Question about LG Flatron L1710S 17" LCD Monitor
Using buttons on monitor to control color, etc
How may i select displayed buttons when trying to change color. etc?
  • 558 Answers
Some monitors, I do not have a manual for, however after 5 min I can usually figure out how to operate the osd. menu then up down then menu again if not that then push a few buttons and see if you can select what you need.
Posted on Jun 19, 2008
How to adjust color of screen
click start control panel,display,settings you can make adjustments for more or less pixels or from the drop down list pick the appropriate level of color range
click start control panel,display,desktop you can select a different desktop from the drop down list also there should be a browse button where you select your own personal picture saved in my pictures also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope it helps
May 15, 2012 | Hannspree HF225DPB 21 inch LCD Monitor
Trying to fix the color on my monitor
Click start control panel administration tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
you might have to remove your graphics card to make sure the socket is clean
restart your computer the reinstall it this should activate found new hardware wizard
if your computer came with a mother board disk the drivers could be on it
or a browse button where you can select different pictures this may vary depending on your operating system
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
hope this helps you
Dec 02, 2011 | E-Machines eMachines Monitor E15T4
Monitor picture looks misty
hope this helps you
Oct 26, 2011 | Computers & Internet
U screens colors on my pc is too bright
hope this helps you
Oct 05, 2011 | NEC MultiSync 1920NX 19" LCD Monitor
My new 202E 20'' monitor says Monitor Controls Locked. How do I unlock it to change the brightness, color etc please?
Press and Hold the Menu button (which is towards the left of Power button) for 20 seconds until it displays "Monitor Controls Unlocked" on the screen.
Hope this helps !
Regards,
Shuaib
Aug 30, 2010 | Philips 150C4FS 15" LCD Monitor
Image is off center bottom is cut off so I cannot see commands
This page is for ACER products. Select the DISPLAY, the choose the correct model for your monitor. There select Guides and Manuals. When you get the PDF file open, look for ADJUSTING DISPLAY SETTINGS. (page 6)
This is what was one one product's manual. This is similar to what my HP monitor uses. Hope this helps.
User Controls
A brief description and the location of all LCD Monitor function controls and indicators:
Figure 2-1
Stereo Speakers
PC Audio Stereo output.
Speaker Volume Control
Increase Volume - Turn the knob clock wise.
Decrease Volume - Turn the knob counter clock wise.
DC Power Switch
Press the power switch to switch the monitor ON/OFF.
DC Power-On Indicator
LED lights Green color --- Power is ON.
LED lights Yellow --- Monitor is in "Power Saving Mode".
LED is off --- Power is OFF.
5
Function Select Buttons
Press either left or right control button for OSD (On Screen Display) menu selection.
6
Adjustment Control Buttons
Press the left button to decrease the OSD setting and press the right button to increase the OSD setting.
7
External Headphone Jack
The monitor speakers will be disabled when using an external headphone or external speakers.
Good luck
Feb 18, 2010 | Acer Computers & Internet
How to increase brightness of my monitor i put it
Hi, you can try this; in a clear area of the Desktop screen (right)) click, once the desktop window open, click on Personalize, next click on Display Settings. You can adjust the brightness by by doing the following: On the resolution scale adjust from Low>High; you can do this until you are satisfied with the view. In the (Colors) drop box, click the down (Arrow), and choose the "Highest" color (16bits>32bits) etc. Next click to open the (Advance)) settings, click on the (List All Modes) button, once the window open choose the (Highest) settings: example (1366 by 768, True Color (32bit), 60 Hertz. Remember to click the "Apply", and "OK" buttons after each selection or change. "Hope this helps' Ya"
Jan 29, 2010 | NEC MultiSync FE700 17" CRT Monitor
Is it possible to change the color temperature on Studioworks 560N?
Much better if you change the color control on your PC. Or your desktop right click properties, On the Display properties click settings, under the setting select Advanced. Look for your videocard software control. It will let you adjust the Gamma, Contrast, Color control of your display properties.
Oct 21, 2009 | LG Studioworks 560N 15" CRT Monitor
Screen ajustment
Hi stefan,
You can adjust manually using the OSD (on-screen display) menu of you monitor by pressing menu button. Other monitor OSDs cannot be accessed on single button but some combination of buttons but considering it can be accessed, please look for it. Try also changing the properties at Operating System GUID (graphics user interface display) Control Panel Display or your monitors display monitor application software. Try changing the frequencies and other special features like single screen or wide screen, etc..
Best regards,
Rosener
Jan 30, 2008 | Acer AL1716 17" LCD Monitor
Monitor nor driver acknowledged
If you just want to adjust the display settings so that they are more to your liking go to Control Panel and open Display. When the Display Properties box opens click on the settings tab. Use the slider bar in Screen Resolution to adjust to 1024x768 or whatever resolution your monitor displays best at. To the right use the pull down arrow to select the highest color quality you can select. Then click on the Advanced button on the bottom left and you should see a Monitor tab. Click on that and ensure your refresh rate is 60 Hertz. Save your settings, accept the change confirmation when it appears and your monitor should be good to go. I have about 90 Dell LCDs and the default Windows drivers for the LCDs usually work great.
Jan 01, 2007 | Dell E153FP 15" LCD Monitor
LG Flatron L1710S 17" LCD Monitor Logo
Top LG Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Teet Bergmann
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
