Question about Amana ABB1927DE Bottom Freezer Refrigerator
My pull out freezer (on the bottom of my fridge) leaks water onto the floor. Apparently water pools inside and freezes on the bottom of the freezer and then melts and leaks out? Any ideas? Thanks!
  • 5 more comments
  • cljy Oct 04, 2010
    do you mean inside the fridge or freezer, to peel off the back cover? And this is from the inside?
  • cljy Oct 04, 2010
    okay now that I have the shelves out I see the water tank for the dispenser is frozen and it will not dispense water. BTW the model number is ARB2257C
  • cljy Oct 04, 2010
    defrosting in progress. I was mistaken about the water dispenser. It wasn't pumping because I unplugged the fridge. okay, found the venting in the bottom of the panel. Where do I find the drain hole? Hate to sound stupid but I think I've looked in some of the obvious places.
  • cljy Oct 04, 2010
    When I pour hot water into the venting it cascades inside the back of the freezer. Don't see a drainhole in the bottom of the freezer or fridge.
  • cljy Oct 04, 2010
    okay taking the back panel off, finally understanding what you're talking about. Sorry I'm a bit slow...
  • cljy Oct 04, 2010
    okay my son found a hunk of food in the drain pipe. I think this will fix it. Thanks
  • cljy Oct 04, 2010
    Thank you for your help. We were able to fix it!
  • 503 Answers
sounds like your defrost drain is frozen over. When the refrigerator is going into defrost it's draining through the front instead of the drain pan. You can remove the shelves and peel off the back cover and clear the drain by pouring hot water on the frozen drain hole. If you have a baster of some sort you could try to squirt the hot water through the venting on the bottom of the panel. Another way to to point a hair dryer on the drain hole. The best method is to remove the shelves and panel and make sure the drain is clear.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Posted on Oct 04, 2010
  • Monika Arora
    Monika Arora Oct 04, 2010
    Auto-defrost refrigerators I've seen usually pipe the defrosted water from the back of the compartment through a short pipe and onto an open receptacle mounted on the compressor. The heat of the compressor evaporates this small quantity invisibly.
    If the pipe is blocked or leaking, or the receptacle has a hole, it might be dripping straight onto the floor instead. If seen situations where the pipe becomes blocked with small bits of food detritus etc. Try gently poking something long and flexible - a bit of wire, perhaps, into the hole and see if you encounter an obstruction.
    If not, you will need to get behind the machine and verify that the meltwater is being correctly deposited into the catcher container on the compressor, and that the container is watertight.
  • Monika Arora
    please defrost it.
Tip
What is wrong when your side by side refrig. leaks from inside the freezer
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing, in many case when the floor indent is full the water will leak onto the floor.By pulling the refrigerator out from the wall,there will be a tube behind the service panel on the right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
I hope this helps you to stop the leak,
Gene
on Aug 04, 2011 | Refrigerators
My Maytag MZD2766GES is leaking water to the bottom of my freezer, which, when it get alot starts leaking all over the floor. where is this coming from?
Gene
Aug 18, 2011 | Maytag Refrigerators
Water is collected at bottom of basket in freezer. What can I do ?
Gene
Aug 11, 2011 | Jenn-Air JSD2789GES Side by Side...
Frigidaire Fridge Freezer forms huge iceblock inside fridge back wall. It freezes up whatever is stored in fridge i.e. vegtables, cheese. Water leaks onto the floor from under the vegetable containers. ...
the defrost drain pan is plugged up,you need to defrost it and run a wire down the drain tray hole so it can drain to the bottom as it defrosts otherwise it defrosts and runs everywhere else and re freezes
Jun 05, 2011 | Frigidaire GLRT86TES Top Freezer...
Water setteling on bottom of freezer side and freezing also leaking. 2 fridges both doing the same thing . leaking on the inside and freezing and underneath water is leaking.
Clean out the defrost drain. There is a drain in the freezer that lets all the defrost water run under the fridge. If that gets clogged then all the water runs into the freezer and can even leak onto the floor
Sep 13, 2009 | Refrigerators
Water pools at bottom of freezer, freezes and water leaks out
Hello, this sounds like you have a blockage in the drain tube, remove bottom shelf from fridge and remove the styrofoam..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Aug 31, 2009 | Freezers
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Amana ABB1927DE Bottom Freezer Refrigerator Logo
513 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
