Question about General Electric Hotpoint® RB536BKBB Range
Need wiring diagram for GE model # JBP26B Y2WH. The large hot plate part # WB21X226 need to know haw to wire. I had diagram when i unhucked switch but lost it.
  • 4 Answers
SOURCE: GE JP350 wiring problems
a to black one
b to red one
d to orange
e to grey
a-e to red two
a-d to black two
a-c to orange two
a-b to grey two
a-a to white
Posted on Jan 20, 2008
  • 979 Answers
SOURCE: GE refrigerator wiring diagram
Icemaker must be at 28 degrees to make ice. The harness supplying the power should have 120 volts there at all times, and the icemaker itself is the device that switches the power off and on once all requirements are met. Your diagram for the fridge is on the rear service panel, or in a packet on the insisde rear..accordianman
Posted on Apr 03, 2008
jyackle5
  • 8197 Answers
SOURCE: need manual for microware GE Profile Spacemaker XL1800
Yes you can wus the racks all the time they are made for the microwave.
Also here is the manual
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40395-1.pdf
Good Luck and Please Rate FixYa!
Posted on Jan 11, 2009
  • 73 Answers
SOURCE: wiring diagram
http://www.partadvantage.com/store/spider/ge/7
Please Click on the Link above and just, click on your model#
Your info is there.
Hope i helped
Please Rate me
Thank You
George
Posted on Apr 28, 2009
TheMobilian
  • 8220 Answers
SOURCE: TIMER WIRE DIAGRAM
Just attach the green wire to any screw closeby. Nothing could be simpler. Look closely and you will find a small male terminal to connect the green wire in some models.
Posted on May 13, 2009
Wiring diagram for ge 3 coil range burner
Go to the back of the range. The wiring diagram with be on the back, or inside the top console. They hide them there for service engineers. Washing machine diagrams are in the bottom or in the top console, Fridges are behind the back of the freezer to the right of the evaporator coils.
Your colour coding is probably the same on all burners. There is normally only two wires.
May 16, 2016 | GE Kitchen Ranges
I do not know how to hot wire my pocket bike it is electrical had to orange wires a green and a black and white one need help hot wiring it
The key switch should have a set of wires coming from it, usually it is just two wires that act as a kill switch, if you put a jumper across the contacts of them it will pull start, to get the rest of the electrical working a wire diagram would be in order, and to find that you would need your model number of the pocket bike
Apr 22, 2014 | Cars & Trucks
Ge Wiring Diagram
Request the wiring diagram directly from GE.
Oct 24, 2017 | GE Refrigerators
I have a new GE 15306 Mechanical Time Switch and need to wire it up to 2 white and 2 black wires that I had on my old timer. I need more information on the wiring than is on the diagram on cover of metal...
http://waterheatertimer.org/images/GE-15306-wiring-250.jpg
http://waterheatertimer.org/GE-timers-and-manuals.html#15306
GE 15306 is a version of 120Volt Tork 1101 indoor-outdoor timer sold at Home Depot under GE name and number.
You have 2 cables.
One cable comes from Breaker box, and other cable goes to Load (light, fan, motor, pump).
Each cable has black and white wire.
1) Cable from breaker box: Black wire H Hot connects to to terminal L.
Notice there is a metal bridge that connects terminal L and terminal 1.
If metal bridge is missing, use a jumper wire and connect L and 1.
White N Neutral from breaker box connects to terminal X.
2) Cable going to Load:
Black connects to terminal 2
White connects to terminal X.
So both white wires are on terminal X.
Jul 14, 2011 | General Electric GE 56941 24-Hour Outdoor...
Having wiring problem on 1970 amc javelin v8 need to see wiring diagram where the selonoil is under hood inside right fender need to know how many wires from selonoid and where they go thanks
Yeah, You're right on the position of the solenoid, and you hook the side large post to the hot post of the battery with large cable, and the large post on other side of solenoid to the starter with the large cable. The single wire that comes from the starter switch goes on the small post to the front, and if theres a second small post, it doesn't have to nave a wire on it, but normally it is a power cutout to other things that are not needed to be powered when cranking. Use a test light and have someone crank the engine over to test and see for sure which wire is the one coming from the switch before you connect it.
Apr 25, 2011 | AMC Eagle Cars & Trucks
Need a wiring diagram for 696 seriess switch
You don't need a wiring diagram.
The screws tell the story.
On one side of device has 2 screws.
On other side has 2 screws.
Green screw is for bare ground wire.
1) One side will have dark screws and the other side will have brass screws. The dark screws will be connected together with a brass plate. The brass screws will be separate.
-or-
2) One side will have brass screws and the other side will have silver screws. The brass screws will be connected together with a brass plate. The silver screws will be separate.
#1 Hot from breaker connects to dark screw. Wires to Load (light,fan) connect to brass screws.
-or-
#2 Hot from breaker connects to brass screw. Wires to Load (light, fan) connect to silver screws.
Nov 08, 2010 | Pass & Seymour #696LAGCC6 15A Almond 3WY...
Need wiring diagram for a ge triclad motor
Not all motors are dual voltage, the motor must state on th ename plate that it is dual voltage and can operate on 115
Oct 23, 2009 | Air Tools & Compressors
Have an old sears craftsman 1/4 hp grinder model 397.19501 wires have been disconnected. I want to rewire and test. Does anyone know how to connect the wires? There are 2 copper tabs under the on/off...
the two copper tabs under the on off switch are to break the power source.connect incoming power to one of these(black) then a short piece of wire from the other tab under switch to one of the three tabs under plate that is marked hot or l1 is probably #2 but you need to be sure. the white is the nuetral or l2 which is most likely #3 and the green is the ground most likely #4 I would definately look online for a wiring diagram to be sure if they are not marked with L1 L2 and GND
Oct 10, 2009 | Black & Decker 3/4 Hp, 8" 205MM, Heavy...
I have an older ge zoneline and one of the locknuts came off a selector switch. when it was turned it turned to far and twisted off five wires. i can put them back on but im not sure what terminals they...
I obtained the following statment from the GE web site:
How to Obtain a Wiring Diagram or Schematic...diagram. If you are in need of a replacement wiring diagram, simply call the GE Answer Center with your complete model number. The diagram may be faxed, e-mailed or mailed. You can reach us by dialing 1-800-626-2005. We are available...
http://genet.geappliances.com
Dec 19, 2008 | Heating & Cooling
General Electric Hotpoint® RB536BKBB Range Logo
195 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
