Question about Craftsman Garden
I have a 25cc craftsman leaf blower model 358.794740 pull starter rope broke. how hard is it to change?
2 Suggested Answers
  • 10 Answers
SOURCE: broken pull starter rope
remove pulley that rope goes on, wind it with new rope, wrap it till it is full, then feed rope thru hole in housing, put pulley back in place, put rope thru pull handle, pull thru till you feel spring catch tie a knot and that should do it......be careful when removing pulley not to dislodge recoil spring
Posted on Oct 22, 2009
How to repair rope pull in craftsman weedwacker gas trimmer model No. 316.791940"?"
If you go to searspartsdirect.com an enter the model number for your weedwacker if will show you a diagram of how to remove the rope pull. Hope this helps.
Sep 26, 2016 | Craftsman Garden
Pull string broke how do I replace it
Don, Instead of me writing a book to ya on how to do this. A much much easier way to do this is to go on you tube.com
In the search menu, type in how to replace starter pull rope on (make) leaf blower...etc..
This way you will have visualization to go along with the instructions.
It's not super difficult, you can do this!! Good luck
Oct 18, 2015 | Troy-Bilt tb4bp ec backpack gas leaf...
I can't pull the starter cord. It is stuck
You have one of three problems.
1) The engine is flooded/hydrolocked. Pull the spark plug and see if the pull starter frees up.
2) Unit was left out and got wet. Take starter assembly off unit and see if is rusty and shoot penetrating oil into spring housing avoiding the rope area.
3) Damaged starter assembly from animal infestation or debris sucked in from leaf blowing. All you can do is buy a replacement unit and swap it up.
Good luck and be safe!
Mar 06, 2015 | Husqvarna Backpack Blower 25cc, 140 Mph,...
Need repair manual craftsman yard vacuum model 247.77013.0
Go to searspartsdirect.com and enter the model number and it will give you an options for the manual. Hope this helps.
Aug 01, 2014 | Craftsman Yard Vacuum System 4 in 1 190CC...
I have a craftsman blower 358.797130 and the pull core broke .i have taken everything apart but can not get the pully off the seal o ring seems to be stoping it help the manual is no help
Yes, owner operator manuals cover very little in the way of repairs. If you have the unit taken apart down to the starter/recoil unit and you want to replace or rewind the rope on the pulley...it shouldn't have to be removed, unless the starter spring has broken. These units have a cheap starter system that wears easily and causes the problem you have. If you can, preload the spring (before installing the rope ) by turning it several times in the tension direction and then hold it in place and install the rope, Observe how the old rope is looped around the inner core of the starter if you install new rope.
Aug 06, 2010 | Craftsman Garden
I have a craftman leaf blower model#368794963 hand held 25cc it was running fine but now it wont start
hello
if you have spark remove the sparkplug and priming the engine(put some gas in sparkplug hole into the cilinder).Pull the rope for starting engine as many times as you need until the engine starts but without any choke and the switch on the on position.Please let me know what is going on.
regards savumihai71
Nov 04, 2009 | Craftsman Garden
Broken pull starter rope
Oct 22, 2009 | Garden
Pull starter handle is locked in it's orginal position,pulling on the handle does nothing
Unless the starter rope jumped track and is causing the problem, it sounds like the engine is locked up.
Sep 20, 2009 | Craftsman 4 Cycle Blower/Vac
Garden Logo
73 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
