Question about Sony BDP-S550 Blu-Ray Player
VUP 0/9 KEEPS FLASHING DURING FIRMWARE UPGRADE NOW ITS MORE THAN ONE HOUR
I had the same problem when I made the mistake of trying to do a firmware upgrade via CD-R instead of the Network option. My player is no longer connected to the internet so I created a CD-R following the directions on Sony's site. The CD-R attempted to do the upgrade, but was stuck at 0/9 and I could hear the disc trying to read. The problem is the disc you created. You need to make another one. On the Mac, I used the Finder to burn the disc per Sony's instructions. That is what failed in the player. My second CD was created with Roxio's Toast Titanium, PC/Mac Data CD-R. If you have Windows, I would suggest using a commercial burning CD program, like EasyCD Creator and burn the two update files to the root level of the CD. Make sure the disc is finalized.
Next, you need to open the player to manually release the tray to eject the CD and swap it with your new disc. Remove the two back screws on each side. This removes the two side trim panels. Remove the two screws holding the top trim panel on each side. Then slide the top trim panel from front to rear to release the panel. If that doesn't work, open the CD cover door with your finger and then gently pull up on the top panel at the front edge to release the clips along the front, across the entire front edge. Then slide the panel back to remove it. Then remove the three screws at the front edge, and two more screws on each side. There is also one screw at the rear top edge. Remove the top panel. Then get a long paper clip. Looking at the front of the player, the manual eject hole is on the right side of the optical drive. Above the hole is an E engraved above the hole. Insert the paper clip straight into the hole and you should be able to push the release mechanism causing the tray to open. You might have to fish around a little. Slide the tray open and replace the disc with the newly burned disc (or obtain a disc from Sony for free through their website). Close the tray. You can leave the player open. Plug in the power cord and the upgrade will continue where it left off. It may take a minute or two, but you will see the VUP advance to 9/9, then finish. The tray will open and you can remove the disc. Close the tray and the player may reboot again. Once you see the No Disc message, turn off the player and pull the power cord. Reassemble in reverse order and reconnect your player to your TV and it will have the new firmware.
Posted on Oct 15, 2010
  • 4 more comments
  • Peter Hillman
    Peter Hillman Oct 15, 2010
    I forgot one step. After you remove the top plastic trim panel, you need to remove the front trim panel by releasing the three clips on the bottom, two clips on the side, and two clips on top. Then remove the rest of the screws to remove the top metal panel.
  • Kevin Homan
    Kevin Homan Nov 06, 2010
    Gotta love the internet - I googled and found your solution to the exact problem I had. Thank you! I also followed the directions at Sony's site and burned a firmware upgrade disc using the Mac's Finder. My Sony Blu-Ray recognized the upgrade disc and started the process, then stuck at VUP 0/9. Following your instructions, I burned a new upgrade disc using Toast Titanium to make a Data "Mac
  • Kevin Homan
    Your description of removing the panels from the Blu-Ray player to access the CD tray differed from what I had to do because I have a Sony BDP-S350. So for the benefit of those who have the BDP-S350: Remove the two screws one on each side. Then remove the three screws from the back - one at each of the top back corners and one at the top middle. Now slide the case slightly back to remove it. Next, remove the entire front panel by lifting up on the clips - I think there are 6 or 8 total. You have to go back and keep lifting up on them until you have enough of them released for the entire panel to come off. At this point you do not have to remove anything else. The manual eject hole is on the right lower side of the disc player towards the front. An E is engraved above the hole. Insert a straightened paper clip into the hole. It took a few attempts fishing around until I got the release mechanism to open the tray. Remove the bad upgrade disc and put in the new one. You do not have to put the front panel back on to proceed with the upgrade. Plug the power cord back in and wait for the firmware upgrade to finish. The tray will eject after completion. Remove the upgrade disc and put everything back together in reverse order.
  • Milroy74 Jan 10, 2011
    After 2 failed attempts and a lot of online research, I used Toast and burned a CD in ISO9660 format at a slow burn speed. I removed the old CD, loaded the new one, and reconnected everything. The version upgrade was completed in less than 30 minutes and the BD player works fine.
  • Firsttothesc Feb 13, 2011
    I have the s-350 and I have been putting the paper clip in the hole with the e but I cannot get the tray open
  • sonyuser43 Feb 27, 2011
    Thank You! Perfect instructions.
    BTW Manual Eject is on the Right Panel of the drive, not the right side of the "front" like I had thought.
Gotta love the internet - I googled and found your solution to the exact problem I had. Thank you! I also followed the directions at Sony's site and burned a firmware upgrade disc using the Mac's Finder. My Sony Blu-Ray recognized the upgrade disc and started the process, then stuck at VUP 0/9. Following your instructions, I burned a new upgrade disc using Toast Titanium to make a Data "Mac & PC" CD-R although I unchecked the Mac boxes and just left the PC boxes checked. Once I removed the old upgrade disc and put in the new Toast-burned upgrade disc and plugged in the power for the Blu-Ray player, the VUP 0/9 flashed for about 5 minutes and then the upgrade proceeded to completion taking about 15 minutes total.
Posted on Nov 06, 2010
  • DouginSalem Feb 06, 2011
    This solution worked perfectly for me, after having had the Sony tech service person tell me to send the player to Texas for exchange. Like others, I had used a Mac to burn the CD. For my second burn try, I used my Windows laptop.
