Question about DeLonghi Dragon 3 1025 / 1025T Oil Filled Radiator Heater
Delonghi dragon oil filled heater with timer. How does the timer work, is there a way to set it so that it stays on all the time? Do not have the manual
Within the timer is a 3 point switch. Push the switch to the end closest to the arrow and away from the clock icon. It will stay on
Posted on Oct 14, 2010
2 Suggested Answers
SOURCE: set time on delonghi oil filled portable heaters and set start and finish times
It was very tough to find the actual manual online for your modle in English. However, you can call Delonghi customer support:
DeLonghi Customer Support: (800) 322-3848
Delonghi does have manuals for some models on their site. Take a look at this link, the model might be similar enough to yours to be able to get the information you need.
http://www.delonghiusa.com/search_results.cfm?sp_q=oil+filled+heater&sp_p=all&sp_f=ISO-8859-1&sp_w_control=1&sp_w=alike&sp_a=sp1003e79d&sp_c=5
Hope this was helpful.
have a great day!
Posted on Oct 29, 2008
My delonghi dragon safeheat is cutting off. I have not set the timer to turn it off. Is this a safety shutoff from overheating?
It does have a thermal safety and it very well could be the problem. I looked up this review for you. I hope it is what you were looking for. Roger http://products.howstuffworks.com/delonghi-dragon-oil-filled-radiator-heater-hm25e-review.htm
Apr 06, 2011 | DeLonghi Heating & Cooling
Hi i have a new DeLonghi Dragon 3 heater. The timer seems to work opposite to your instructions - i.e. the instructions indicate that the notches must be pushed to the outer ring to indicate the operating...
This is from the instruction manual online:
To set the heating periods proceed in the following manner:
- Check the time by your watch. Supposing it is 10.00 a.m. turn the numbered dial of the
time-clock in a clockwise direction until the number 10 coincides with the reference mark s
on the time-clock. Set the time period during which you wish the appliance to work by
pushing the notches towards the centre. Each notch corresponds to a period of 15 minutes.
At this point sections will be visible corresponding to the working periods.
Set in this way the radiator will function automatically every day during the set period.
(Important: the plug must remain connected to power supply).
- To change the programmed time period, just bring back the black notches to their original
position and set the new working periods required.
- If you wish the appliance to function without programmed working periods push all the notches
towards the centre. In this case, to turn the appliance off totally the plug must be pulled
out apart from switching off, so as to avoid unnecessary working of the timer.
Jan 29, 2011 | DeLonghi Dragon 3 1025 / 1025T Oil Filled...
Delonghi Dragon Two, oil filled rad trips the main elec fuse
If it is tripping the breaker in the panel, there is a direct short in the heater. Scrap it before it causes a fire. Seriusly
Oct 24, 2009 | DeLonghi 6707E Oil Filled Radiator Heater
Actual output on settings
MODEL DELONGHI TRD0820ER 2KW OIL FILLED RADIATOR
YOU HAVE THREE SETTINGS
1. 900 WATTS
2. 1.1 KW 1,000 WATTS WHICH IS ABOUT 1.096 WATT
3. 2.0 KW 2,000 WATTS
Nov 25, 2008 | DeLonghi Dragon 3 1025 / 1025T Oil Filled...
Set time on delonghi oil filled portable heaters and set start and finish times
have a great day!
Oct 29, 2008 | DeLonghi 6707E Oil Filled Radiator Heater
Timer
Timers? I thought those were like temp settings to turn off when it got to a certain temp. What numbers are on yours?
Nov 09, 2007 | DeLonghi 6707E Oil Filled Radiator Heater
DeLonghi Dragon 3 1025 / 1025T Oil Filled Radiator Heater Logo
1,944 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
