Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Vacuum does not have suction in the base unit. All hoses have been checked and filter cleaned and dried
    Problem Solver:
  • 9 Answers
There is a pipe that can be removed on the left hand side of the dyson and a U bend pipe around the back.. Remove both and check for any thing stuck in the pipes. Failing that, turn the dyson upside down and remove the cover using a 2p and check for any thing near the roller..
Posted on Oct 04, 2010
What causes poor suction on model ud40270? It seems like a lot of air is blowing out the front where the filter is.
Susan:
First, remove and clean or replace all of the filters in the machine. There is an inlet filter above the dirt collection cup. and an exhaust filter at the front lower part of the top of the vacuum head. If either filter is clogged, you'll get poor suction. Also lay the machine on it's back, and check the tunnel where the dirt goes up into the machine (behind the beater bar) to see that it is not clogged.
Jan 08, 2015 | Filter Vacuums
My vaccuum cleaner has lost its suction, how can i fix this?
Your vacuum most likely has a clog in the hose somewhere. It's a dirty job, but usually pretty easy to fix. They usually clog where there is a bend in the hose, such as near the brushes or near the body of the vacuum itself. It would be helpful to know what kind of vacuum you have. Sometimes the bag is full and debris starts to back up. That fix is very, very easy. Sometimes there is a clog in the hose because something was vacuumed up that should have been picked up instead. I (unplugging the vacuum first) generally take apart a wire coat hanger to snake my way through the hose. You may have to unscrew the brush area of your vacuum to access that end of the hose.
May 29, 2014 | Panasonic Vacuums
My hose no longer works no suction buth the vacuume still works how do i fix I checked the hose checked the filters nothing works to get my hose so it has suction.
Check the following after unplugging the power cord from the outlet.
- Check for suction at the back of the unit, after removing the hose where it attaches to the back of the vacuum. If there is NO suction, the machine will need to be taken to a local Service Center for inspection.
If there IS suction at the back of the machine with the hose removed, please check the following:
Unplug the unit from the outlet.
- Check the Pre and Post-Motor filters for debris. Dirty filters can restrict airflow. The pre-motor foam filter is square and located in a pull out tray underneath the dirt cup. The foam filter may be hand washed in cold water with mild detergent. Reinstall the filter when it is completely dry. The post-motor HEPA Media filter is rectangular and located on the side of the machine. Note: The white HEPA Media Post-Motor Filter is not washable.
- Ensure the dirt cup is empty.
- Check the upper tank for build up or clogs.
- Twist the inner cyclone to the left and pull down
- Wipe the inside of the upper tank and separator plate with a
damp cloth moistened with water or mild cleaning detergent.
- Once the inner cyclone is dry, lock back into the machine by
pushing up and turning to the right.
- Put the dirt cup back in
- Check for good suction at the end of the upholstery hose. If there is good suction, make sure the hose is firmly connected to the lower hose on the back of the vacuum. If there is no suction at the end of the hose, check the hose for splits, cracks or clogs.
- Make sure the brush is rotating. If it is not, remove the access plate and examine the brush, and belt for damage. The access panel can be removed by lifting the 4 tabs located at the bottom of your machine. Lift tab 1 then 2-4 tabs to remove the access panel.
CLEARING CLOGS
- Detach the upper hose from the machine. Insert a broomstick into the hose to push any obstruction through to the opposite end.
- Remove the screw from the left side of the lower hose on the back of the unit, and straighten this section of hose by pulling it down or lay the unit out flat, and roll the unit on its side with the lower house towards the top side. Look through the hose for any obstructions. Push a broom stick through the lower hose to unclog.
Aug 12, 2010 | Bissell Upright Vacuum - The Pet Hair...
Model UH60010, Series X12.0, Mfg code K09A. While attempting to use the hose and the extensions to clean shelves, my wife reported no suction. I removed the brush roller and the plastic piece just below...
There are six different reasons a vacuum can lose suction, a plugged vacuum hose, bad motor, full vacuum bag, or cracked or damage hoses. Purchasing a vacuum cleaner can be a costly expense while repairing the suction on the unit can be virtually free. Most suction loss problems on a vacuum can be easily fixed or remedied with common house hold tools and very little technical expertise.
If your vacuum cleaner losses suction, the first and easiest solution is to check the bag. If the vacuum cleaner bag is full suction will be greatly reduced and the unit will become ineffective. A vacuum cleaner works by passing air through the bag fibers leaving dirt and debris behind inside the bag. If the refuse bag becomes full, airflow is restricted, limiting the amount of air passing through the vacuum bag resulting in loss of suction. When replacing the vacuum bag always consult your owners manual to insure that the vacuum bag seals with the vacuum inlet hose. If your vacuum cleaner bag is not tightly sealed to the vacuum inlet hose you will decrease the air flow through the bag resulting in loss of suction.
