TSST Corp CDRW/DVD TSL462D ATA Device (code 10) will not start up.
    Problem Solver:
  • 16 Answers
Please perform the below steps to fix the issue:
Step 1: Please perform manual registry set up by following the below steps:
Please make a full backup of your registry files, particularly user.dat, system.dat, and policy.pol. If you make any incorrect entries, the backed-up registry files can be used to replace the corrupted registry entries.
Follow these steps to backup registry:
1. Click Start, select Run. In the "Open" field type REGEDIT
2. Click OK and click "File" in the menu bar
3. Click "Export" from the drop down menu this will open a new box
4. Click the down arrow beside "Save In" and select "Local Disk (C:)"
5. In the File Name field type BACKUP.REG Verify that under the "Export Range", that the radio button is beside "All"
6. Click Save.
Now make the following changes in registry:
1. Click Start and click Run(XP) or type Click Start and type regedit in search then hit enter(vista, Windows 7).
2. In the Open box, type regedit and click OK.
3. Click the plus (+) sign beside HKEY_LOCAL_MACHINE.
4. Click the plus (+) sign beside System.
5. Click the plus (+) sign beside Current Control Set.
6. Click the plus (+) sign beside Control.
7. Click the plus (+) sign beside Class.
8. Locate the {4d36e965-e325-11ce-bfc1-08002be10318} key and click it.
9. On the File menu, click Export.
10. In the File name box, type savedkey and click Save. It is better
to save the "savedkey" to the desktop.
11. Click the REG_MULTI_SZ data type UpperFilters (found in right
window pane) and then click Delete on the Edit menu.
12. When you are prompted to confirm the deletion, click Yes.
NOTE: If this data type is missing, continue to the next
method.
13. Click the REG_MULTI_SZ data type LowerFilters (found in right
window pane) and click Delete on the Edit menu.
14. When you are prompted to confirm the deletion, click Yes.
15. Quit the Registry Editor.
Step 2: Please uninstall the CD/DVD drive form Device Manager :
1. Click Start and select Control Panel.
2. Double-click the system icon. If the System icon is not found directly under Control Panel, click the Performance and Maintenance icon and then click the System icon.
3. The System properties Window opens. You can open the System Properties window directly by pressing the Windows key and Pause/Break key simultaneously.
4. Click the Hardware tab and then click the Device Manager button.
5. Click the plus (+) sign next to the DVD/CD-ROM drives .
6. Right-click the driver listed under this Category and select Uninstall. In the Confirm Device Removal dialog box, click OK.
7. Repeat step 6 until all entries under the device category are deleted.
8. Restart the computer.
After the notebook is restarted it automatically detects the drive and the drivers are installed.
Regards,
Shami
Posted on Dec 06, 2010
  • mwf1 May 20, 2011
    Thank you for straight forward honest advice on fixing this problem. I highly reccomend this forum to obtain self help on issues such as this.
  • Sara Haberer
    Sara Haberer Dec 30, 2012
    Yay!!!! This worked! :) Thank you so much for the instructions; they were very easy to follow.
Code 39. Windows cannot download device. Driver
Go to http://pcsupport.about.com/od/driverssupport/ht/upperfilters-lowerfilters.htm for the solution. I had a similar problem (Code 39) with my optical drives and Windows 7 64-bit. This solution corrected it.
Aug 09, 2010 | Dell Computers & Internet
Cd/dvd drive not available . its a TSST Corp CDDVDW TS-L632N ATA Device. it came with error code 10 then vanished. i have tried system restore, have tried regedit. and ried to download a new driver with no...
1-it is probable that there might be a virus infection!
2-or ther might be physical damages to your cd drive
3-try reinstalling your operating system.
Nov 16, 2009 | HP Computers & Internet
My CD DVD player won't work. TSST CORP CDRW DVD
This is the latest driver released by TSSTCorp for thier devices.
If this helped please vote kindly
Oct 09, 2009 | Computers & Internet
How do I install a TSST corp CD/DVDW TS-L632D ATA device
It should just plug in and windows will reconize it.
Sep 25, 2009 | Computers & Internet
TSST corp CDRW/DVD TSH driver
Go to device manager - delete the device, then do a 'find all plug and play devices'
Jun 30, 2009 | Dell Computers & Internet
TSST Corp CDDVDW TS-L632N ATA DEVICE
Try to uninstall your optical drive on device manager and restart your system.
->if that doesn't work try a firmware update.
->if that still doesn't work,replace optical drive.
that should resolve your problem
May 29, 2009 | HP Pavilion DV6700T Notebook
Lost cd-dvd rom driver for a TSST Corp CDDVDW TS-L632N ATA DEVICE DRIVER
You can select your Operating System since you didn't mention it and continue to your drivers page at the link below:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3747228&lc=en&cc=us&dlc=en&submit.y=4&submit.x=7&lang=en&cc=us
May 25, 2009 | HP Pavilion dv6930us Notebook
TSST Corp CD/DVD RW TS-L632M ATA device wont play discs. Driver is current
I also have the TSST cd/dvd with the same problem but I just realized that is a comflict between all these programs I have installed (Windows Media Player, Sonic and Roxio Easy Creator 6). WMP will not even show it, then I went to Roxio audio central an it worked perfectly. I tried to change the default back to WMP but it wont take it. I believe this happens because Roxio was the last I installed and took control of the sound. Hope this help. I will be uninstalling my WMP and installing it again so that I can keep it as my first choice.
Apr 22, 2009 | Computers & Internet
Computers & Internet Logo
1,560 people viewed this question
David Payne
David Payne
