Question about Nakajima AE-740 Typewriter
When we type a letter it isn't typing the key we are striking.
  • Nakajima Master
  • 3,594 Answers
The Pitch switch is probably in PS position put it in 10 nor 12.
DickyO
Posted on Oct 04, 2010
Royal safari portable typewriter letters ghosting
Usually you are striking incorrectly snap the keys and get off of them. you holding the key down too long.
Jun 28, 2016 | Royal 1966 Safari Portable Typewriter 8247
How to write letter verifing address
Instructions
    • 1Before you begin, set your marginicon1.png 1 inch from the top, 1 inch from the bottom, and 1.25 inches on both sides.
    • 2If you're using letterhead, there's no need to type in your name and address. If you're using plain white paper, type in your name, address and phone number (phone number is optional), centering the text. Make the font in this portion of the letter slightly larger than the rest of the text. You should also type your name, address and phone number in boldicon1.png type.
    • Sponsored Links
    • 3About four lines down from your name and address, type the date in full after strikingicon1.png the "Tab" key seven times to bring you a little further than the middle of the page. The date should be typed in full like this:
      February 1, 2009.
    • 4Four or five lines down from the date, at the left hand margin, type the name and address of the person you're sending the letter to. This portion of the letter is called the inside address. If the person you're addressing the letter to has a title, type his or her name first, then type in a comma, space once and type in the title, such as:
      Jamie L. Mulligan, Manager
    • 5Two lines down from the inside address, strike the "Tab" key seven times and type in the subject line. The subject line tells the recipient what the letter is about. In this case, it should look like this:
      Re: Verification of address
    • 6Two lines down from the subject line, type in the salutation. The salutation could be Dear Sir, Dear Ms. Mulligan, Gentlemen, or To Whom It May Concern (if you don't know the name of the contact person). The salutation should look like this:
      Dear Ms. Mulligan:
    • 7Two lines down from the salutation start the body of your letter five spaces in from left margin. The body of your letter should start out saying something such as:
      I am writing you this letter to verify that 101 Washington Street, Lynbrook, New York 11593 is the address I should ship your order to.
    • 8Two lines down from the body of your letter, after striking the "Tab" key seven times, type in a complimentary closing such as:
      Very truly yours, or
      Sincerely
    • 9Four lines down from the complimentary closing and in line with the complimentary closing, type your full name in, like this:
      Jamie L. Mulligan
    • 10Sign your name in the space between the complimentary closing and your typed name.
Read more: How to Write an Address Verification Letter ' eHow.com http://www.ehow.com/how_4745362_write-address-verification-letter.html#ixzz2DRXhelUj
Nov 27, 2012 | Computers & Internet
I strike letter "m" it
try to disconnect your keyboard and turn the computer off.. when you plug it back up it should have been reset.. or go to the keyboard settings in control panel and you should be able to fix it from there... when you type on a word processor does the letters do the same thing or is it only when you are printing??
Mar 15, 2011 | Computers & Internet
My AX -430 typewriter was functioning well as i was using it. However as i was typing a new word, the letters are no longer visible on the paper. The part that hits or is it the hammer or arm, can no...
It sound like you have a broken part. If the hammer is not hitting hard enough, the armature theat make the hammer strike the keys is broken. This is a common problem with the ax's
Mar 03, 2011 | Brother EM-430 Typewriter
Some of the letters i type are coming out as numbers
You may have the number lock on. Look on the top right of the keyboard for a key marked Num Lock and press that key. Try and type and see if the number lock is off. If not you may have to hold down Fn and strike the Num Lock key to turn it off.
Regards.
Aug 05, 2010 | Computers & Internet
Everything works except for spacebar & key advance
The T/W is probably just gummy. Will it tab? If so the correction mech. is probably the trouble, if not try some WD40 on the silver shaft that the s
carrier slides on.
DickyO
Jun 18, 2009 | IBM Office Equipment & Supplies
Letters aren't striking ribbon
Get some WD40 and spray it on thw segment (the place where the type bars are swung) then everywhere the key mechinism pivots.
DickyO
Apr 04, 2009 | Olivetti Linea 198 Typewriter
I am trying to type a letter but when I strike the letter g it types a $. None of the keys seem to be lined up with the correct letter on the wheel. How do you correct this problem?
there is a slide switch on the L.H. side of the key board that reads 10,12,15, PS
the switch needs to match the print wheel stile you have in your typewriter. most typ's have 10 or 12.
PS stands for proportional spacing a takes a spicule print wheel
Jan 14, 2009 | Nakajima AE-710 Typewriter
Keyboard not striking letters while in email function
Well you already proved that your keyboard is fine.
The problem is with yahoo. Try typing in other websites and see how that works.
Are you using yahoo "email classic" or the "all new yahoo email"? Try the classic and see if that works. Also, try updating your java:
http://www.java.com/en/download/index.jsp
Let me know how it goes.
Oct 01, 2008 | Computers & Internet
Nakajima AE-740 Typewriter Logo
Top Nakajima Office Equipment & Supplies Experts
James Cagle
James Cagle
Ron Dufek
Ron Dufek
Jim Keysor
Are you a Nakajima Office Equipment and Supply Expert? Answer questions, earn points and help others