The second and sometimes most common reason for loss of suction on a vacuum cleaner is a plugged vacuum hose. If the hose becomes plugged, air flow will become restricted. To unplug a vacuum hose detach it from the machine and inspect the inside. If there is a restriction in the hose, remove it with your fingers and replace the hose onto the unit. If the hose is long and the debris is hard to get too, a broom handle or other long object can be passed through the hose to dislodge the debris. Most vacuum cleaners contain more that one suction hose, so make sure to check each one by process of elimination. Another area that can become easily plugged on a vacuum cleaner is under the lower base of the unit by the roller brush. Large debris can get caught in this area and restrict air flow to the hose.
If your vacuum refuse bag is not full and the suction hoses are not plugged the next thing to check is the condition of the hoses. Many hoses are made from plastic which can easily tear or crack. If your vacuum cleaner shows signs of wear or are cracked they need to be replaced. Even the smallest hole in a vacuum hose can leak enough air to greatly diminish the suction potential of your unit. Replace your vacuum cleaner parts with OEM parts from the original manufacturer to ensure the tightest fit.
Most vacuum cleaners contain filters. Filters are used as a last line of defense to remove dust and smaller debris particles before the air is recycled back into the environment. If vacuum cleaner filters become dirty or plugged they also can decrease the amount of air traveling through the unit. Some filters can be easily rinsed with water whereas others need to be replaced. It is important to check your owners manual before rinsing a vacuum filter.
The last and probably least common problem for a vacuum cleaner to loose suction is a bad or failing vacuum motor. Over time vacuum motors lose power due to worn carbon brushes or long term damage. A vacuum cleaners worst enemy is moisture. If water or moisture is sucked into the vacuum motor it will greatly diminish the amount of suction the unit has. Replacing a vac motor can be a costly and time consuming ordeal. In some cases, replacing a vacuum motor can outweigh the cost of buying a new vacuum. Vacuum suction is measured in water lift which can easily be measured by using a water lift gauge. If the water lift measured in inches, falls below half the original water lift specifications for the unit, it is time to replace your motor. Most vacuum cleaner repair shops carry this type of equipment and can easily tell you if it is time for a new vac motor.
Jul 25, 2010 | Vacuums
Do07 not picking up out only suction with hose
Check and clean filters, looking at it from front filter is located in base on right hand side, take out filter clean sponge and let it dry overnight. see here page 5
http://www.dysonmedic.com/PDF%20docs/dyson_dc07_owners_manual.pdf
Mar 01, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
The suction on my eureka optima stopped working but the roller still works, what might i do to fix it?
Hi there. Most suction problems are due to a blockage. Start with the base and look carefully for debris that is stopping air flow. You may have to remove the base plate to get to the problem. I am including a link to the manual for your machine. look on page four so see how to remove the base and check for blocked airways. http://www.eureka.com/service/manuals/75287_eng.pdf
Aug 19, 2009 | Eureka 431A Optima Bagless Upright Vacuum
Bissell ProHeat 2X(9200) hose to cleaner solution no suction
There are a couple areas to check:
1. The black gasket where clearview water collecting unit and the base's front meet. Ensure gasket is in good condition.
2. Check if you're getting sufficient suction: remove the water collecting unit. When you turn on the the unit, you'll feel suction out of a black hose pointing upwards next to the grey dial. If you're not getting sufficient suction you need to check that all the gaskets are seated properly. there are 3 gaskets: (1) an orange one seated between the black hose and the base unit (2 and 3): On the bottom of the unit there is a removeable panel. This panel has a gasket (red) and inside there is a white gasket.
Jun 30, 2009 | Bissell 9200 Upright Vacuum
Vacuum hose has little suction.
There is most likely a clog in the hose. If the hose has poor suction the foot probably has poor suction as well seeing that the hose is what gives the foot assy suction.
Jan 05, 2009 | Bissell 6594 PowerForce Bagless Upright...
Losing suction filter clean,hoses clear,output blower good,but very poor suction
if the blower is much stronger than the suction, you may have an air leakwhere the cover fits on tank or possibly a warped tank or cover. feel all around the unit for air being drawn in somewhere besides the hose. try it without the hose on and block the inlet for a couple seconds to see if the unit leaks air in. also replace the filter , dont try to clean it, the pores clog and reduce suction and damage motor.
Jun 11, 2008 | Craftsman 17765 Canister Wet/Dry Vacuum
Bissell lift off pet-no suction through base (hose is fine)
I had a similar problem with mine. When you take the collector container out, if you reach your hand up, you will fill a round, plastic piece. Gently turn it and the piece pulls out. On the outside of the piece is a foam filter that may be plugged. There is another filter underneath the collection container in a pull-out drawer. Both filters can be washed with cool water, allowed to dry totally, then replaced. I understand that both of these filters need to be washed "frequently". It worked for me, hope it works for you.
May 08, 2008 | Bissell 37604 Lift-Off Pet Bagless Upright...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
50 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
