Diaz con DISH Network. Muchas disculpas que est? teniendo estos problemas con el sistema. Por favor, me puede describir un poco m?s de lo que aparece en su pantalla. Aparece un mensaje usualmente puede que aparezca un n?mero de tres dijitos ala mano derecha de la pantalla. Si no ay ning?n numero si me puede dar mas detalles del problema q est? teniendo con mucho gusto le ayudar? con su problema.
Jan 01, 2011 | DISH Network IR Remote Control
Enciende y aparece el logo de la bateria y luego se apaga , y por mas que lo haga cargas mas horas sigue igual . Por favor no se sin ayudar
Si cuando te aparece el logo de la bateria, esta tiene poca carga a pesar de haberla cargado durante horas, entonces podria ser:
1) Un da?o en el cargador (en este caso igual no funcionaria aunque tuvieras la laptop conectada directamente al tomacorriente). 2) Un da?o de la bateria (la bateria no esta tomando la carga). 3) Un da?o en la fuente de poder.
Tambien te recomiendo revisar que los contactos esten limpios: 1) Donde la bateria tiene partes metalicas que hacen contacto con otras partes metalicas de la PC. 2) Donde hacen contacto las partes metalicas del cargador con las partes metalicas de la laptop.
Asi podras saber si tienes que cambiar el cargador, la bateria o si tienes que llevar la PC a un taller a que le revisen la fuente.
Oct 19, 2010 | Computers & Internet
LAS LUCES EXTERIORES NO ENCIENDEN
i am getting the problem in graphic card . dispaly cannot change ,and cannot change setting in display , plse give solution or solve this problem.
Feb 04, 2009 | Foxconn 865G7MF-SH Motherboard
Como hago para saber cuanto ...
la bateria no agarra carga, y apenas lo compre, que puedo hacer
Jan 16, 2008 | Kaser Corporation Mambo Nano(1GB) Digital...
Epson Stylus C48 InkJet Printer Logo
94 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
