Question about Watches
Hi, I have a Rado Diastar 193.0324.3 watch, digital and analog. The analog spindles are not synced to each other - I mean - there's no way to make them show the time correctly. For example - the hours spindle is excatly at 7 when the minutes spindle is at 7 too. When the hours spindle is exactly at 12, the minutes is at 7. It's impossible to make them both show 12. How do I sync the two spindles ? Thanks.
SOURCE: analog clock not in sync with digital clock
This problem may be due to your analog hands being improperly zeroed. To find out, try this: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero. If you do this and your minute hand points to 1 o'clock, or five minutes, you will know that this is the problem. If this is the problem, you can can correct it by zeroing the hands as follows: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero, or close to it. You should also notice the letters "HR" in the lefthand digital display. This allows you to move the hour hand by rotating the crown. If the hour hand is not pointing at 12 o'clock, rotate it so that it does. 3. Push the top button once. The letters "MIN" should appear in the lefthand digital display. This allows you to move the minute hand on the large dial, and the minute and hour hands on the small UTC dial. Rotate the crown so that the minute hand points directly to 12 o'clock. 4. Push the top button again. The letters "SEC" should appear in the lefthand digital display. Rotate the crown to point the second hand directly at 12 o'clock. 5. Push the crown back into its normal position. Set the digiatl time and date in your tie zone, and your analog hands should match the digital read-out. If the zeroing of the hands is not the problem, I don't know what is wrong with the watch.
Posted on Sep 27, 2007
VOTIT
  • 2071 Answers
SOURCE: Rado Diastar
your problem is in setting lever,when the setting lever is jumping the stem cannot get back and lock,you better unscrew the complete barrel drum bridge plate take it out ,and the winding pinion is expose,take the winding gear and the setting lever is expose then arrange the alignment,align the winding pinion to the setting lever,alignment is ok.back bridge plate and screw,,make some winding of the crown,let see rachet wheel can turn transmission wheel of complete barrel drum,if can then checked the stem if already lock.,if lock already the job is done,...email if you some question regarding a watch ;lacarontito@yahoo.com
Posted on Jun 21, 2008
SOURCE: I have a Rado DiaStar
Hears how i do my watch, i have the same watch as you.Just make sure nothing is displayed on the clock face by turning the winder, ie NO digital time, NO daul time, NO alarm, NO stop watch etc, Pull out the winder(crown) and adjust the hands to the time you require by spinning the winder.(Gentley for mins and fast for hours) The digital clock will display wilst doing this, but not change the time.handy if you want to sync both clocks.Push the winder back in at the time to sync and the digital display will go out, then spin the winder again if you want to display the digital features. I hope this helps, please post if it does, Maurice Chevalier- Herts
Posted on Nov 27, 2008
SOURCE: rado diastar swiss 196-0364-3
I bought the same watch recently and have the same problem. The hours can be adjusted in the dual time zone by looking up the manual, but the minutes stay put. I can't bring them to blink so that these could be adjusted. Any ideas? I sent a mail to Rado through their website but no answer.
Posted on Dec 06, 2009
SOURCE: Have Rado 193. am
You can adjust the analogue hands without changing the digital ONLY when you have set the watch to 24hr fornat. Do this by going to the second Timezone screen (T2) and pressing the crown once briefly. If A or P appears, the time display is in 12-hour mode. If no letter appears, the time display is in 24-hour mode. To change mode, press crown briefly a second time.
Now go to the basic display where no digital info is shown. Pull the crown out. Now slow turning will adjust the minutes and fast turning the hours, but only of the hands. Therefore you can synchronize the two. After they show the same time, press the crown back in and adjust both times together using the crown as normal on the standard "Time" digital screen
Posted on Jul 20, 2011
Where to get a new. Watch strap
You can get Watch strap and everything of watch from The Prime Luxury Boutique. It is an authorized luxury watch retailer. http://theprimewatches.com/
Aug 09, 2014 | Rado Diastar Anatom Jubile watch
What's the price of this watch rado diastar
hi the watch i found is pretty much identical. only thing is anchor is at different angle. points straight down not to the right and its a females watch. price is bout 506 pounds or 895 dollars. hope this is useful to u.
Jan 21, 2013 | Watches
Hi, The first link on my Rado Strap has chipped. Can I get the link replaced without having to replace the whole strap.
Just go to your local service center found on www.rado.com and they will replace the link for you for about $25.
Jun 09, 2011 | Rado DiaStar watch #R20282192 Watch for...
How do i set time and date of my rado wristewhatch?
Hi - I have a Rado Jubilee-Black Face-Lovely Dial
Problem:Time is set with a Key - Back of the watch
I have LOST this Key & need to buy or get one?
Can you please advise - rozilamohamed@yahoo.com
Many Thanks
Ms>Mohamed
Feb 23, 2011 | Rado Diastar Anatom Jubile watch
The release buttons on the clasp of my Rado Jubile wrist watch have lost their spring tension can it be fixed
mcdevito75 here, Best Bet with your Rado watch, Look for a small watch repair shop in your area for adjustment / replacement.
Jun 21, 2010 | Rado Diastar Anatom Jubile watch
Rado watch stopped working
It sound like a fault. Be careful who looks at it though and what they charge - a complete new quartz movement for most watches, even fancy ones like your don't cost as much as £90 so almost all of what you are charged is labour.
Feb 02, 2009 | Rado Diastar Anatom Jubile watch
Rado diastar swiss 196-0364-3
Jan 06, 2009 | Rado Coupole R22531723 Watch
I have a Rado DiaStar watch (with digital display), and the hands are out of synch with the digital display. Is there a way of adjusting the hands independently of the display? or must it be sent back to...
Nov 01, 2008 | Rado Diastar Anatom Jubile watch
Watches Logo
1,002 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
