Question about Troy Garden
I am having trouble with my Troy Bilt riding mower in getting it to start. I have charged the battery. The mower started yesterday and when I finished and tried restarting it behaved as if the battery was dead. The battery is less than six months old. I have tried to recharge the battery and it still won't start. The engine will not turn over.
  • gra624 Oct 04, 2010
    I do I check the charging system on my mower as you mention as one of the possibilities?
    Joe,
    How do I check the charging system of the mower and if damaged how do I replace it?
  • 10,865 Answers
Hello. Unhook that battery and take it to your local auto parts store to be tested, a free service. Clean the inside of the battery clamps and the battery terminals before reinstalling it. When you reinstall, make sure you are tightening down the clamps using a proper fitting open end wrench or a proper fitting socket wrench. Also, change the spark plug and the air filter unless you have already done so during this mowing season.
Having done these things, your battery will start the tractor and it should recharge itself as you mow. If you find within the next couple of mowings that the battery is low once again, that indicates that the tractor's charging system is bad, or that you have a short somewhere within the tractor which is causing a constant drain on the battery. Joe
Posted on Oct 04, 2010
    President:
  • 2,777 Answers
Does it click like it's attempting to start or anything? Does it sound like an electrical issues to you, not even attempting to start? Many things can cause this... need more information.
Thanks
Tim
My troy bilt riding mower wont crank
Check your battery and see if its fully charged. I had a battery that the charger said was fully charged but a cell was dead. Take it to a battery store and they will check it free of charge.
If that's not the problem check all the battery cables on both ends for being tight and clean. If that's not the problem you could have a bad starter.
Jun 22, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
Turn key starter wont turn over engine
Sounds like the battery is too dead to start it, try charging the battery to see if it improves. Check the battery connections to make sure they are clean and tight. Hope this helps
Apr 20, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
Troy Bilt pony will not start
no fire , sounds like your having a problem with one of the safety switches on mower deck ckt look under tractor but over mower deck for a loose or hanging wire bet it goes to a switch ?
Nov 13, 2013 | Troy Garden
Mower: Troy Bilt 42 Mustang Zero-turn mower: The
Hello Donna,
I would remove the battery and have it tested at a local parts store. It sounds like the battery to me.
Sep 08, 2013 | Mustang Rzt 50" Zero Turn Riding Lawn...
I have a troy bilt riding mower. I put a new battery in it last summer. This yr., my son left the key in on positon when he got done cutting the grass. Naturally it killed the battery, I jump started the...
It may not be charging due to a bad connection to the battery or to the generator on the engine. The generator on the engine may be going or has gone bad.
I hope this helps.
Jul 27, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
I have trouble starting my troybuilt 0 turn 42' ride mower when i first st art it for the day. i have to spray gas into the carb to start.it,s only a year old
Does the battery need replacing ? The voltage should be above 12.8V for easy starting, Alternator should be charging at about 14 volts.
Check the choke plate is operating properly.
Check air filter is clean.
Feb 22, 2011 | Troy-Bilt Garden
I have a troy bilt riding mower, 6 years old, 26
many of these units use the starter motor as the generator to re-charge battery. check voltage regulator & wiring.
Sep 28, 2009 | Garden
I have a Troy bilt 17hp 42 inch cut ride on lawn
yes they have a charging system, not like a car but a charging system one the less. as i said before either under or around the flywheel. some newer mowers also have an electronic regulator.
Jul 31, 2009 | Garden
Garden Logo
168 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
