Question about Maytag Refrigerators
Our refrigerator isn't cooling. We have the MSD2650KES
    President:
  • 1,099 Answers
Not cooling is a fridge repair job that you can do without the help of a professional. Often the fridge has a frost-free failure, or the compressor is faulty but there are many other reasons for a fridge not cooling properly.
Step 1 - Find the Problem
Your first job is to locate the source of the problem. Consider each of the following:
* Gaskets - Make sure the gaskets/seals are not torn and are sealing properly.
* Evaporator fan - Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches).
* Air damper - Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section.
* Condenser coils - Check to see that the condenser coils don't have a dust build-up and that the condenser motor is working.
* Compressor - Make sure your compressor is working with on and off clicking noises.
Step 2 - Frost-Free Failure
This is the most common cooling problem in fridges. Expose the evaporator coils by accessing the panel in the freezer section. The coils in the freezer section can sometimes get clogged up with frost. This can stop the evaporator fan motor from blowing cold air around, or cause the fan to hit it and stop, or become noisy. The defrost timer can be a bit tricky to find but it is usually located behind the back bottom corners of the fridge, although they can sometimes be found in the ceiling of the fresh food section, or behind the cold control cover.
Step 3 - Find the Timer
When you find the timer, turn the wheel-like screw slowly with a screwdriver until the fridge shuts off. The refrigerator is now defrosting. If you find that the fridge starts now, you will need to replace the defrost thermostat and the defrost timer.
Step 4 - Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven't got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
If there is a ticking or squealing noise in the defrost timer, or it seems hot to touch, replace it.
Many fridges have and inline fuse on both sides of the defrost heater. You will need to replace the whole heater if one of those fuses blows. Check these fuses with a volt meter if the defrost heater doesn't work.
A quick check if you have a cooling problem is to inspect the evaporator coils. If there is a build up of white snow on the coils, this indicates a frost free problem; if there is balled ice on part of the coils with the rest bare, this indicates a system problem, like a problem with the pumping compressor.
Hope this helpout in solving the problem.
Posted on Oct 04, 2010
My refrigerator freezer is working but my refrigerator isn't
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 30, 2011 | Microwave Ovens
The freezer side is cold & food is frozen, but the refrigerator side isn't keeping food cold. Its warm!!
heatman101
Aug 28, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer works great but refrigerator. Doesn't get cold its cool but not cold turned thermostat to 33 and ut isn't gettingcold
heatman101
Aug 21, 2011 | Kenmore Side by Side Refrigerator
Freezer is cold, refrigerator isn't
heatman101
Jul 26, 2011 | Refrigerators
I have a sharp refrigerator - freezer. SJ-48L-SL1 The freezer is colding but the refrigerator section isn't.
heatman101
My refrigerator isn't cooling. The freezer is working fine though. Any suggestions?
heatman101
Jul 07, 2011 | Refrigerators
Frigidaire FRS22ZRF side by side. Freezer works but the Frig isn't cooling. Anyone know what the problem could be?
heatman101
Jul 02, 2011 | Frigidaire FSC23F7D Side by Side...
I have a GE Model GSS22SGRF refrigerator. The freezer is cold but the freezer isn't staying cold. Any suggestions?
heatman101
May 23, 2011 | GE Refrigerators
MSD2650KES SIDE BY SIDE REFRIGERATOR - BACK OF FREEZER ICED OVER AND REFRIG NOT STAYING COLD. DEFROSTED FREEZER, WORKED FOR A WEEK OR TWO NOW THE SAME THING...HELP
either the defrost heater located next to the evaporator core is burned out or the defrost timer unit is defective in the refrige compartment controls area or the defrost thermostat on or near the evaporator coil in the freezer is defective
Jun 08, 2010 | Maytag MZD2766GES Side by Side...
Refrigerators Logo
108 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
