Question about AEG Kitchen Ranges
We have an AEG type AMME 100l ba4 motor used on a power washer. Someone has replaced a capacitor but the machine still does not work but I am not sure they have not altered some of the other wiring so I could use a wiring diagram to chaeck it. Thanks Richard
3 Suggested Answers
SearsTechToo
  • 261 Answers
SOURCE: GE Washing Machine Replacement Motor - Capacitor? Relay? Schematic?
The new units have all of your schematics, capacitor and a higher price for a reason. With GE I avoid used parts because there is so much electronics you don't want to fry. The wire harness leads match the old and there should not be an extra wire, were would it go if there is not a receptacle for it?
I looked up your unit and the motor replacement is WH20X10009 for the model you quoted. As of now GE is has updated this to model wh20x10006 for around 263 dollars.
Posted on Oct 03, 2008
jyackle5
  • 8197 Answers
SOURCE: I wanted a wiring diagram to cannect a motor
The vonly way to get a wire diagram for your machine is to contact black and decker on the link below.
http://www.blackanddecker.com/Customer-Service.aspx
Good Luck
Posted on Dec 01, 2010
I have AEG Lavamat 60210 Front Load Washer machine. The machine stops after some cycles and time on the screen return to start. The Problem I get is E52.
Intervention of motor overheating safety cut-out.
Possible fault Motor faulty; Intervention of motor overheating cutout; Wiring faulty; Electronic board faulty.
Machine Status/Action Power to the heater unit and reversal of the direction of rotation are interrupted. If the problem does not re-occur, the alarm is memorized and the cycle continues. If the fault persists after several attempts to supply power (about 35 min.), alarm E51 is generated.
Oct 23, 2016 | AEG Washing Machines
Hi. Got a Aeg T56840 dryer with an E50 error. So It might be the carbon brushes that needs to be changed. But How do I get to the motor? Top, side, back or button of the machine? ? Hope you can help
side off as explained by one person on a forum
so some questions to be asked
does the drum turn
will it turn if you help it
it is unlikely that it will have brushes as most electric appliances use induction motors which are brushless
e50 is the machine sensing the drum failing to turn
it could be a failed start/run capacitor if the drum turns when you help it start
the capacitor is a 6uf capacitor mounted on the motor ( try e-bay)
the fault also may cover not heating
try resetting the machine by disconnecting from the power point for 15 minutes then starting it again
Dec 17, 2015 | AEG Washing Machines
Is the motor from an AEG L16820 Washer Dryer compatible for use in an AEG L16850 Washer Dryer
The two model nos you quoted do not in general have interchangeable motors however....
The exact motor depends on your product number not your model number. Look on the plate on the machine and check on aeg's website or a spares website
Jul 22, 2014 | AEG L16820 Front Load Washer
How do I fix my AEG Lavamat T57800 dryer
E51 - Motor power triac short-circuited
Motor faulty ; Wiring faulty ; Electronic board faulty ; Motor capacitor ; also check tension of belt
Dado
Jul 15, 2014 | AEG T57800 Electric Dryer
AEG Lavamat Turbo 12710 update. Machine is refusing to start on any program. I set program. Instrument panel lights up as expected. Time indicator starts to flash. Door indicator light then goes from...
You will need to change the carbon brushes in the motor. Tip machine 45 deg backwards you might need someone to hold for you and look at motor underneath you will see 2 black carbon brushes remove these and replace if worn then retry machine also make sure the wires to the motor are ok.
Jan 07, 2011 | AEG Lavamat 12710 Front Load Washer /...
My AEG Lavamat W 1000 runs properly but won't spin
a little late to solve your problem...if it ever happens again, change the 16 micro farrad capacitor in the upper rear right corner of the machine. This capacitor controls the starting torque in any motor mode
May 15, 2010 | AEG Lavamat W1450 Front Load Washer
What means error code "C9" ? AEG Lavamat 76669
C9 Indicates Motor Fault. It seems that the Carbon Brushes have Worn out.
Replace it and more likely it would Fix the Problem.Once you replace that, you need to put the machine into Service Mode to Reset the Error.
Steps for Reset the Error Code
1. Press and Hold the Prewash and Soaking Buttons Together.
2. Whilst Holding them, Turn the Dial from Off one Click Anti Clockwise
Note - If problem persists, Check the motor plug for broken wires and check the state of the carbon brushes.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Feb 28, 2010 | AEG Lavamat 88840 Front Load Washer
Oct 03, 2008 | Washing Machines
Capacitor
it helps the motor to turn, it is sometimes called the starting capacitor and some are called running capacitor..
all capacitor used in drive motors are used to start the drive motors.
i hope i answered ur inquiries...
drcool
Aug 10, 2008 | AEG Lavamat 72640 Front Load Washer
Kitchen Ranges Logo
148 people viewed this question
Top AEG Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you an AEG Kitchen Range Expert? Answer questions, earn points and help others
