Question about Whirlpool Refrigerators
The infrared receiver is flashing in the freezer of my whirlpool refrigerator
3 Suggested Answers
  • 7 Answers
SOURCE: whirlpool refrigerator side by side Ice control
its a defrost sensor that reads the inside temp of your freezer so it knows when to defrost itself.you need to close it so it wont allow th freezer to freez up.
Posted on Oct 12, 2007
  • 30 Answers
SOURCE: I heard a dripping sound and discovered it was
The common thing is the water line hook up to the back of the frige. First find the shut off. It is usually under the sink or behind the fridge. Roll the fridge out slowly so as not to damage line further. Also roll it straight as not to damage floor. Once u turn off the water line listen to make sure the water drip has stopped if it stops thats the problem. The line is very easy and simple to change yourself. You can get the plastic ones or copper one at the home centers.
moz-screenshot-1.jpgThe water shut off can look like this behind fridge....
http://img.diynetwork.com/DIY/2003/09/18/dpb105_1fw_lead.jpg
or like this if its under sink either way follow the line from fridge to find it.
http://www.howsed.com/wp-content/uploads/2008/03/disconnect.jpg
Posted on Sep 25, 2009
My ice maker makes a lot of noise at night I wake hearing it making ice droping sounds. I don't use a lot of ice can I turn the infrared receiving switch to off?
The noise is probably ice dropping into the pan and the normal ice maker and water valve sounds associated with making ice. Most Whirlpool models have a slide cover to "turn off" the ice maker - closing this cover fools the control into thinking the bin is full. Your owner's manual should provide greater detail on this option.
Sep 13, 2014 | Whirlpool Refrigerators
BROKEN INFRARED ICE CONTROL - ON WHIRLPOOL SIDE BY SIDE. CAN I REPLACE THAT PART?
The part you need to replace is 4389102 this comes with both boards and replace them as a pair. I have a question though, is the harvest fingers in the ice maker at position like a clock? Also to confirm the flashing of the light when the flap is depressed it 2 flashes and a pause? Not 1 flash and a pause, this means unit is harvesting and the ice maker should be moving and if not the ice maker could have a broken gear. This control unit could run you about 100 buck so make sure this is what you need before your purchase. Good Luck
Jul 28, 2014 | Whirlpool Refrigerators
Infrared reciever ice control
What is your question and model number? Is this a refrigerator that you need information about the infrared reciever? I have Whirlpool Electronic Infrared service information just not sure of your question or model number. Thanks, Sea Breeze
Model Numbers can be found in these locations
Dec 13, 2012 | Whirlpool Freezers
Whirlpool infrared shut off arm
If it has optics in the freezer, that is the shut off. Is dosent have a wire bail
Sep 13, 2012 | Whirlpool ED2FHEXN Side by Side...
I had that problem before and it is happening now, whirlpool side-by-side stopped making ice. last time it was a problem with infrared light, can you tell me how to check for it? there is infrared eye that...
Yes, when you open the freezer door, the small red light should start to flash, you should see a flap on the left side wall, push it in so it is flush with the wall, now the eyes should see each other and the red light should go to a steady on, put your other finger over the other eye on the right and the red light should start flashing again, if not then you most likely have a eye malfunction. Hope this helps, Rick
Jul 28, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Ice Maker on Whirlpool Side by Sidek stopped making ice
Go to sears.com, select "Parts Direct", enter model number and wait for unit to be displayed, find ice maker part number and price.
Oct 01, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Whirlpool Refrigerator Icemaker not working
The receiver board has an eye on it (it receives the signal and it may need cleaning. A Q-tip should do. Close the spring loaded panel and insert Q-tip and wipe.
Sep 18, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frige freezer
if you have frost in the freezer it either has an air leak on the gasket or the defrost system has failed and you need to call an honest appliance repair person,don't call sears$$$$$$$$$,check all around the gasket first,mike
Sep 07, 2008 | Whirlpool ED2FHEXN Side by Side...
Whirlpool refrigerator side by side Ice control
Oct 12, 2007 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
834 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
