Question about Dell UltraSharp 1907FP 19" LCD Monitor
My mointor pinstripes on my mointor
  • Rufus May
    Rufus May May 27, 2008
  • 46 Answers
Probably the LCD panel itself has gone bad. The tab board in usally the problem. The welds between the glass and board go bad.
Posted on Jun 21, 2008
Dell Laptop pinstripes on screen
Sounds like the Graphics Adapter has gone bad. If you connect a External Monitor do you see the same? If you boot to Safe Mode do you see the same? Has the Laptop been overheating? Has the Fan, Vents, and heatsink been cleaned recently? Any damage?
May 02, 2013 | Dell Inspiron Computers & Internet
Mointor dell flat screen
flashing amber normally just means it has gone into standby because it's not getting a valid signal, when you bought the other monitor did you use a different vga/dvi cable when you plugged it in? are both inputs the same? for more information on the padlock please read this page http://www.paulstravelpictures.com/Dell-LCD-Monitor-Flashing-Padlock-Icon/index.htm
Apr 29, 2012 | Computers & Internet
I have just bought a Verbatim 4GB PinStripe USB Drive. My Windows 7 computer at home will not recognise it, and nor will most computers at work (Windows xP Professional). The shop replaceed it, but the...
Hello John,
The Store 'n' Go PinStripe USB Drive from Verbatim has a push and pull sliding feature which protects the USB connection when it is not in use without the need for a separate cap which is easily lost.
Aug 16, 2011 | Verbatim STORE-N-GO (95312) 8 GB Hard...
DRIVE OUTPUT NOT COIMING & LCD mointor
hw to select a drive depending on current rating
Mar 13, 2010 | Lenze AC Tech Lenze 8100 AC Drive Inverter
Dell flat panel monitor -power button blinks green to amber - no
One reason that this is happening could be that it is on Power saving mode. This happens when the LCD monitor detecs an incorrect timing then thats the time that the LCD goes blank and the power botton starts to blink.
what you need to do is to turn the computer off. Unplug cables attach to the LCD make sure it is also off, once done press the power botton for a couple of 30secs to a minute and then release. After doing so re-connect all the cables and make sure that both ends is tight and secure once everything is ok turn the computer on same with the monitor to check if it solves the problem.
Jan 10, 2009 | Dell Dimension 2400 PC Desktop
Out Of Range
It means the LCD does not like the resolution or refresh signals from your video card. Try a resolution like 1024 x 768 at 60 or 72 Hz refresh.
Monitor Mike
Jan 03, 2009 | Star Logic 17" LCD Monitor
Mitsubishi WD52527 Pinstripe vertical red lines
Is the set blurry with pinkish color and white lines?
Dec 21, 2007 | Mitsubishi WD52527 52" Projection HDTV
Horizontal 'pinstripe' lines on all channels
sound like the screen control on the flyback is set just a little too high. the flyback has the red wire attached to the tube. the flyback has 2 small adjustable controls. if you look close enough 1 is marked focus & on is screen. turn the screen slightly to the left & look at your picture. the screen is like a master brightness & if it's up too high you will see what is called retrace lines. good luck.
Jan 16, 2007 | Daewoo DTQ-20N3FC 20" TV
Dell UltraSharp 1907FP 19" LCD Monitor Logo
Alun Cox
