Question about Cafe Manila Cyber Cafe Management Standard
The client can't connect to the server - Cafe Manila Cyber Cafe Management Standard
How do i connect in server if client always say no response from server
Sounds more like a problem on the server side, not on your side.
Oct 17, 2014 | Computers & Internet
Smartcard cannot be forwarded to Terminal Server via RDP
Try re-registering the services on the client computer and see if that fixes it. Otherwise I would consider reinstalling Windows on the client.
Feb 11, 2014 | Microsoft Windows 7 Professional 64 Bit 3...
Handy cafe clients could not connect to server. i manually configured the server ip and they are now visible to the server. however ither server cannot control the clients
I am sick of my handycafe server keeps changing its ip addres.....i have to reconfigure from each client every day.....how can i just change my handy cafe server ip address......?
May 22, 2012 | Computers & Internet
HOW CAN I CONFIGURE MY HANDY CAFE SERVER AFTER I INSTALL
cant view my client in handycafe my net and router r ok last night i can view but now there gone
Mar 01, 2012 | Ates Software HandyCafe
What does 192,168,1,254 mean?
Your server may be In Active mode, the FTP client chooses the port number that it will use to transfer data on and tells the server which client-side port to send the data to. It issues the PORT command to let the server know what IP address and Port number it will be listening on to receive the data from the server.
PORT 192,168,1,254,4,15 The server then initiates the data transfer to the client, sending the data to the port number that it was told to by the client. Since the Server has initiated the connection, a stateful firewall will not allow the data to be sent back though. (No client has created the connection and so no respective connection exists.)
Hope this helps.
Good Luck
C2Solutions
Feb 16, 2012 | Dell Computers & Internet
How do i connect a client directly to my server?I keep getting an error message sayin i'm using an in store sychronization which is not supportedt by this version. My other client is working perfect. One...
First make sure all stations are on the same version, then uninstall the enterprise server/client services from the appropriate machines. Next, direct connect the client to the server. pcAmerica no longer supports the "enterprise" sync (which is lame) but have switched over to sql replication in the newer versions (which costs $$$). so the only way to do sync w/o redundancy is with direct connect. id also check out faq.pcamerica.com for some help
Nov 02, 2010 | Pc America Restaurant Pro Express
Syncing client with server - Restaurant Pro Express
Your getting a connection successful because your looking at the localhost. The server would be the network name of your server. And the password is case sensitive and is pcAmer1ca. (Note the number 1, not an i)
Jan 29, 2010 | Pc America Restaurant Pro Express
How can i connect client computers to server where clients have no hard disk.How clients can boot and access hard drive of server?
u can connect with ur client through terminal server. for that u've to server 2003. u can see the steps that how to configure terminal server for that u've to go this link:
http://support.microsoft.com/kb/300847
Sep 25, 2009 | Microsoft Windows Xp Home Edition Sp2...
Computers & Internet Logo
683 people viewed this question
Top Cafe Manila Computers & Internet Experts
David Payne
David Payne
Are you a Cafe Manila Computer and Internet Expert? Answer questions, earn points and help others
