Question about LG Flatron L1710S 17" LCD Monitor
Using menu on lg monitor
How do I use the on screen setup buttons
2 Suggested Answers
SOURCE: LG monitor model no: L1900RQ how to get to the monitor menu??
http://www.lge.com/products/sidemenu/list/normal%20lcd%20monitor_PRD%7CDWN_down%7Clist.jhtml
Posted on Nov 10, 2008
  • 3 Answers
SOURCE: Setup and Menu buttons do nothing on my LG LHT854
You need to press "Input" on the remote and keep pressing it until you get to the connection that you are using (e.g.: HDMI, etc). Once on that, you can use the setup screen. It took me several hours to figure that out.
Posted on Nov 26, 2008
How do I unlock screen controls for LG W53 27" monitor?
Press and hold the Menu button for several seconds to toggle the OSD (on-screen display) Lock on and off. The Menu button is the third button from the left in the group as you look at the front of the monitor. You should see a message on the screen when the OSD lock is disabled.
The OSD Lock feature is described in the manual and is the same for all W53 monitors. See http://www.lg.com/us/support-product/lg-W2753VC-PF for the manual of one of the monitors. The direct link to the manual came up as http://www.lg.com/us/lgecs.downloadFile.ldwf?DOC_ID=KROWM000230850&what=MANUAL&fromSystem=LG.COM&fileId=KROWM000230850.pdf&ORIGINAL_NAME_b1_a1=W2753VC_EN.pdf .
I hope this helps.
Apr 12, 2016 | LG Computers & Internet
Best way to remove a parental lock from a lg plasma tv
LG Service Menu Instructions
Method 1
Press and Hold <OK> button on remote as well as TV panel at the same time for a few seconds.
Method 2
Press and hold the {MENU} button on the remote and the {MENU} button on the TV at the same time for at least 5-7 seconds.
Method 3
Press and hold the {MENU} button ON THE REMOTE until a 4-digit password screen is displayed.
LG Service Menu PIN/Password Codes
  • 8 7 4 1
  • 8 7 4 3
  • 7 7 7 7
  • 0 0 0 0
  • 8 8 7 8
  • 0 4 1 3
LG LCD Monitor Service Menu Instructions
  1. First turn off the lcd monitor, then press and hold the "MENU" button, then turn on the monitor. Release MENU button after the monitor is turn on.
  2. Press "MENU" button to open the OSD menu, at the bottom of menu, you can see a new selection to go into the factory service mode. Inside the factory service mode, you can see useful information like, product model, manufacturer date, F-ENGINE chipset version, lcd panel number and etc.
Mar 16, 2016 | LG Televison & Video
Message volume fixed
Zone 2 Setup on the RX-V773 using the ZONE2/PRESENCE Extra Speakers The RX-V773 extra speaker terminals can power one set of speakers for Zone 2 or Presence speakers. If the extra speaker terminals are utilized then the RX-V773 cannot be set for Bi Amp (Surround Back/BI-AMP terminals). Setting the Extra Speaker Terminals Note: The RX-V773 remote control will be used to access the On Screen Menu of receiver. 1. Press the On Screen button on the remote control to enter the On Screen Menu. 2. The On Screen display should be displayed on the TV/Monitor. 3. Press the Arrow Down button on the remote until Setup comes up in the screen. 4. Press the Enter Button on the remote control. 5. The Setup Menu will come up across the TV/Monitor screen. 6. Use the Arrow Left & Right buttons on the remote to navigate to Speaker. 7. Press the Arrow Down button on the remote to select Manual Setup. 8. Press the Enter Button on the remote control to enter Speaker Manual Setup menu. 9. Speaker Manual Setup menu with Power Amp Assign highlighted will come up. 10. Press the Enter Button on the remote control to enter Power Amp Assign menu. 11. Speaker Manual Setup, Power Amp Assign menu will come up with Basic highlighted. 12. Press the Arrow Down button on the remote to select 7ch+1ZONE. 13. Press the Enter button on the remote to select 7ch+1ZONE. 14. Press the On Screen button to exit the on screen menu. To control Zone 2 using the RX-V773 remote, the switch at the upper left side (above the BD/DVD Scene button) of the remote must be set to Zone 2. To see the operations on the front of the Yamaha receiver you must press the Zone Control button on the front of the receiver. Note: Only analog signals can be sent to Zone 2. If you want to output the sound from Zone 2, connect an external component to USB Thumb drive, USB iPhone/iPod, Network, AV 5-6 or Audio 1-2 by analog connection. For AM/FM radio the antennas must be attached.
Aug 19, 2012 | Yamaha RX-V773
LG20" monitor. Suddenly a red
Try to reset it
Scroll through the menu options by using the up and down arrow buttons located just under the "Menu" button. Scroll down to the "Setup" icon, which looks like a big cog. Press the "Auto/Set" button to access the Setup menu. Scroll, using the down arrow, to "Factory Reset." This setting is located at the bottom of the Setup menu. Press the "Menu" button on the right side of the monitor. This will bring up the On Screen Display. If nothing happens when the "Menu" button is pressed, press and hold it for several seconds to unlock the On Screen Display. Press the "Auto/Set" button to choose "Factory Reset" and then press the down arrow to reset the monitor.
Jul 23, 2011 | LG Computers & Internet
How do I reset an LG L1751S-BN back to factory settings?
You may reset your LG L1751S-BN to factory settings by:
1. Press the Menu button. OSD (On Screen Display) should appear on your LG L1751S-BN.
2. Press the Lightview +/- button to highlight Setup then press the Auto/Set button.
3. Press the Lightview +/- button to highlight Factory Reset then press the Auto/Set button.
4. Press the Menu button to finish.
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Mar 29, 2011 | LG L1751S-BN 17" Flat Panel LCD Monitor
SCreen resolution to bright
You need to decrease the brightness of your screen by using the buttons on you LG monitor. Push the menu button and then navigate to and select brightness. Now use the left or right arrows to either increase or decrease the brightness.
All the best!
damnor01
Nov 06, 2010 | LG Monitor
My W2253TQ developed a shadow across half of the screen (verticle)
I had the same problem and fixed it with a factory reset, which is done by pressing the menu button, selecting "setup" button, then continue pressing the autoset button on your monitor until "factory reset" is selected. Press the f engine button on your monitor and it will do the factory reset.
Oct 25, 2009 | LG Computers & Internet
LG W2452T monitor not filling entire screen. How do I get it to work?
Use the menu buttons on the monitor to adjust horizontal and vertical size or press the auto button if it has one.
Jun 10, 2009 | LG Flatron L1718S LCD Monitor
Nov 21, 2008 | LG LHT854 Theater System
LG 19 in monitor
it would be helpful to know which monitor you have - each one is a little different... basically, you need to press the "menu" button on your monitor, use the arrow buttons (on monitor, not keyboard) to get to the brightness adjustment screen, hit set, then adjust with arrow buttons, and hit set again, then menu to exit.
Jul 14, 2008 | LG L1915S 19" LCD Monitor
LG Flatron L1710S 17" LCD Monitor Logo
419 people viewed this question
Top LG Computers & Internet Experts
Brian Sullivan
Brian Sullivan
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