  • meskal Mar 11, 2011
    Sony wants $250, I'll fix yours for $50 Shipping both ways to and from Florida!
    meskal@tampabay.rr.com
I have a BDP-S550 player. I went through the same problem of the mac disc hanging. The previous suggestions were very helpful except for the plastic cover. I could not get the plastic top off by the suggestions, I had to slide the cover forward until it came loose. Then, I was able to take off three screws that held the metal frame in place. After that I was able to get to the front right side and release the drive by a paper clip and remove the disk. I made a CD-R disk on Vista OS and put into the drive. Plugged in the power cord and waited. It finally when through the process and upgraded the firmware. Thanks a lot guys.
Posted on Jul 07, 2011
WANT TO UPGRADE FIRMWARE. SCREEN GOES BLANK
Allways read about the serial number before flashing firmware or the wrong firmware revision was loaded for this model ?
firmware chip replace by new or lend a chip with an appropriate revision start and create a hot-swap by reinserting the old chip and re-flash the correct firmware in it, because he will likely continue to boot black
Feb 25, 2016 | Samsung 2232GW
How to up date hp Officejet 6700 Primium all-in-one code auf8437ojde38
  1. Switch on the HP Officejet 6700 series printer and wait until the printer is READY. [The Power light should be on]
  2. Double click on OJ6700_R1435A.exe to launch the HP Printer Update utility. A list of OfficeJet 6700 Premium series printers detected will be displayed on the screen.
    Note: If the Wired network printer you wish to upgrade is not displayed in the detected printer list, click on the Refresh button to scan for printers connected via the wired network.
  3. Click on the checkboxes on the left to select single or multiple OfficeJet 6700 series printers you wish to upgrade.
  4. Click on the Update button to start the firmware flashing process.
  5. Message showing "The selected printer has been updated successfully" will be displayed. Firmware flashing will begin.
    CAUTION! Do not interrupt the printer during the upgrade process. Printer may be damaged if power is interrupted during the firmware upgrade process.
  6. When the printer has successfully completed the flashing process, it will automatically print out a Self Test Diagnostic Page, that will show the new firmware version.
  7. Click on the Done button to close the HP Printer Update utility.
HP Officejet 6700 Premium All in One Firmware
Nov 14, 2014 | HP OfficeJet 6700 Premium All-in-One...
My lg cookie black turned itself off one day and i have been trying to turn it back on and it comes on but it only shows the lg logo then it keeps on flashing
Go to your cellular service provider or other reputable cellular repair shop and let them do a firmware upgrade. Had teh same thing, and the upgrade solved the issue.
Aug 23, 2011 | LG Cell Phones
When i try turning my 5230 on it just comes up with the intial white screen that says nokia on. It wont load up my screen. Please help, thank you
Try the following suggested solutions as they may solve your problem:1. Remove any newly added hardware on your device, e.g a MicroSD device(memory card), and replace it with a component compatible to your product.2.Upgrade your phone's firmware.You can do this through the Nokia PC Suite provided with your phone.During the firmware upgrade process, ensure that your phone remains connected throughout the operation and that you have a working internet connection.
Procedure:1. Download the Nokia PC Suite from the Nokia Website at http://europe.nokia.com/support/download-software/pc-suites/compatibility-and-download and ensure that you select the appropriate phone model2.Install the Nokia PC Suite(latest version is Nokia PC Suite 7.1 as at the time of writing this) on your computer.3.Connect the Nokia phone to your computer via USB.4.Follow the procedures at http://nokia5230.com/nokia-5230-firmware-update-v12-0-089/ and http://nokia5230.com/nokia-5230-firmware-update-v20-0-005/ to upgrade the phone's firmware.
I hope the above data will help.For more on tweaking your Nokia 5230 phone, follow the link beloe:http://nokia5230.com/nokia-5230-hacking-tutorial/
Have a good time ahead.
Dec 18, 2010 | Nokia 5230 Cell Phone
My sony bdp-s350 has failed to upate latest firmware, the disc keeps spinning, showing 0/9 vup. After two hours i finished pulling the plug out. The machine seems totally locked, any thoughts on what i can...
You may have better luck than me -- try unplugging the unit. Wait two minutes. Before plugging it back in, hold down the Open/Close button that ejects the disc. Then plug it in. It may open the door.
Nov 29, 2010 | Sony BDP-S350 Blu-Ray Player
Error codeExxx sys err vup ng
This error occurs while installing the firmware update in the player. Hence, try resetting the player and check if it helps.
Turn Off the player and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation.
Jul 27, 2010 | Sony BDP-S300 Blu-Ray Disc Player
Frozen on hour glass mp4 player
Try to reset the player and if that doesnt do it do a firmware upgrade...
Jan 17, 2008 | iLO (2 GB) MP3 Player
System initializing
This is straight out of p. 67 of the user's manaul, available on iRiver website (it may not work if the computer does not recognize the device):
Initializing H10
67
Additional information
Firmware upgrade
66
What is firmware ?
It is the operating system that works in the H10.
iriver provides you with the latest and best features through Firmware upgrade.
You can choose manual or automatic upgrade function.
For information on automatic upgrade, refer to the iriver plus instruction manual.
Manual firmware upgrade
Select [Option - Firmware Upgrade] from the menu in iriver plus.
Do not disconnect H10 during firmware upgrade.
Internet must be connected for the "Firmware Update" function.
Change to "Player must be connected to the PC for Firmware Upgrade function.
Note
Please initialize H10 player in the following cases.
All music, pictures, text, and data will be erased from the player during this initialization.
- if there appears to be corruption on the internal hard drive.
- if an error message displays and the player doesn't boot properly.
1 Connect the player and PC using the cable supplied with the player.
Open iriver plus.
Select [Option-Portable Device Initialization]. 2
Click [Start] to begin initializing.
Initializing H10
Dec 18, 2007 | iRiver H10 MP3 Player
Sony BDP-S550 Blu-Ray Player Logo
4,765 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
