Question about Riccar R552
My Ricar bobbin casing falls out when starting to sew. What's happening?
    Genius:
  • 1,788 Answers
Do you have the right size bobbin? And is your casing inserted the correct way and in the right position? Sometimes, if you have the wrong size bobbin it will cause this, remember not all bobbins fit all machines. Be sure you use the ones that your manufacturer recommends, or you can cause internal damage
Posted on Oct 04, 2010
The bobbin thread will not raise. The bobbin and holder falls out every time
Difficult to help without knowing the make & model.
If the bobbin case falls out, then it is not latched into place. Most bobbin cases have a spring loaded latch that needs to be held open until the bobbin case is firmly seated in the machine. Then the latch is released which locks it in place.
Installing Sewing Machine Bobbin
Aug 08, 2017 | Sewing Machines
Bobbin shuttle fell out
About 8,950 results (0.69 seconds) Search Results
    Inserting the Janome Front Loading Bobbin Case - YouTube
    ? 1:46
    https://www.youtube.com/watch?v=Mz7-k4G9HFg
    May 8, 2013 - Uploaded by Janome Canada
    Learn how to insert a front loading bobbin case. It's easier than you might imagine. Janome ... Janome HD-1000, Beginnersewing machine.
    How Do I Fix My Sewing Machine: Troubleshooting Your ...
    www.craftsy.com > Blog Home > Sewing Blog
    Nov 7, 2014 - Well, I've been teaching on Janome machines for about 6 years, and I ...Take the Trouble Out of Sewing Machine Troubleshooting! ... has fallen out of the take-up lever, which can happen if the machine was jammed along the way. ... of thread through the bobbin winding tension at the top of the machine.
    Bobbin Case Keeps Falling Out of a Sewing Machine ...
    www.thriftyfun.com/Bobbin-Case-Keeps-Falling-Out-of-a-Sewing-Mach...
Feb 09, 2016 | Janome Hd1000 Sewing Machine
Bobbin falls out of its place
the tip of the needle may be loged in the inside of the hook so the bobbin does not fit flush. do u hear a click when inserting the bobbin case?
Apr 29, 2014 | Juki Sewing Machines
Metal Bobbin Case falls down in machine when I try to sew
the bobbin case needs to be checked to see if it needs to be replaced
and also checked the hook and hook race.
Feb 16, 2013 | Sewing Machines
Loading Bobbin Case correctly in a 9410
the machine needs to be checked to see why thats happening
cause the bobbin case isn't suppose to do that
Feb 16, 2013 | Singer Sewing Machines
After I sew I can pull the bottom stitching right out. What causes this? Help
The problem is most likely thread tension. First try loosening the upper thread tension (numbered wheel on left side of most machines), if this doesn't rectify the problem then check the bobbin case tension. Correct bobbin case tension can be verified by holding the bobbin case with bobbin inserted and thread extended several inches. If you grasp the thread the bobbin case should not descend rapidly (fall) but should unspool slightly when thread is quickly tugged upward. Please refer to attached picture or your owner's manual.azcouture_1.jpg
May 15, 2011 | Brother LS-1217 Mechanical Sewing Machine
When I try to sew, the bobbin bangs around, like it doesn't fit.
Is it the bobbin or the bobbin case that is banging around? If I don't seat my bobbin case properly, it rattles and eventually falls out. Your bobbin case may be damaged, in which case, the bobbin is not going to fit properly. I dropped and stepped on my bobbin case once and the machine had the same symptoms. Then there's the obvious answer, a wrong size bobbin got mixed up with your bobbins. I've had that happen when I've taken a class with others. We all share tools and sometimes the right ones don't get back to their proper owner.
Nov 28, 2010 | Brother XL-2600I
On sewing a normal seam, the bottom piece of material becomes puckered
From what you describe, it sounds like you have your bobbin tension a bit too tight. Take the bobbin case out of the machine and hold it up by the thread. The bobbin case should move down slightly when you give it a slight ****. If the bobbin case doesn't move much it is too tight and if the bobbin case falls into your hand it's too loose.
I’m happy to assist further over the phone at https://www.6ya.com/expert/gary_ff3d95e2d75b6cc9
Nov 13, 2009 | Bernina Virtuosa 160
While sewing the bobbin case moves, wheel locks up, needle locks
Im not sure if this will help but thought I would pass it along. My Pfaff 6122 tells me to check bobbin for thread unrolling clockwise before you place it back in the machine. I had mine turned to un roll counter clockwise, this is wrong, the bobbin will fall out when you pull on the thread while you are holding it in your hand. You may just keep putting it in backwards. Hope this works for you. J.R.
Feb 05, 2009 | Brother CS-6000
Bobbin case.......
A bobbin case for accommodating a bobbin which has a shaft portion and a collar portion formed on both sides of the shaft portion on which a thread is wound, the bobbin case comprises: an opening being opened on at least one side of an axial direction of the shaft portion, for detachably accommodating the bobbin; a thread take-up portion provided in the axial direction opposite to the opening, for pulling out the thread of the bobbin; and a holding member which makes contact with the bobbin and nonrotatably holds the bobbin.
Feb 27, 2008 | Brother LS-2125 Mechanical Sewing Machine
Riccar R552 Logo
510 people viewed this question
Top Riccar Sewing Machines Experts
Tally Girl
Tally Girl
Joseph Mueller
Joseph Mueller
Are you a Riccar Sewing Machine Expert? Answer questions, earn points and help others
