Question about Kenmore 15864/15862 Top Load Washer
Strong Musty odor
My Kenmore 80 series washer has a strong musty mildew odor. I would like to clear that up. Clorox and hot water thru the system doesn't help. Drains are OK.
  • Anonymous Jun 03, 2008
    MY KENMORE 80 SERIES WASHER HAS A STRONG MUSTY ODER - THE WASHER IS ABOUT 4 YRS OLD -THE SMELL JUST STARTED ABOUT 3MONTHS AGE - I HAVE TRIED CLOREX,TILEX, PINE-SOL BUT THE SMELLSTILLCOMES BACK
You will have take it apart, removing the wash tub and all top plastic parts. I just finished taking mine apart do to a mouse that chewed a larg hole in my water tub, and notice tons if old gunk mold and build up. It smells and will not go away unless you scrub it. Sorry to say it is all internal pouring clensers will only wash thru the tubes.
Posted on Jun 22, 2008
Musty smell
The "MAX" line indicates how much liquid must be in the blue dispenser cup before it DISPENSES from the bottom of the cup.
This is a very, very frustrating mistake that gives owners much grief.
After three months of incorrect type of detergent or incorrect amount of the correct detergent used--musty odor begins to occur.
After more than two years--a significant amount of soap ****/curd has accumulated in the washer. Odor-causing bacteria flourishes on this build-up.
It is imperative to remove this slimy residue. Tide sells a product called
"TIDE WASHING MACHINE CLEANER" which is very effective.
Service manual and more can be found at this BLOG of mine
Jun 12, 2012 | LG Washing Machines
My washing machine has a strong mildew, musty smell when we haven't used it for a day. Cleaned the tap in lower left corner and use the HE soap. Help!!
Hello Friend, Your problem is simple to resolve. This is a common issue. It is possible that the water quality being delivered to the washer could contain higher than normal amounts of micro-organisms causing the growth of mold and mildew. Basically what is happening with your washer, when not in use the washer door remains closed trapping in moisture which is the perfect invironment for mold and mildew to grow. You should run a large empty load with bleach and from now on just leave the washer door partially open when not in use. This should resolve your problem. Happy to help, Tim.
Jun 26, 2009 | LG Washing Machines
1994 Kenmore 90 series washer smells musty
Do a boil wash without clothes & detergents, with a cup of bicarbonate of soda in the soap drawer.
Mar 30, 2009 | Kenmore Washing Machines
Duet washer has a strong odor when draining
you might be getting "sewer gases" from your drain, but most likely your washer is the cause of the odors.
does it also smell musty when you get your clothes out?
whirlpool makes a product called "affresh" that is specially designed to clean out the residues from a front load washer.
you can find them at sears or lowes and the come in a package of 3 tablets. run a tablet on the clean cycle or on whitest whites or the longest cycle you can choose, use hot water and a second rinse option.
also to prevent this odor in the future make sure you are using only HE type soap and dont use too much. the least amount should do well to clean any clothes.
Feb 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Musty odor in laundry
I would say that you are getting a build up of soap and oil from our bodies, on the inside of your wash bowl.
The Tubs pull out of the washing machine really easy and then you can water blast the two tubs.Solves this problem?
Once you learn how to pull the tub out you can also clear a blocked pump.
I have a after market lint filter fitted to my F&P washing machine,works wonders .
ask your local whiteware Man for some hints on a Bowl removal.
A five minute job???
Jul 27, 2008 | Fisher Paykel EcoSmart GWL15
No matter what i do our clothes and washing machine always smell musty, is it our hard water?
have you tried filling tub with hot water and 2-3 cups CLOROX CHLORINE bleach and letting it wash a few min then letting set for 30-45 min ? bargain bleach tends not to be as strong as the old fashioned stuff also leave lid open as much as possible same applies if front load except wash door boot out inside inner lip.. roll back to clean with bleach solution
Jul 24, 2008 | Maytag Washing Machines
Musty smell
probaly a good wash with chlorine bleach..fill tub with hot water pour 2-3 cups bleach let agitate for few mins stop machine and let set 20-30 mins restart and let finish cycle ..to head of future problem leave lid open between uses
May 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Bad Musty Moldy Odor in Washer
Run a wash on the highest temperature, and add some vinegar into it. May do this more than one time. Be strict to wash on the higest temp some times in the month.
Good Luck
Jan 24, 2008 | Siemens WFXD8400UC Front Load Washer
Kenmore 15864/15862 Top Load Washer Logo
266 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
