Question about Hotpoint Aquarius WF000 Front Load Washer
Machine fills with water even when switched off at the mains
    President:
  • 670 Answers
Sounds like you have a problem with the inlet fill valve. Normally it requires power to allow water into the washer. There might be an obstruction that is preventing the valve from closing when the machine is off. Have the valve replaced, and it should fix the problem.
Posted on Oct 04, 2010
How to fix a bosch dishwasher?
Run away. It is not a do-it-yourself project, as these machines are complicated beyond normal reason... Call a technician, trust me.
Jul 08, 2016 | Bosch Dishwashers
My ultima1000, wm 71 says error 10 sometimes and error 11 mid way thru a cycle. The pipes are fine and water is on what could be the problem?
E10 No cold fill detected - washing machine does not fill
  • Check mains water pressure
  • Check inlet hoses for kinks
  • Check inlet filter
  • Check water inlet valve
  • Pressure switch fault
  • Wiring fault
E11 Not hot fill detected - washing machine does not fill
  • Wiring fault
Apr 11, 2016 | Washing Machines
My washing machine starts then loses power once its filled up with water like complete power gone you have to unplug it then replug it 10 or so minutes later
Possible that when the water is filled and is ready to switch on the motor there is a connection issue due to a loose connector or a fault in the mains outlets. Please trace this to ensure that the mains supply stays even when it is seen to be power off after initial start.
Also check the mains power on the board, possible there is fault on the drive circuit or finally it can be due to a processor issue.
Sep 27, 2013 | Washing Machines
Washing Machine on the blink mainly due to no spin/drain cycle wo
check your drain filter, get a wet vac and vacuum the water out, then open the drain plug at bottom and try to vacuum the drain to clear out debris......then turn on and test washer if it fills and drains if it fills with water and doesn't drain then your drain pump is defective........get your model number and source for a pump motor.................................
if it doesn't fill with water then your water fill switch is defective...............source for parts..............
if this helps out anyone a feed back would be good..........
Apr 16, 2010 | Miele Novotronic W1918A Front Load Washer
Help! My fisher paykel washing machine won't stop filling up!
If the water continues to fill even if unplugged the water valve is sticking and needs replaced. if removing power turns the water off the water level pressure switch is bad or there is something plugging the sensor tube somewhere.
Eric
Nov 22, 2009 | Washing Machines
Bosch continues to fill when rinsing even when the machine is off
The inlet valve is stuck open most commonly , you can check this by taking the wires off the valve and then turn everything back on , if the water is still flowing replace the inlet valve.
Phil
Apr 14, 2009 | Washing Machines
Dishwasher filled with water even though cycle was finished.
the same problem accures with some types of washing machines,when you turn on the machine the control switch sends a signal to a valve on the mains water supply inside the back of your machine telling it to open the problem accours if you live in an area that has hard water because lime scale builds up in this valve so when you switch it off the valve is in the open position because of a lime scale build up, i would say it needs an new valve.adrian
Dec 16, 2008 | Maytag MDB9600A Jetclean II Built-in...
Washer Dryer - drum is filled with water even when switched off and door can still open!
Try the valves inside the back where the water hoses connect to the machine they should default to the closed position when water is not required
Oct 31, 2008 | De Dietrich LZ9619 Front Load Washer /...
Frigidaire Front Load Washer
your timer has contacts inside of the main module that makes your machine switch cycles even though it may be going round the contacts are probablyeither burnt or carboned up so bad they are not making contact the fact that it is going round pretty well confirms with me thats your whole problem good luck
Aug 26, 2008 | Frigidaire ATF6000ES Front Load Washer
E60 error code
Found These Fault Codes On Internet, Hope This Helps, Daz
ALARM CODES
E00(E00)- Problems with water fill during washing
-Tap closed; solenoid valve, water distributor, wiring ,main PCB, pressure switches
E01(E00)- Problems with water fill during drying
-Tap closed; solenoid valve, wiring , main PCB, pressure switches
E10(E10)- Problems with water drain during washing
-Drain hose kinked, filter blocked, drain pump, water distributor, wiring , main PCB, pressure switches
E11(E10)- Problems with water drain during drying
-Drain hose kinked, filter blocked, drain pump, pressure switches
E20(E20)- Door open
-Cycle in Door delay, wiring , main PCB
E21(E20)- Fault in door delay power triac
-Wiring , main PCB
E30- Fault in electronic pressure switch
-Electronic pressure switch, wiring , main PCB
E31- Fault in electronic pressure switch circuit
-Main PCB (fault in electronic pressure switch circuit)
E32(E10)-Calibration error in electronic pressure switch
-Electronic pressure switch, drain pump, wiring , main PCB, filter blocked
E33- Incongruency between electronic pressure switches and safety switch 1
-Electronic pressure switch, safety pressure switch,wiring, main PCB
E34- Incongruency between electronic pressureswitches and safety switch 2
E35- Intervention of anti-overflow pressure switch
-Solenoid valve, water distributor, wiring, main PCB,anti-overflow pressure switch
E36- Water leakage (maximum number of resets exceeded)
-Water leakage, drain hose too low, pressure switch,wiring, main PCB
E40- Motor power triac short-circuited
-Main PCB (triac short-circuited)
E41- No signal from tachimetric generator
-Tachimetric generator on motor, wiring, main PCB
E42- Fault in tachimetric generator circuit
-Main PCB (tachimetric generator sensing circuit)
E43- Intervention of motor overload protection
-Motor, wiring, main PCB
E50- Insufficient heating during wash phase
-NTC sensor setting incorrect, heating element, wiring,main PCB
E51- Overheating during wash phase
-Heating element (to earth), main PCB (relays)
E52- Insufficient heating during drying phase
-NTC sensor setting incorrect, safety thermostat,thermostats, drying heater, wiring, main PCB (relays)
E53- Overheating during drying phase
-Drying heater (to earth), main PCB (relays)
E55- Fault in power relay for heating element (K3)
-Safety pressure switch 2, wiring, main PCB- 6 -
E60- Fault in washing NTC sensor
-Washing NTC sensor, wiring, main PCB
E61- Fault in drying NTC sensor(condenser)
-Drying NTC sensor (condenser), wiring, main PCB
E62- Fault in drying NTC sensor(duct)
-Drying NTC sensor (duct), wiring, main PCB
E63- Fault in 1/2 power thermostat
-Drying NTC sensor (duct), 1/2 power thermostat, wiring,main PCB
E70- Power triac to distributor motor short-circuited
E71- Fault in power relay to distributor loads
-Main PCB (relay open)
E72- No distributor position signal
-Water distributor motor, wiring, main PCB
E73- Incorrect timing on distributor contacts
-Water distributor, wiring, main PCB
E90- Fault in tank fill pump
-Hoses obstructed, tank fill pump, wiring
E91- Fault in tank drain pump
-Hoses obstructed, tank drain pump, wiring
E92- Fault in power triac to tank fill pump
-Tank fill pump, wiring, main PCB
Jan 04, 2008 | Zanussi ZWF1440 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
